6th May 2011, 07:23 | #7621 | Link | |
I think it would be a good idea for you to look at overclocking your GPU and squeezing as much as you can out of it. |
6th May 2011, 07:45 | #7622 | Link | |
The 6450 is supposedly faster than previous generation you should be fine. I'm getting by almost perfectly with a 4550 (slight more powerful than 5450) with madVRsync061 |
6th May 2011, 08:41 | #7623 | Link | ||
Also if you've ticked 'use separate device for presentation' under the general settings make sure you haven't ticked 'use D3D11 for presentation' as I found that to be slightly more demanding of my 5670.
Madshi, have you considered developing a few madVR profiles? Low quality (for slower computers) for example would avoid more of these questions as madVR becomes more popular. Last edited by ryrynz; 6th May 2011 at 09:06. |
6th May 2011, 09:32 | #7624 | Link |
Is it possible to change OSD shortcut to something else than "ctrl+j"? It is overriding Photoshop shortcut which i use quite often.
Sorry, if this was mentioned before but it's quite hard to look through ~380 pages. On page 170 Madshi responds that he will add option to assign diffirent shortcut somewhere in future so maybe i just can't find it. Or is it not done yet? Thanks! |
6th May 2011, 10:00 | #7625 | Link | ||
I will test your settings when I'm back at home and report back. |
6th May 2011, 10:01 | #7626 | Link | |
6th May 2011, 14:04 | #7627 | Link |
I still get an access violation error when I switch to the next mediafile in the folder. I use PgUp and PgDown to do this often from within the media player - and whenever I do, I get an error.
MPC-HC says: Access violation at adress 4A50F54E in module MVRSETTINGS.DLL Read of adress 06FFFFFC. This has ben happening since v0.59 and changing settings dosn't seem to do anything. It only happens in exclusive mode btw. Works fine in windowed. Any1 else getting this error or can help? |
6th May 2011, 19:22 | #7629 | Link | |
Yeaah =) Last edited by ch1n4; 6th May 2011 at 21:41. |
6th May 2011, 21:17 | #7630 | Link | |
http://en.wikipedia.org/wiki/Nyquist...mpling_theorem The maximum frequency a PCM recording can hold is half its sampling rate, which would be 22.05 kHz for a file sampled at 44.1 kHz, well above what any human can hear. The only true use for higher sampling rates is for better pitch or time shifting, the process of which involves resampling, which would be why Reclock wants to oversample. Last edited by Pyroshock; 6th May 2011 at 21:21. |
6th May 2011, 21:49 | #7631 | Link | |
In that example posted above, if you were to sample the analogue signal at 20Hz (assuming the image above is 10Hz) you would simply have twice the number of data points per second, and a better representation of the original signal. It doesn't change the frequency of the audio, it simply gives you more data points on it. When you are just playing back audio, you're fine playing back 48kHz audio at 48kHz, but if you are making any changes to it, you need to oversample it to have enough precision to do so without a quality loss. This is essentially the same reason madVR works in 16-bit despite our video sources being 8-bit. |
6th May 2011, 22:45 | #7632 | Link | ||
The truth is, that it doesn't matter. No-one is able to see the difference between 24 and 23.976 fps (see no hear). You don't even have to mess with sound if you edit common scene in a movie, because single shot is usually very short (couple of seconds), so video and audio are still in sync. Quote:
Also upsampling by averaging samples (like in your example) introduces false frequencies beyond initial 24kHz). Reclock indeed uses 32/192, but AFAIK only for output from resampling routines, to better allocate data from resampling process. And that is perfectly resonable. Sure, but it works only for analogue output. |
6th May 2011, 22:54 | #7633 | Link | |
7th May 2011, 04:46 | #7634 | Link |
I'm trying to use MadVR with RGB to talk to my Panasonic TH-P50VT20A plasma over HDMI from HTPC Windows 7, Quad Core, 1G, ATI 5570.
Whenever I set the Pixel Format to in CCC (11.4, 11.3, 11.2 & 10.8) to ATI "RGB 4:4:4" it does the update and all my levels are fine - brilliant picture. BUT sometime between 10 seconds and 60 seconds later it "auto magically" goes to YCbCr 4:4:4 in CCC, I can see it resync on the plasma, revert to YCbCr 4:4:4 in CCC and screw my levels. Reboots and coming out of standby also seem to trigger it. Levels are correct if I use a DVI to HDMI cable, but for other reasons I can't use this. One thing that does seem to trigger the "reverting" is closing MPC-HT with MadVR. Perhaps something is "resetting" regularly? I've reverted to 10.8 drivers, but they seem to have the same behavour. I've googled my head off and can't find much except old stuff about the YCbCr 4:4:4 being shown after RGB 4:4:4 update, but this is different. Is anyone else seeing this? Any ideas? Update: More googling finally turned up the answer. Turn off GPU Scalling, stop AMD external event service, change Pixel Format to RGB 4:4:4, reboot and enable service
ASUS H97 Plus, Intel i5-4690 2.50Ghz, 16GB DD3 1600, XFX R9 270X 2GB DDR5, LynxTwo B Win 8.1 Pro with WMC 64Bit, Kodi, MPC-HC 1.7.8, LAV 0.65.0, Reclock 1.8.8.5, HD AnyDVD Last edited by Neeto; 7th May 2011 at 05:09. |
7th May 2011, 06:40 | #7636 | Link |
It depends on the frame rate of your content but lets assume your content is 24fps, the point to running at 24hz on 24fps material is to avoid frame drops or duplicated frames. Advantages of this are a smoother movie watching experience the disadvantage is that some screens have a high amount of flicker at low refresh rates.
7th May 2011, 07:59 | #7637 | Link |
tell me how to set display modes in madvr v0.61 version with video stream 1280*544P ,23.976fps and video hardware 1920*1080@60,please.
when playing a video with 1920*800p 24fps,how should I set display modes in madvr v0.61 to watch the most smooth video? |
7th May 2011, 08:37 | #7638 | Link | |
I think you should use reclock because there is filckers at low refresh rate. I run 24p at 48hz so the problem is not as serious as 24hz. |
7th May 2011, 09:18 | #7639 | Link | |
7th May 2011, 14:23 | #7640 | Link | |
(1) Does the amount of sync mismatch depend on the number of pre-presented frames (which you can set to anything between 1-16)? (2) What happens if you activate/deactivate the "use a separate device for presentation" option (render settings)? Does that fix the problem? (3) What about the D3D11 presentation path? Does that fix the problem? Generally audio should have exactly the same sync with "present several frames in advance" turned on and off. If there's a difference then something is going wrong. Can you other guys please also test and report audio/video sync? Thanks... |
