17th August 2010, 21:58 | #10463 | Link | ||
17th August 2010, 22:29 | #10464 | Link | ||
NY Frame of Mind
Reminds me of years ago when I worked for the Norwegian audio co Tandberg. The running joke was that the name translated to "intermittent". Quote:
"Talk to me Goose" |
18th August 2010, 20:06 | #10465 | Link | |
20th August 2010, 03:43 | #10467 | Link | |
Perhaps if eac3to could look at the first 2 files in the playlist and then it notices they do not have matching tracks it could then use only the file with the higher track count and longest time. If the track counts don’t match eac3to will fail anyway, so there would be nothing to loose. The chapter times would also have to be offset by missing file length. Maybe if the first file is less than 30 seconds long just drop it, or perhaps a switch? Mike
Another EAC3to GUI Plus Last edited by MikeEby; 20th August 2010 at 03:49. |
20th August 2010, 10:17 | #10468 | Link | |||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 20th August 2010 at 10:25. |
20th August 2010, 10:31 | #10469 | Link |
Or change the way the info is presented, currently:
M2TS, 1 video track, 1 audio track, 0:20:43, 50i 1: Chapters, 4 chapters 2: MPEG2, 576i50 (16:9) 3: AC3, German, 2.0 channels, 192kbps, 48kHz Code:
00001.M2TS, 1 video track, 1 audio track, 0:00:43, 50i 1: Chapters, 4 chapters 2: MPEG2, 576i50 (16:9) 3: AC3, German, 2.0 channels, 192kbps, 48kHz 00002.M2TS, 1 video track, 1 audio track, 0:20:00, 24p 4: VC-1,1080p24 (16:9) 5: DTS, German, 5.1 channels |
20th August 2010, 12:07 | #10470 | Link |
madshi,
"-mono" switch to output only center channel (in mono wavs) doesn't seem to work correctly when a second pass is needed. Code:
eac3to v3.24 command line: eac3to audio.thd audio.bd.wavs -mono ------------------------------------------------------------------------------ TrueHD, 5.1 channels, 48kHz Decoding with libav/ffmpeg... Writing WAVs... Creating file "audio.bd.C.wav"... [libav] Lossless check failed - expected 0, calculated c <WARNING> The original audio track has a constant bit depth of 16 bits. Superfluous zero bytes detected, will be stripped in 2nd pass. Starting 2nd pass... Decoding with libav/ffmpeg... Reducing depth from 24 to 16 bits... Writing WAVs... Creating file "audio.bd.L.wav"... Creating file "audio.bd.C.wav"... Creating file "audio.bd.SR.wav"... Creating file "audio.bd.LFE.wav"... Creating file "audio.bd.R.wav"... Creating file "audio.bd.SL.wav"... The processed audio track has a constant bit depth of 16 bits. eac3to processing took 21 minutes, 21 seconds. Done. Last edited by nautilus7; 20th August 2010 at 12:12. |
20th August 2010, 19:10 | #10472 | Link |
I don't know if this is a bug, or if that's what's meant to be, but demuxed H264 videos cannot be opened with Adobe Premiere, while the same videos demuxed with tsMuxeR can be opened and edited perfectly.
Greetings EDIT: The files I'm demuxing are m2ts ripped from bluray Last edited by chompy; 20th August 2010 at 19:28. |
20th August 2010, 19:36 | #10473 | Link | |
Logo 1, Channels: 2.0, 10.400s Logo 2, Channels: 5.1, 4.992s Logo 3, Channels: 2.0, 15.680s Movie, Channels: 5.1 _
if you ask a question and somebody give you the correct answer don't forget to leave a "thank you" note... Visit The Land Of Dracula (Romania - EU)! |
21st August 2010, 13:21 | #10475 | Link |
Acid fr0g
I am trying to convert "American Gangster" extended edition from BD to MKV.
Firstly I have to correctly demux every track but a problem exist. The standard lenght is composed by the following M2TS: Code:
2:36:50 235+222 236+223 237+224 238+225 239+226 240+227 241+228 242+229 243+230 244+231 245+232 246+233 247+234 248 Code:
2:55:46 235+249 236+250 237+251 238+252 239+253 240+254 241+255 242+256 243+257 244+258 245+259 246+260 247+261 248 I need the italian+english(when italian missing) extended version. How is possible to tell eac3to to select a particular stream from a M2TS and changing it while joining?
