Old 27th April 2015, 10:43   #61  |  Link
stax76
stax76's Avatar
Luigi, thanks for testing and confirming.
Old 27th April 2015, 13:37   #62  |  Link
luigizaninoni
Managed to get QTGMC to work.
avs file:
LoadPlugin("C:\Users\luigi.TZMS\Desktop\Video\Staxrip64\Tools\DGMPGDec\DGDecode.dll")
MPEG2Source("C:\Users\luigi.TZMS\Desktop\burosch1 temp files\burosch1.d2v")
QTGMC( Preset="Slow" , TR2=3 , EZDenoise=0.65).SelectEven()
Put MaskTools2, MVTools2, RgTools, NNEDI3 (as downloaded from Reel.deel post) into C:\Program Files (x86)\AviSynth+\plugins64+ folder
If you want EZdenoise, put in same folder also fft3dFilter.dll, and put libfftw3f-3.dll into c:\windows\system32 folder (both downloaded from here: https://code.google.com/p/avisynth64/wiki/PluginLinks )
Well I can't explain how it works, given that Nnedi3 plugin should not work in windows 8.1; however the nnedi3.dll in avisynth+ folder is different from the one in Staxrip64\Tools\Plugins\nnedi3 so who knows ....
Have not tested speed yet; tonight I'm going to do speed comparison vs. staxrip32 and report back
luigizaninoni is offline   Reply With Quote
Old 27th April 2015, 14:19   #63  |  Link
dejong12
I get this error when trying to encode with NVEnc x264 and not selecting crop:
Error Encoding using NVEncC
Encoding using NVEncC failed with exit code 1
Invalid crop value.: 0x0, Crop [0,0,0,0]
StaxRip.ErrorAbortException: Encoding using NVEncC failed with exit code 1
bij StaxRip.Proc.Start() in C:\Daten\Projekte\GitHub\staxrip\General\Proc.vb:regel 226
bij StaxRip.NvidiaEncoder.Encode(String args) in C:\Daten\Projekte\GitHub\staxrip\General\VideoEncoder.vb:regel 892
bij StaxRip.NvidiaEncoder.Encode() in C:\Daten\Projekte\GitHub\staxrip\General\VideoEncoder.vb:regel 882
bij StaxRip.MainForm.Encode() in C:\Daten\Projekte\GitHub\staxrip\Forms\MainForm.vb:regel 2231
bij StaxRip.MainForm.RunJobRecursive() in C:\Daten\Projekte\GitHub\staxrip\Forms\MainForm.vb:regel 3493
dejong12 is offline   Reply With Quote
Old 27th April 2015, 14:24   #64  |  Link
luigizaninoni
Stax76, just mailed to your address the nnedi3.dll I put into avisynth+ plugins64+ folder. The other nnedi3.dll is the one contained in your installer. The two files are different.
Old 27th April 2015, 14:29   #65  |  Link
stax76
stax76's Avatar
@dejong12
The hardware encoders with GUI don't work at the moment because the 64-Bit encoders don't support avs input, I'm waiting for a answer or update from the author. There is a CLI encoder included that can be used meanwhile.
@luigizaninoni
Thanks, I'll try it when my encode finishes (also using QTGMC).
Old 27th April 2015, 17:54   #66  |  Link
luigizaninoni
made some tests.
First of all there is a problem with Crop filter: autocrop definitely does not work. Error message:
Crop: Destination width is 0 or less.
(E:\Tolta pubblicità\prova temp files\prova.avs, line 3)
Second, I made a SD and HD test. The HD looks fine, much faster and same quality as Staxrip32
The SD test however is puzzling: speed is actually higher in Stax32 (not multithreaded) than Stax64.
I definitely need to perform some more tests.
Old 27th April 2015, 18:20   #67  |  Link
stax76
stax76's Avatar
It works here on Win10, I just tried, maybe specific to a particular source?
Old 27th April 2015, 18:26   #68  |  Link
luigizaninoni
no, autocrop filter did not work on any file I tried. They were all .ts though
Old 27th April 2015, 18:33   #69  |  Link
stax76
stax76's Avatar
avc ts by default should be first muxed to mkv before it's opened, for this StaxRip should have ask you to install haali splitter.
mpeg-2 ts is handled by DGMPGDec (DGIndex/DGDecode) by default.
