Old 29th April 2011, 04:55   #2021  |  Link
SamuriHL
SamuriHL's Avatar
Yes, Andy, but on rented discs that's not a viable solution.
Old 29th April 2011, 05:10   #2022  |  Link
Andy o
Oh sorry I didn't mean you guys, I was answering to robpdotcom who was talking about mkvs:
Both work perfectly by setting Subtitle Selection Mode to "Only Forced Subs" and Blu-ray Subtitles to "Deliver only Forced Subtitles".
I can see though, how his will be tricky to select full subtitles in a pgs stream....
Should have used the quote button.
Andy o is offline   Reply With Quote
Old 29th April 2011, 05:28   #2023  |  Link
jmone
Subtitle Dropping Issues: Using D9 as the test disc. Start playback at Chapter 4 (time code 20:33) and the Subs work fine from here till 21:15, they should start again at 21.25 but don't appear. It always happens exactly at that point. I've tried multiple FFDSHOW builds (clid's Generic, clid's ICL10, XhmikosR's icl 12). Issue happens using both madVR and EVR so it is not the Video Renderer.
EDIT: Don't know why I did not test this early! If I leave LAVSplitter with "Full Subtitles", and "Only with matching language" / "Deliver only Forced Subtitles" unchecked then there is no issue with the subtitles dropping (of course I now get all subs not just forced subs). It looks like a bug in LAV reliably delivering just forced subs with FFDSHOW.
jmone is offline   Reply With Quote
Old 29th April 2011, 06:09   #2024  |  Link
jmone
Thats nothing a decoder would do. Thats all the renderers doing, and ReClock is the only reliable WASAPI (=exclusive) renderer i know.
But even when using WASAPI, it doesn't magically switch output configurations - ReClock has an option to do this for you ("Set matching speaker configuration")
FYI - MC16 support WASAPI and WASAPI Event Style with options for:
- Exclusive Mode
- Flush devise buffers (start up and on pause)
- Present 24-Bit data in 32 Bit package
Also enables the use of their DSP including stuff like:
- Output Format (resampling/bitdepth, channel mixing etc)
- EQ
- Video Sync (keep audio in sync with the video by resampling) - thanks to madshi for helping out on this one!
- Room Correction
- other stuff!
The only downside is it only works in MC16 (it is not a seperate DirectShow filter).
Old 29th April 2011, 06:48   #2025  |  Link
nevcairiel
Originally Posted by SamuriHL View Post
Sigh. This isn't a good situation for us. I wish we could have the sub rendering code from mpc in mc16.
How about DirectVobSub? It should be the same renderer as MPC-HCs, except that it applys it onto the decoded image, not the rendered image. At least with Blu-rays, that are 1080p from the start, you don't get scaling issues - just chroma upsampling issues. Nothing that ffdshow wouldn't also suffer from.
And what the hell, while i'm sleeping you guys produce 2+ pages of comments.
Anyhow, i have alot of discs myself, including Salt, D9 and several others.
From the list in that AVS thread, forced subs inside the normal track are far more common, it seems. I do however have some discs that also have separate tracks for the subs (I don't remember exactly, but i watched one just 2 weeks ago or so - The Expendables it might have been)
The filtering code is pretty dumb right now, i only tested on that one disc - which worked fine. But i can imagine situations where it would cause some issues - not sure if those actually exist in real-life though.
What the filtering does is produce "holes" in the sub stream, usually they seem to be numbered sequentally, now some are missing - maybe ffdshow can't deal.
@MakeMKV:
Flagging the tracks as forced is not important in this scenario. I would however be surprised if it modifys the flags in the PGS frames, just because simply copying is so much easier then rewriting them - so it should preserve those flags.
Old 29th April 2011, 07:34   #2026  |  Link
jmone
Unless I've missed something, it does not have PGS supports which makes it kinda pointless these days. The benefit of FFDSHOW is they added PGS support at the end of last year.
Imagine what would happen if you slept in!
EDIT: That is exactly what it feels like from my end. The FORCED subs stop displaying once a "normal" sub has been supressed.
Old 29th April 2011, 07:42   #2027  |  Link
jmone
As an idea - instead of producing holes, could you present blanks instead?
Old 29th April 2011, 08:21   #2028  |  Link
nevcairiel
It uses the same logic to render subs as the MPC-HC internal renderer - it just looks like there is a missing media type for the DirectVobSub subtitle pin - i'll test later and possibly add it.
The only "problem" is that it doesn't support NV12, only YV12 - so you wouldn't be able to use it with LAV CUVID, unless i manage to add support for that too.