@turment on Telegram |
22nd August 2010, 00:53 | #10476 | Link | |
The Girl With The Dragon Tatoo (US Version) Code:
1) 00001.mpls, 2:33:02 [1+0+17+18].m2ts - Chapters, 17 chapters - h264/AVC, 1080p24 /1.001 (16:9) 00001.m2ts M2TS, 1 video track, 0:00:10, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 00000.m2ts M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 2:32:44, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: AC3, Swedish, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB 3: AC3, English, 5.0 channels, 448kbps, 48kHz, dialnorm: -27dB 4: Subtitle (PGS), English 00017.m2ts M2TS, 1 video track, 0:00:04, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 00018.m2ts M2TS, 1 video track, 0:00:04, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) Mary and Max (US Version) This one has matching track counts just the track properties don't match. Code:
1) 00000.mpls, 00023.m2ts+00000.m2ts, 1:32:26 - Chapters, 17 chapters - h264/AVC, 1080p24 /1.001 (16:9) - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz 2) 00007.mpls, 00007.m2ts, 0:22:04 - MPEG2, 480i60 /1.001 (16:9) - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz 3) 00002.mpls, 00005.m2ts, 0:15:48 - Chapters, 6 chapters - MPEG2, 480i60 /1.001 (4:3) - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz - RAW/PCM, English, stereo, 48kHz 00023.m2ts M2TS, 1 video track, 4 audio tracks, 2 subtitle tracks, 0:00:10, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz 3: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz 4: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz 5: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz 6: Subtitle (PGS), Spanish 7: Subtitle (PGS), English 00000.m2ts M2TS, 1 video track, 4 audio tracks, 2 subtitle tracks, 1:32:16, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: RAW/PCM, English, 2.0 channels, 24 bits, 48kHz 3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz) 4: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz 5: RAW/PCM, English, 2.0 channels, 16 bits, 48kHz 6: Subtitle (PGS), Spanish 7: Subtitle (PGS), English Code:
1) 00001.mpls, 00009.m2ts+00003.m2ts, 1:31:48 - Chapters, 12 chapters - h264/AVC, 1080p24 /1.001 (16:9) - DTS, English, stereo, 48kHz - DTS, English, stereo, 48kHz 2) 00005.mpls, 00011.m2ts, 0:23:55 - h264/AVC, 1080i60 /1.001 (16:9) - DTS, English, stereo, 48kHz 3) 00004.mpls, 00010.m2ts, 0:23:12 - h264/AVC, 1080i60 /1.001 (16:9) - DTS, English, stereo, 48kHz 00009.m2ts M2TS, 1 video track, 2 audio tracks, 0:00:15, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: DTS, English, 2.0 channels, 16 bits, 510kbps, 48kHz 3: DTS, English, 2.0 channels, 16 bits, 510kbps, 48kHz 00003.m2ts M2TS, 1 video track, 2 audio tracks, 1:31:32, 24p /1.001 1: h264/AVC, 1080p24 /1.001 (16:9) 2: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz) 3: DTS, English, 2.0 channels, 16 bits, 768kbps, 48kHz Mike
Another EAC3to GUI Plus Last edited by MikeEby; 22nd August 2010 at 01:04. |
23rd August 2010, 01:05 | #10478 | Link |
I am using the eac3to v3.24 to extract wave files from a DTS MA source. I noticed that the wave files have a bitrate of 1152kbps though the core is 1509 kbps. I am using the arcsoft DTS decoder v1.1.0.0. I extracted the wave files using the following command line
c:\path\to\eac3to.exe e:\path\to\blu-ray\source 1) 3: output.wavs |
23rd August 2010, 01:25 | #10479 | Link |
No, nothing's wrong. The bitrate of a PCM WAV file is always going to be (bitdepth * sample rate * channels / 1000) kbps. More specifically bitdepth will be rounded up to the nearest byte.
So in your example it's 24 * 48000 * 1 / 1000 = 1152kbps It doesn't matter if the source is lossy or lossless. If they both decode to the same bitdepth then the resultant wavs will be the same size. |
23rd August 2010, 02:21 | #10480 | Link |
Acid fr0g
Sorry, I have tried but Make MKV sees only the eng audio for the extended version.. My will is to use the eng audio where the ita audio is missing... I could try to encode every M2TS separately and join them but doing this would not correct the audio gaps and so.
eac3to |
