26th October 2018, 20:47 | #53401 | Link | |
26th October 2018, 21:22 | #53403 | Link | |
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K |
26th October 2018, 21:48 | #53404 | Link |
I would expect it just uses DirectShow to read the files, in which case it should be able to record for anything that LAV Splitter can read for you, no?
26th October 2018, 22:40 | #53405 | Link | |
HTPC: Windows 11, AMD 5900X, RTX 3080, Pioneer Elite VSX-LX303, LG G2 77" OLED Last edited by SamuriHL; 26th October 2018 at 22:45. |
26th October 2018, 22:58 | #53407 | Link | |
EDIT: I spoke too fast, the utility quits after a few minutes. EDIT2: I tried again and this time it created a measurements file, but it's not taken into account, whether I drop the whole folder in MPC-BE or just the index.bdmv file. Let's wait until we hear from Madshi to know if it's supposed to be supported or not.
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 26th October 2018 at 23:42. |
27th October 2018, 00:43 | #53408 | Link |
Try DXVA2 (copy-back) instead of D3D11.
27th October 2018, 07:52 | #53409 | Link |
I am trying to understand how keyboard shortcuts for the different settings work. After pressing the shortcut keys do I also have to hit F2 for the setting to apply or does it apply instantly?
Secondly, I am trying to create shortcut keys for switching between the image-doubling options so I can decide on the fly whether I want NGU anti-alias or NGU sharp. Is this possible? |
27th October 2018, 09:49 | #53410 | Link |
I'm looking to upgrade my HTPC to add 2160p HDR support. I have two options: either replace my GT 430 with a newer full-height GPU (maybe passively cooled), or swap out the box for my old TV server box, which is much smaller and would require a half-height GPU. So I have 2 questions:
- Does anyone have any experience with the Gigabyte GTX 1050 Ti OC Low Profile 4G? Is it likely to be silent whilst doing madVR duty? - Is there a chance of a superior madVR HTPC GPU any time soon? Like a GT 2030 or 2050? What about an AMD RX560 would that work as well?
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
27th October 2018, 09:53 | #53411 | Link |
Yeah, thanx but it didn't work (and it's veeeeery slow compared to D3D11). It's a GT 1030 (I'm at my weekend location). It won't even start measuring if "measure each frame's peak luminance" is not checked in MadVR (it's only logical?) but I assume I need to deactivate it if I want the measure file to be used?
27th October 2018, 11:17 | #53413 | Link | ||
Edit: I would go with a 1050 Ti (4 GB) rather than an RX560 for madVR. The more affordable ones of each model are about the same price.
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 Last edited by el Filou; 27th October 2018 at 11:21. |
27th October 2018, 14:33 | #53415 | Link | |
Mostly less than that. I was playing with my HD7770 and with ~29ms of both average and max stats i can have smooth playback in almost every file. But i only tested for 5 minutes and stop. Then i started watching the last episode of Daredevil and 5 minutes into it bye bye playback. Rendering times went up like crazy. So, for me, safe rendering times is around 20ms. No dropped frames. But its at a cost. Instead of NNEDi 32 neurons i will need to stick with 16 neurons. And the difference is huge. Believe me. Im talking about chrom upscaling. Luma upscale is fine whatever i put (since its not double). Its the same with downscale except SSIM 2D. |
27th October 2018, 15:06 | #53416 | Link | |
"image upscaling algorithm - toggle" and "image upscaling parameter - increase/decrease" may be able to do what you want. You would have to otherwise create separate profiles under "scaling" and only use NGU Sharp and Anti-Alias in those profiles and swap between them by assigning each a keyboard shortcut.
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 27th October 2018 at 15:13. |
27th October 2018, 15:09 | #53417 | Link | |
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 27th October 2018 at 15:15. |
27th October 2018, 15:10 | #53418 | Link |
In this case, your TV would be doing the tone mapping, so the metadata couldn't be used because the TV can't receive it or read it.
27th October 2018, 15:12 | #53419 | Link |
If it says "scene" and "movie" the measurements file is working correctly. This information wouldn't otherwise appear.
