26th June 2006, 17:23 | #262 | Link |
Feature Request:
1. Right Click menu for text boxes on the command editor 2. option to have virtual remote controls on preview window 3. some while back, i had requested the ability to use Enter key on the command editor to do the same as hitting the OK button it was implemented but it isnt implemented now was it taken out purposely? |
26th June 2006, 22:29 | #263 | Link |
Senior Member
The version number is in the file name if you download from r0lz's version section on his site:
http://www.videohelp.com/~r0lZ/pgcedit/versions/ |
26th June 2006, 22:45 | #264 | Link |
Country Member
I'd be against version numbers in file names, too. I would think that most people just "install over" the old version and this is very convenient. And yes, you can always get access to the old versions on the server.
Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
26th June 2006, 23:01 | #265 | Link | |||
PgcEdit daemon
BTW, in almost all numeric fields, it is also possible to enter an hex number (0xFF), and even an octal number (077). Quote:
r0lZ PgcEdit homepage (hosted by VideoHelp) BD3D2MK3D A tool to convert 3D blu-rays to SBS, T&B or FS MKV Last edited by r0lZ; 26th June 2006 at 23:07. |
26th June 2006, 23:05 | #266 | Link |
PgcEdit daemon
Indeed, it is possible to download an archive (including the current release) with the version number in the filename from the "all versions" folder.
26th June 2006, 23:29 | #267 | Link | |
27th June 2006, 01:17 | #268 | Link | |
JuSt a PoWer uSEr
27th June 2006, 06:30 | #269 | Link |
To r0lZ.
May I ask you? I understand, that is a very big work, but it is a very good and necessary possibility (now I forced to use a DVDRemake for this. Stupid program). May be in future... Did you make a more powerful editor for add (before/after current) and delete any dummy PGC's, not for last only? Thanks. |
27th June 2006, 10:55 | #270 | Link |
PgcEdit daemon
Well, inserting, deleting or moving a PGC at any place is easy to do.
The difficult part is to fix the navigation commands. That's not as easy as it sounds. For example, when a PGC is deleted, what should I do with the commands pointing to it? Also, the advantage is not obvious. It is already possible to create a PGC. It doesn't need to be at a specific position to be used. Anyway, it's something I would like to do. It's on my ToDo list for a while... but there is always something more important to do first.
27th June 2006, 11:45 | #271 | Link |
Country Member
I find the unused dummies in the middle of a domain to be just a little irritant. But they do no harm and take up little space. Why bother?
Advanced error checking is my major wish list item, as you know r0lZ Regards
27th June 2006, 12:37 | #272 | Link | ||
BTW, a DVD Remake fix it automatically. And that feature is impossible to off in DVD Remake. After this, a jump, call and other links (frequently) pointing to a PGC with zero number!!! Please leave this fix to user. May be include that as menu item in expert mode? Default is off (nothing differences with current mode). Who need it - switch on, like automatically fix goto links within one PGC now. PS. I agree with blutach. I don't like a DVD with trash PGC. Do you remember a last ifo's, which I sent to you? Near 140 PGC in one VTS!!! I will never believe, that all of it used in DVD. Edited: Once more idea: may be make that feature as a plugin? Last edited by President; 27th June 2006 at 12:48. |
27th June 2006, 15:57 | #273 | Link | |
PgcEdit daemon
But maybe I'll do a basic function to delete or move a PGC without fixing the navigation. As a plugin, yes, it's a good idea. But don't expect it soon. It's the summer, and I am currently in lazy mode!
27th June 2006, 16:54 | #274 | Link | |
Interstellar Traveler
29th June 2006, 05:48 | #275 | Link | |
I will be wait you at September, 1:-))). Last edited by President; 29th June 2006 at 06:01. |
29th June 2006, 07:32 | #276 | Link |
Spielberger
In according to this post I made a DVD to check SPRM7 in case of multi-pgc titles.
It seems that there are players with troubles if there is a JumpVTS_PTT command greater than 255 so it is checked too. jump to PTT>255 should show colorbars for a few seconds and then a table jump to PTT>255 successful read sprm7 from player should show colorbars for a few seconds and then a table with the result SPRM7=0 or SPRM7=1 or SPRM7=258 or SPRM7=other some results WinDVD, PowerDVD, Nero Showtime -> 258 Marks Tray Player, Sonic Preplay, Ravisent Cinemaster, Scenarist Simulation -> 1 Cyberhome 505, Pioneer DV-444, Pioneer DV-668 -> 1 Muvid DVD-205, Easy ET 602, S.E.G. Hollywood 2 -> 258 NAD T524, Panasonic DMR E 100 H, Cyberhome CH-DVD-402 -> other Download Test-DVD Last edited by bigotti5; 29th June 2006 at 07:34. |
29th June 2006, 10:42 | #277 | Link |
PgcEdit daemon
See also this thread, with the results of the SPRM 7 test I did in the past.
You can download my SPRM 7 test DVD on the PgcEdit homepage: TEST_SPRM_7_PAL.zip, TEST_SPRM_7_NTSC.zip.
30th June 2006, 15:06 | #278 | Link |
7.* bug?
Hi r0lZ,
I was trying to send you email, but got no reply. First of all - thanks a lot for such a great tool, I'm still new to it, but the more I use it - more I like it I think I found a bug - I was going after http://forum.digital-digest.com/show...07&postcount=1 and I can do #1-4, but #5 is all gray. I downloaded older version 6.3.1 and it works just fine. It looks like this was broken in release 7 - I tried another build (7.1.2 I think) - no luck also... If needed - I can email you IFO files, but it's not working for at least 3 DVDs, so I guess it has nothing to do with files... Thanks a lot and hope this helps... |
30th June 2006, 19:41 | #279 | Link | |
Spielberger
If you wanna change it click "Domain - Domain stream attributes" from main menu bar @r0lZ To the validity of SPRM_7 I found this in US Patent 6370322 Last edited by bigotti5; 30th June 2006 at 19:58. |
1st July 2006, 02:30 | #280 | Link |
Country Member
@senditthere - I am afraid you can blame me for asking for this enhancement from r0lZ. I was finding it strange to change 1 PGC when the attributes were for the whole domain. But now, it is very easy to remove from all PGCs as bigotti mentioned.
If you have removed a stream from 1 PGC but left it in others in the same domain, then this enhancement prevents you from taking it out of the PGC (where it does no harm to sit as a placeholder - except that you need to click the remote a bit more to cycle through the streams). Regards
