Old 6th December 2005, 23:26   #441  |  Link
Originally Posted by Chainmax
Ok, so how do I do that?
My way:
eedi2() # 160x112 -> 160x224
lanczosresize(320,256) # -> 320x256
Would mg262's method work?
What he gave is not complete. I suppose he's just saying that you can resize the width by turning. But he still has to get from 224 vertical to your required 256. So maybe he means this:
turnright().eedi2().turnleft() # 160x112 -> 320x112
eedi2() # -> 320x224
lanczosresize(320,256) -> 320x256
Old 6th December 2005, 23:41   #442  |  Link
mg262
Clouded
mg262's Avatar
Yes, that's all I meant. Sorry if I was too brief -- I was posting in a hurry. I would also try both variants:
lanczosresize(320,256) #-> 320x256
eedi2() # 160x112 -> 320x112
turnright().eedi2().turnleft() #-> 320x224
There probably won't be a difference, but it's hard to be certain without knowing exactly how the filter works... and it doesn't take long to try both. For general resolutions, I would also try overshooting the target resolution and then downsampling... but in this case, 224 and 256 are so close that I don't think it's worth trying.
a.k.a. Clouded. Come and help by making sure your favourite AVISynth filters and scripts are listed.
mg262 is offline   Reply With Quote
Old 6th December 2005, 23:54   #443  |  Link
Chainmax
Huh?
Chainmax's Avatar
Ok, which one of these three you prefer:
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it.
Chainmax is offline   Reply With Quote
Old 6th December 2005, 23:59   #444  |  Link
mg262
Clouded
mg262's Avatar
Definitely not the second -- horribly blocky. There's not much between the first and the third, but I think I prefer the third. But both emphasise vertical features more than I would like.
Old 7th December 2005, 00:07   #445  |  Link
Chainmax
Huh?
Chainmax's Avatar
What do you mean by that?
Old 7th December 2005, 00:10   #446  |  Link
mg262
Clouded
mg262's Avatar
It looks like everything has been painted by someone who only understood how to make vertical strokes. That may just be a feature of the scene, of course.
Old 7th December 2005, 00:15   #447  |  Link
Chainmax
Huh?
Chainmax's Avatar
Well, the second picture is the source with just lanczos and addborders, does it show that issue as well?
Old 7th December 2005, 00:17   #448  |  Link
mg262
Clouded
mg262's Avatar
Now that you mention it, looking again, I think it does.
Old 7th December 2005, 01:14   #449  |  Link
The size is not 320x256 as you said you required. Why are you changing the game?
Old 7th December 2005, 02:04   #450  |  Link
Chainmax
Huh?
Chainmax's Avatar
The actual picture size is 320x256, I'm just adding borders to reach a DVD compliant resolution.
Old 8th December 2005, 05:29   #451  |  Link
@tritical
OK, first time I'm using Tdeint()...
You wrote:
That means TDeint could use EEDI2 in the following way (assuming clip is TFF):
interp = separatefields().selecteven().EEDI2(field=1)
tdeint(edeint=interp)
I wanted to try this adaptive use of eedi2(). I had a BFF wedding DV clip. So I did this first:
interp = separatefields().selectodd().EEDI2(field=0)
return interp
The result is nice:
Then I tried this:
tdeint(order=0,edeint=interp)
But the result is not so nice (note aliased diagonals):
Can you set me straight, please? Thank you.
Old 8th December 2005, 07:28   #452  |  Link
tritical
I stated things incorrectly and oversimplified into two scenarios when there are actually four same framerate deinterlacing cases that need specific handling. The configurations should be:
1.) bff clip, keep bottom field, interpolate top field:
interp = separatefields().selecteven().EEDI2(field=0)
tdeint(order=0,field=0,edeint=interp)
2.) bff clip, keep top field, interpolate bottom field:
interp = separatefields().selectodd().EEDI2(field=1)
tdeint(order=0,field=1,edeint=interp)
3.) tff clip, keep bottom field, interpolate top field:
tdeint(order=1,field=0,edeint=interp)
4.) tff clip, keep top field, interpolate bottom field:
tdeint(order=1,field=1,edeint=interp)
The settings you tried should be changed to either case 1 (just change selectodd to selecteven) or case 2.
