16th September 2008, 23:20 | #2023 | Link |
b4k3d
'AV Frame Too Large' Error?
I get this error when trying to remux:
The Bourne Ultimatum (HD-DVD -> TS (VC-1+ 5.1 PCM) The Perfect Storm (BluRay -> M2TS (VC-1 + 5.1 PCM) The only constant is VC-1 and PCM but I have muxed a lot of other VC-1/PCM BluRay/HD-DVD's w/o problems? I Googled and found a post over at SlySoft but the guy wound up re-installing all his A/V apps and I don't have time for that. Anybody know how to fix this or increase the AV buffer in tsMuxeR. I haven't tried running these through Scenarist yet but that's my next move...Anybody sm0k3 time |
18th September 2008, 00:46 | #2024 | Link | |||
I emailed Mosu, the mkvtoolnix maintainer, about adding TrueHD support: Quote:
18th September 2008, 03:58 | #2025 | Link |
Hello, when a ripped M2TS or TS, MKV file is opened in tsMuxeR (v1.4.8.b) I used to see the language of each track such as eng, spa, ger etc. but now it shows nothing against each track (all blank).
Can anyone please help me regain this capability? THANKS! |
19th September 2008, 23:20 | #2026 | Link |
Hi all, I wanna demux LPCM audio from one of the BD movies and I just found out that tsmuxer doesnt fully support the format.
When I try to demux it with tsmuxer I dont get track info in the status window, the process is taking way too long and after aborting I get an WAV file. What other tool would you guys recommend, maybe tsremux, although there isnt really an option for that and I get almost 100% cpu usage on my old 2 GHz Athlon XP when tsremux is running.? Cheers |
19th September 2008, 23:46 | #2027 | Link | |
20th September 2008, 09:47 | #2029 | Link |
Life's clearer in 4K UHD
How can that be? AAC audio is not a Blu-ray specified audio format!
20th September 2008, 10:33 | #2030 | Link | |
20th September 2008, 12:59 | #2031 | Link | |
Location: The Great North (the better half of North America)
I have yet to use the digital copy that comes with most BDs nowadays (no use for them), I'm only speculating that the problem is there and that is the audio format used. Does anybody know what audio format is packed with the digital copy? Let me rephrase: Is the digital copy on the actual BD or is it downloaded from another source with a code or something like that? |
20th September 2008, 13:50 | #2032 | Link |
@hdpete: I wanna mux it back in, this specific BD release has many audio tracks, I just wanna keep the LPCM audio.
There is a tool called Pcm2Tsmu, its a little utility to convert lpcm files to a format accepted by TsMuxer (lpcm data in blocks with little headers). |
20th September 2008, 18:32 | #2033 | Link |
Guys I need some help. Subtitles aren't showing up in my M2TS files while playing them back on a PS3. I always leave the subtitle check boxes checked whenever I convert an MKV, but the it seems the PS3 is not recognizing them when I hit the subtitle button or tab. What am I doing wrong?
20th September 2008, 19:16 | #2034 | Link | |
After know the 'title' (2 for instance), the 'track' (5 for instance), 'bitdepth' (16), 'channels' (8) and 'samplerate' (96000), the final sintax can be like: eac3to "your_folder_source" 2) 5: stdout.pcm | Pcm2Tsmu - output.pcm -i 16 -c 8 -s 96000 |
20th September 2008, 19:26 | #2035 | Link | |
20th September 2008, 23:45 | #2037 | Link |
Blu-Ray structure
21st September 2008, 00:15 | #2038 | Link | |
Yep bluray structure (AVCHD) The resolution of the movie must be 1920*1080 or 1280*720. If the resolution is not correct, you will get a greenbar on the screen |
23rd September 2008, 12:36 | #2039 | Link |
I've come across something strange, and i want to ask if somebody knows what's up ...
I've made a reencode/backup of a BD, and for expirimental reasons i've tried to remux the original DTS-MA. According to duppies expiriments it should work, but i get some strange results. I add my H264 file, and set framerate. After this i add the DTS-MA track, and set language. I alsso set the "split" -option to 4,35 GiB, and up to this moment averything works fine. Then i start muxing, first to M2TS because i need those 2 files to end up with 2 "BD5's. And that works fine too. But now the strange thing: When i cancel the operation, and for example end up with a 2 GB M2TS and make that into a BD5, the resulting BD5 plays fine after burning. But when I let the whole operation finish and make the complete 4,35 GiB BD5 & burn that, my player says "unsupported". So "partially finished" files work, really finished product doesnt And that only with DTS-MA files, all other audio-streams work .... I've come up with the idea that it might be that somehow only smaller M2TS-files with DTS-MA will work. So this evening i'll try and see if a BD5 with 2 * 2,175 GiB M2TS-files will work (hopefully the split-option on tsMuxeR works correctly on blu-ray; I've seen that it splits, and creates different M2TS in the STREAM-directory, but I havent tested it yet to see if it makes a working playlist). Any ideas / suggestions, or is it a error in the players firmware ? Last edited by G_M_C; 23rd September 2008 at 12:39. |
23rd September 2008, 14:20 | #2040 | Link |
meta file how to / Ubuntu/Linux how to
Please forgive me, but I do not have the time to go to the over 100 pages of this thread. Searching it did not bring up an answer to my question:
Is there a Linux how-to anywhere? I tried creating the meta file by myself, but now that I think I did everything right I just get a "VBV buffer overflow at position xxxx.xx" error at a rate of several hundred errors/sek. The resulting file (a mux of several .sup and .ac3 and one .264) has roughly the right size but will not play back in vlc... |
tsmuxer |