Old 27th April 2015, 19:28   #70  |  Link
kalehrl
Added xvid_encraw 1.2.0.0
Why not the latest 1.3.3?
kalehrl is offline   Reply With Quote
Old 27th April 2015, 20:03   #71  |  Link
stax76
stax76's Avatar
I couldn't find a x64 build.
Old 28th April 2015, 15:30   #72  |  Link
stax76
stax76's Avatar
@kalehrl
Next build has XviD 1.3.3 and a additional XviD 2 pass profile.
"%app:xvid_encraw%" -smoother 0 -max_key_interval 250 -nopacked -vhqmode 4 -qpel -lumimasking -notrellis -max_bframes 1 -bvhq -bquant_ratio 162 -bquant_offset 0 -threads 1 -i "%avs_file%" -pass1 "%working_dir%%target_name%.stats" -bitrate %video_bitrate% -par %target_sar% -turbo
"%app:xvid_encraw%" -smoother 0 -max_key_interval 250 -nopacked -vhqmode 4 -qpel -lumimasking -notrellis -max_bframes 1 -bvhq -bquant_ratio 162 -bquant_offset 0 -threads 1 -i "%avs_file%" -pass2 "%working_dir%%target_name%.stats" -bitrate %video_bitrate% -par %target_sar% -avi "%encoder_out_file%"
Old 28th April 2015, 15:51   #73  |  Link
Patman
Patman's Avatar
Thats great Stax. I've found xvid_encraw 1.3.3 x64 too. And i think the pipe option caused the error. Because of the search, it was a short night :-D
Tools for StaxRip | x264 - x265
Patman is offline   Reply With Quote
Old 29th April 2015, 09:51   #74  |  Link
stax76
stax76's Avatar
The nnedi3 problem happens only in vmware so QTGMC works on Win8 and Win10.
Next StaxRip release will have:
ffms2 is fixed
NVEncC and QSEncC are reverted to use piping with ffmpeg
StaxRip 64-Bit will use a different settings then StaxRip 32-Bit, currently the settings are shared which is problematic. I guess it's possible to use AviSynth 2.6 32-Bit side by side with AviSynth+ 64-Bit
Did I miss any problem or is everything solved then? The port would be complete then and could be released as beta.
Old 29th April 2015, 11:13   #75  |  Link
luigizaninoni
Autocrop of .ts still not solved (autocrop of .mp4 works fine)
https://dl.dropboxusercontent.com/u/...si_StaxRip.log
Crop: Destination height is 0 or less.
(C:\Users\luigi.TZMS\Desktop\Incensurato cercasi temp files\Incensurato cercasi.avs, line 4)
Old 29th April 2015, 13:40   #76  |  Link
stax76
stax76's Avatar
Can you upload this source, I probably can't do something but want to keep the file in case I start AviSynth programming, unfortunately AutoCrop as far as I know hasn't a maintainer (not sure about it).
Old 29th April 2015, 14:12   #77  |  Link
luigizaninoni
uploaded 1 minute clip:
https://dl.dropboxusercontent.com/u/...o%20cercasi.ts
Stax64 is still usable, you can always find the correct crop with some other software, and then manually edit the avs script
Old 29th April 2015, 17:01   #78  |  Link
stax76
stax76's Avatar
it's DGDecode failing to decode in Win8 and Win10, Win7 is fine. Take a look in the preview, everything is green! Use this workaround:
in the settings on the demux tab make this changes:
add projectx (use add button)
move projectx above DGIndex (use up button)
remove m2v extension from DGIndex (use edit button)
now you are good, open a source, sit down a minute and try to understand how all this works, study the log file
is there any software with a more comfortable and powerful manual cropping dialog then StaxRip? I doubt so! Press F1 in the crop dialog, always use mousewheel together with control and shift key.
Old 29th April 2015, 17:25   #79  |  Link
stax76
stax76's Avatar
What I don't get is why is the preview of the script in StaxRip and MPC all green and AutoCrop don't work but still x264 encodes it all fine.
Old 29th April 2015, 18:16   #80  |  Link
luigizaninoni
now ts autocrop works fine, thanks a lot!
