Old 26th September 2024, 20:16   #10721  |  Link
Klaus1189
Updated german translation
Old 28th September 2024, 06:28   #10722  |  Link
Klaus1189
Old 28th September 2024, 07:06   #10723  |  Link
wushantao
Updated Simplified Chinese
https://files.catbox.moe/r4d6kj.7z
https://file.io/W5HFcFuw90BB
https://seyarabata.com/66f79cc3b9253
wushantao is offline   Reply With Quote
Old 28th September 2024, 07:17   #10724  |  Link
wushantao
Originally Posted by wushantao View Post
emmmmm,,, the original file was deleted by microsoft defender on my pc, and it told me that it was a trojan....but that it's just a txt text file compressed as 7z .......
Old 28th September 2024, 12:03   #10725  |  Link
cmhrky
Updated Turkish translation.
cmhrky is offline   Reply With Quote
Old 28th September 2024, 14:23   #10726  |  Link
v0lt
Thanks everyone. Translations have been updated.
@wushantao
You can also translate the installer.
sc.tsk_LongPathsEnable=Enable Windows 10 long paths support
v0lt is offline   Reply With Quote
Old 28th September 2024, 21:27   #10727  |  Link
s0meone_new
custom_messages.iss updated :
https://easyupload.io/z8hxqx
Hungarian translation updated:
https://easyupload.io/x33h88
s0meone_new is offline   Reply With Quote
Old 29th September 2024, 03:40   #10728  |  Link
wushantao
full custom_messages.iss
i also try to translate traditional chinese, this sentence is very simple, it should be fine
https://files.catbox.moe/hp0lm6.7z
https://seyarabata.com/66f8bd0fa4c7e
https://file.io/lnAzGGIiQyLS
Old 1st October 2024, 08:52   #10729  |  Link
v0lt
I think it's worth splitting the file "custom_messages.iss" into separate files for easier translation... Done.
Old 1st October 2024, 15:40   #10730  |  Link
jmatos72
Originally Posted by Aleksoid1978 View Post
Fixed.
jmatos72 is offline   Reply With Quote
Old 5th October 2024, 05:21   #10731  |  Link
v0lt
MPC Video Renderer 0.8.7.2295
Changes:
Cosmetic fixes to the settings window.
Statistics font size now scales according to Windows text scale.
Improved handling of switching the display to and from HDR mode.
Added the "Adjust the frame presentation time" setting. The feature without setting was added earlier in the 0.7.3 release for smooth viewing of interlaced video on high-frequency displays.
Fixed work with HDR modes when the "Automatically manage color for apps" option is enabled in Windows 11 24H2.
PS: MPC Video Renderer 0.8.7 is included in the MPC-BE 1.7.3.121 installer.
Old 6th October 2024, 05:58   #10732  |  Link
ryrynz
ryrynz's Avatar
Does anyone else find that using shift-F5 for Save Image (Auto) with MPC-VR doesn't save the same image as shown on the screen?
I'm finding I have to go to the next keyframe to get the previous keyframe's image. I've found this to be the case even when I tried it out a year ago.
Old 6th October 2024, 07:11   #10733  |  Link
v0lt
Switch "Swap effect" to "Discard".
Old 6th October 2024, 09:51   #10734  |  Link
ryrynz
ryrynz's Avatar
Thanks!
Old 6th October 2024, 18:45   #10735  |  Link
Goldbreaker
All builds crash with the new Windows Update 24h2! It takes ~10 videos to load than crash. Only the compatibility mode to Windows 8 helps... Please fix this.
Goldbreaker is offline   Reply With Quote
Old 6th October 2024, 18:54   #10736  |  Link
how about the crash report?
Old 6th October 2024, 19:54   #10737  |  Link
v0lt
Roll back broken Windows updates.
MPC-BE player works fine on my Windows 10 22H2.
Old 6th October 2024, 20:01   #10738  |  Link
Goldbreaker
What a great statement for programmers... I don't want a crash report from my porn videos on the Internet, thanks. Test it yourself, after a few files MPC-BE crashes with the latest Windows version... No matter what filter and setting...
Old 6th October 2024, 21:29   #10739  |  Link
Klaus1189
What filters do you use?
Such as external decoders, external video renderer, ...?
Does a crash report really contain source file info? And/or other personal info?
You can send a link of an uploaded crash to devs via pm. No need to make it public.
Also hardware info such as GPU and driver version is really useful for devs.
Old 6th October 2024, 22:13   #10740  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Not confirm.
Use Windows 11 24H2 - all is perfect.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Aleksoid1978 is offline   Reply With Quote
