22nd February 2017, 23:58 | #21562 | Link |
Hello!
DXVA2(copy-back) slowdown/''skips'' with HEVC.Other non HEVC sources play smoothly. DXVA(native) plays smoothly too HEVC with EVR. Any solutions for DXVA2(copy-back)? lav 0.69 GPU:RX 470(amd) with latest drivers. Last edited by Damien147; 23rd February 2017 at 00:37. |
23rd February 2017, 07:30 | #21563 | Link |
Copy-Back has historically not been that great on AMD, so either it works or it doesn't, can't really change anything either way.
Especially when handling 4K 10-bit content you need a lot of memory bandwidth just to download and upload the image again, which AMD cards don't seem to like doing very much.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd February 2017 at 07:32. |
23rd February 2017, 08:35 | #21564 | Link |
Did you see my report? https://forum.doom9.org/showthread.p...95#post1798395
I am not sure what is going on, but HEVC 4K 10bit works fine with madVR for me (AMD RX460 4GB) if I disable P010 and P016 output in LAV. CPU load decreases from over 70% to ~35% without P0 output. Last edited by nussman; 23rd February 2017 at 08:38. |
23rd February 2017, 09:02 | #21565 | Link |
All that would do is lower the memory bandwidth requirement on uploading the images back to the GPU, which I suppose can already help. LAV performance is not really different between NV12 or P010 output, both are similar in efficiency. If anything P010 should be slightly more efficient since its the native GPU format and doesn't require dithering. But its double in size so maybe that balances out.
Make sure LAV is using direct mode (ie. decoder is "dxva2cb direct"), but if its using P010 or NV12 output there rarely is a reason why it wouldn't use direct mode. Of course it goes without saying to avoid any software post-processing filter like ffdshow or others, as those will eat your performance on 10-bit content.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 23rd February 2017 at 09:14. |
23rd February 2017, 09:32 | #21567 | Link |
EVR doesn't accept P010, so it would use NV12 then.
23rd February 2017, 10:56 | #21568 | Link | ||
23rd February 2017, 10:58 | #21569 | Link | |
23rd February 2017, 12:31 | #21572 | Link | |
The performance looks like the same of DXVA native, but of course I can see spikes of 100% GPU utilization and full clock speed for core/ memory (1300MHz/ 2000MHz)
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
23rd February 2017, 14:33 | #21574 | Link |
On Win10 - EVR/EVR Custom accept P010. Checked on Nvidia 960/AMD RX460.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /Patriot 32Gb@3200 /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
23rd February 2017, 15:38 | #21575 | Link | ||
We are saying the same thing. Quote:
Can you tell which driver version you are using?I'm gonna try that.I am with 17.2.1 WHQL that came out yesterday and I can't get smooth playback with 10 bit 4K HEVC and dxva2(copy-back).Picture slows down,framerate drops. p.s. Γεια σου Ελλαδάρα!! Last edited by Damien147; 23rd February 2017 at 15:49. |
23rd February 2017, 15:59 | #21576 | Link |
17.2.1 beta, I think there are no differences with WHQL.
I don't think that really matters but my RX 470 as I've already posted has 2000MHz GDDR5 memory and 1300MHz GPU clock. Win 10 x64 of course. Try to use the clean install of AMD drivers which uninstalls previous drivers and not DDU. But it seems as an issue of your system. P.S Δεν νομίζω να καταλαβαίνει κανένας τι γράφουμε στα Ελληνικά και υπάρχει κανόνας να γράφουμε Αγγλικά εδώ, αλλά δεν άντεξα την πρόκληση
23rd February 2017, 16:01 | #21577 | Link | ||
Though definitely some of those things that will only work with Windows 10 EVR Render Backend and you need other ways (APIs) todo it pre Windows 10 with acceleration though of course you never gonna get it to work under DWM windowed so in a browser and HTML5 you gonna fail completely with 10 Bit support under Pre Windows 10 when using the Native Microsoft APIs. Quote:
Also because the overhead of AMDs Driver is overall higher it can make a difference which advanced CPU you have and which instructions AMD makes use of We should see further improvements overall here due to the tuning for Zen which is partly also gonna effect the Intel overall Performance due to the similiar nature of both compared to the old Athlons and Bulldozer
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd February 2017 at 16:30. |
23rd February 2017, 16:26 | #21578 | Link |
Perhaps it is a DPC latency issue?
http://www.resplendence.com/latencymon |
23rd February 2017, 16:30 | #21579 | Link | ||
Was with 17.2.1 beta too and the problem was there.Don't update to WHQL if you want,it's the same thing. About clean install I've tried that and THEN I tried DDU to see if there is a problem.Nothing changes.I have lower clocks but yes you are right.It seems that it is my system and not in general. P.S. Σιγά,ένα γειά ανταλλάξαμε.Καλή συνέχεια. Quote:
23rd February 2017, 16:35 | #21580 | Link | |
But yeah if you think about a SOC at 7W is completely destroying it overall but only with Zero Copy with Copy Back most Socs would die also for 4K Hevc.
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 23rd February 2017 at 16:41. |