There are also the configs for bobbing, but atm the edeint option is broken for bobbed output so I'll post those later when it is working.
tritical is offline   Reply With Quote
Old 8th December 2005, 15:11   #453  |  Link
Thank you for the clarification. I tried case 1. But the result is not as satisfying as I hoped. Please compare the sharp diagonals to the pure eedi2() picture in my previous post (especially over Ben's right shoulder). Is there anything I can do, perhaps lower the threshold?
EDIT: Even with thresholds at 0, it's not improved. Apparently it is the alternating of passed through content with interp'ed content, as can be seen via the map option, that causes this. I think we need to determine the combed areas and then use the interp'ed data on all scan lines within that area. What do you think?
case 1:
Old 8th December 2005, 21:53   #454  |  Link
tritical
@neuron2
Any way that I could get that part of the clip for testing? Also, how fast is the background moving in that sequence? If you set the motion thresholds to -1 do those areas look as they do in the interp clip?
Expanding the motion map that way would probably help in this case, but I can't say for sure without seeing which pixels it is weaving and why.
@All
I was thinking last night about making an edeint type option for the motion map that would allow TDeint to take a motion map from another filter. I've realized that I don't want to reimplement all of the options and features of TDeint in TDeint2 (and the code in TDeint is so big and ugly that if I did I would rewrite it all) when the only real changes would be EEDI2 type interpolation, which can already be used in TDeint, and the new motion mapping. So instead, I am going to add an "emap" parameter to TDeint. Luckily, I already have my new motion mapping implemented in another filter . The downside to doing everything in separate filters is it is slightly slower than if it was integrated and it makes it more complicated to use. On the plus side, allowing everything to be done externally opens up more possibilities and makes it easier to implement new ideas.
Old 8th December 2005, 22:11   #455  |  Link
Thanks, tritical. I'll upload the clip when I get home tonight. Right now, I'm busy finding out how crappy all the H.264 tools are. How about this: a "Pro" transport multiplexer that won't let you set the PIDs or the transport mux rate (heck, it won't even tell you what rate it ends up with, so you have no way to know what rate to inject it at!).
Old 9th December 2005, 00:33   #456  |  Link
DarkNite
Almost Silent Member
DarkNite's Avatar
I wouldn't worry about integration until you had both the time and desire to do so. Things aren't so complicated for those of us who know the lost art of "how to rtfm".
Rethinking the "Why?" chromosome.
DarkNite is offline   Reply With Quote
Old 9th December 2005, 01:34   #457  |  Link
Here it is:
http://neuron2.net/misc/short.zip
It's BFF DV. I've been using Cedocida. The snapshots are from frame 0.
Thank you for taking a look at this. I still think the motion areas need to use all the scan lines. I mean, how could that be wrong, since it would be copying whole areas of the good full interp'ed clip, which we know looks fine? I concede that it may not be necessary, but let's see if you find a weaving issue.
No, it's fully combed! That suggests that your case 1 is set up wrong, or there is a weaving bug.
Old 9th December 2005, 02:11   #458  |  Link
OK, I solved it. You need the field parameter on Tdeint() for case 1!
It makes a very sweet adaptive deinterlacer. This results in the best deinterlacing I have ever seen under Avisynth. It blows away LeakKernelDeint(). And it's tolerably fast on my 64FX-55. Bravo, tritical!
Would it be possible for you to update your four cases above with the right field settings for Tdeint(), as this will serve as a reference for use of this outstanding method?
Sweet (who needs Faroudja?):
Old 9th December 2005, 02:46   #459  |  Link
Interestingly, you can get comparable results with my VirtualDub filter. My code is a lot more naive so will produce more artifacts. But it still looks pretty good. Here are the settings:
Old 9th December 2005, 03:18   #460  |  Link
tritical
Thanks, I'll update the settings... it is quite funny that I can't keep the parameters right for my own plugins. I was assuming field got set to the same value as order by default (field=-1) in TDeint since that is how it works in TIVTC, but that is not true (it uses field=1 by default)... I should read the readme sometime . Now I am wondering how many times I have made that mistake when giving settings before.
tdeint, tivtc