(Edit: Adding NV12 support to DirectVobSub seems hard, would probably be easier to add YV12 output to LAV CUVID.....)
I'm also pondering if it would be possible to write a sub renderer using the MPC-HC rendering code which would hook into the sub rendering interface of madVR, basically how MPC-HC works, just as a standalone filter.
It would however be limited to madVR (and the Haali renderer).
Maybe, maybe not. I don't know that much about the PGS format itself..
I'll test with ffdshow when i get home from work.
Maybe its an easy fix in ffdshow sub rendering code...
Old 29th April 2011, 08:42   #2029  |  Link
Andy o
Sigh, good news and bad news. Good news, the Tourist works fine, just like Paprika did. Bad news, I spent my free rental on The Tourist.
Old 29th April 2011, 09:00   #2030  |  Link
nevcairiel
From what i gathered from the last two pages - the subtitle filtering works fine in principal, as long as you use the MPC-HC renderer, right? Any discs (or mkvs) it failed on? (ignoring ffdshow issues for now)
Old 29th April 2011, 09:20   #2031  |  Link
Andy o
I'm using the MPC renderer, yes. The only available titles I have right now with forced subs are those two, Paprika and The Tourist. I think we can add Avatar and District 9 to the list of working titles too.
Old 29th April 2011, 09:28   #2032  |  Link
Nexin
@nevcairiel Some Praise and idea for inclusion into ffdshow asap and keep in sync with versions <>
Thanks to you both for the development and updating of LAVSplitter. Moreover making LAVSplitter available for us all to use
Nexin is offline   Reply With Quote
Old 29th April 2011, 09:30   #2033  |  Link
nevcairiel
I don't think thats a good idea. ffdshow is a decoder, adding a splitter in there is weird .. (also, i have my own Audio Decoder, which would conflict with ffdshow - and i rather distribute both)
Additionally, i do not care for the extra work keeping it in sync.
Then there is the whole ffmpeg version issue...
Just install both packages, i don't think thats too much to ask.
Old 29th April 2011, 09:50   #2034  |  Link
jmone
All good ideas, and I would plug for the following, but given your time is precious, I'd also put them in this order:
1) Mod LAVSplitter to output a (forced) SUB stream that is compatible with a wide range of decoders as possible (incl FFDSHOW) OR if it already does then it is a bug in FFDSHOW that needs to be fixed
2) Mod DirectVobSub to support pgs
3) Write a new Sub Renderer (happy that it would only support madVR but that means you could not use it with DVD's at present).
OR - since it is a rendering role, and Madshi has been kicking back recently get him to build it into madVR
Old 29th April 2011, 09:53   #2035  |  Link
nevcairiel
I'll try to fix it in LAV Splitter, maybe there is something simple to be done.
Maybe i can output dummy, blank packages .. or adjust the id in the packages .. i'll look into it.
That'll be easy. In addition i'll add YV12 output to LAV CUVID so those two can be used together.
I don't think i'll be doing this, its a whole new world of pain.. and, no practical use for me, i use MPC-HC.
Old 29th April 2011, 10:30   #2036  |  Link
jmone
Sounds good to me for 1 and if that fails 2 + I agree on your comments for 3 (unless an earlier hint of LAVVideo was true in which case.....) Anyway, Filters are like bad habits, I'm always trying to cut down the number I have!
Old 29th April 2011, 10:31   #2037  |  Link
nevcairiel
There will be a LAV Video, but it won't do subtitles.
Old 29th April 2011, 10:38   #2038  |  Link
madshi
Who's Madshi? What's madVR? Huh? What are you talking about?
Old 29th April 2011, 10:41   #2039  |  Link
fastplayer
...and so the circle is complete.
fastplayer is offline   Reply With Quote
Old 29th April 2011, 11:09   #2040  |  Link
joeydrunk
So mochc dies.allow.the flags through than. What exactly are you saying about this particular situation? When using makemkv we just have to make sure and always check the forced sub box if we want to be able to watch forced only and regular subs separately?
Originally Posted by robpdotcom View Post
Just tested this with two mkv's: The Tourist, with which I did not extract a separate, forced sub stream (so, the forced subs are embedded in the normal subs stream); and Avatar which I had previously ripped by extracting the extra forced stream (flagged as forced by mmg).....
Would it be possible for LAVSplitter to create a virtual "forced" track, which will load automatically, then you can then select the full subs, for example, via Right Click > Navigate, or even by the player's "next subtitle" keyboard shortcut ("S" in MPC-HC)?
joeydrunk is offline   Reply With Quote
