Old 22nd February 2022, 12:34   #41  |  Link
real.finder
Originally Posted by Ceppo View Post
thr60i in CTelecineNew and thr2 in CPostProcessing must have the same value. Try this way.
If still does that, tomorrow I will look into it (same clip I guess). Also, you are supposed to bob after CTelecineNew.
I did make thr60i in CTelecineNew and thr2 in CPostProcessing same and it still got problems
the output of CTelecineNew is already 60fps! I think it wrong to do bob with it! but anyway that seems work but the output of bob seems not ok (to many ghosting)
Last version of mkvtoolnix doesn't accept that.
weird, I don't use last mkvtoolnix but it always "# timecode format v1" and all old tools and plugins only work with "# timecode format v1" even the last x264!
See My Avisynth Stuff
Old 22nd February 2022, 18:36   #42  |  Link
Ceppo
Could you please tell me how to input the vfr file with x264. I never done vfr before you asked for it so I don't know much. Since your suggestion seems more compatible I might change it.
We can do like that: if isBob false, expect double frame rate, if isBob true expect same frame rate, so you can use the bob from the original clip. Does this seems acceptable?
Ceppo is offline   Reply With Quote
Old 22nd February 2022, 18:58   #43  |  Link
real.finder
x264 has --tcfile-in for vfr timecode file
so this ok?
i=last
bob=stgmc(useEdiExt=2,EdiExt=sanimebob(useBWDIF=true, FastNnediHBD=true),Sharpness=0,tr2=2,ESearchP=true, Refinemotion=true, fastma=true)
#~ CTelecineNew(bob=true,write=true,thr60i=0.1)
CTelecineNew(bob=false,thr60i=0.1,inputTxt=true)
CPostProcessing(0.1,0.9,isbob=false,edeint=i.CPostProcessingMask(bob=bob,nt=4),edeint2=bob)
CDecimateNew(isBob=false,error=false)
it seems work
edit: and yes it should not act like this for isbob=true, I think for isbob=true case it should "if isBob true expect same frame rate" as you said
Old 22nd February 2022, 21:28   #44  |  Link
Ceppo
Updated:
v1.0.6
- Fixed wrong frame count on CDecimateNew
- Now CPP expect same frame rate edeint/2 clip when isBob=true.
I didn't do much* testing, I have something going on.
Also you don't need to specify edeint with CCPMask with the same bob clip. It's automatic.
i=last
If Bob false, thr60i is ignored.
Old 22nd February 2022, 22:15   #45  |  Link
real.finder
thanks, work fine, but the timecode file still "# timestamp format v1"
anyway I will test more with some DVD later
Old 22nd February 2022, 22:24   #46  |  Link
Ceppo
I forgot, sorry. Tomorrow I will add it with a new parameter for CDecimateNew.
Old 22nd February 2022, 23:08   #47  |  Link
real.finder
one more thing, and it's about CTelecineNew
in CTelecineNew(bob=true) sometimes it show frame that not same as qtgmc and that makes some artifacts
also instead of just vinverse.dll can we have option to choose alternatives like https://github.com/Dogway/Avisynth-S...GMC.avsi#L1273 ?
Old 22nd February 2022, 23:16   #48  |  Link
Ceppo
It does field matching. So 1 field might be dropped for the adiacent while QTGMC does not. And can you give me a picture of those artefacts? QTGMC VS CTelecine VS Original
EDIT: what I said makes no sense. Might be a bug. If you could provide a sample clip that does that and point out some frame.
It depends by the filter. If it does not blending, it won't work. I'm not feeling well atm, can you give me a comparison of a telecined frame with vinverse vs your vinverse?
Old 22nd February 2022, 23:37   #49  |  Link
real.finder
I know it do field matching, I didn't mean CTelecine did it but when using it like this
bob=stgmc(tr0=-2,useEdiExt=1,EdiExt=sanimebob(useBWDIF=true, FastNnediHBD=true),Sharpness=0,tr2=5, Refinemotion=true, fastma=true)
#~ CTelecineNew(bob=true,write=true,thr60i=0.2)
CTelecineNew(bob=true,thr60i=0.2,inputTxt=true)
CPostProcessing(0.1,0.9,isbob=true,edeint2=bob)
CDecimateNew(isBob=true,error=false)
look at the Teeth
tfm kinda do same sometimes, but it's ok with
istff=GetParity()
bobclip=qtgmc
Interleave(TFM(field=istff ? 1 : 0, micmatching=0, mode=0, clip2=bobclip.selecteven()), TFM(field=istff ? 0 : 1, micmatching=0, mode=0, clip2=bobclip.selectodd()))
vinverse originally was a script function by Didée then tritical make it a plugin, but now the dll version is outdated in case of HBD and some other improvements so there are Vinverse_avsi and ex_vinverse since the dll didn't get any updated since 10 years, that why I asked about option to choose alternatives
Old 22nd February 2022, 23:43   #50  |  Link
Ceppo
I don't have your bob filter to check. Try without using CPostProcessingMask as edeint clip. It might be it failing with your bob filter.
About vinverse, ok. There is a problem, I can't load the page anymore.
Old 22nd February 2022, 23:46   #51  |  Link
real.finder
I don't have your bob filter to check. Try without using CPostProcessingMask as edeint clip. It might be it failing.
I already don't use CPostProcessingMask now
any bob can be a problem, you can use just
bob=qtgmc
and what page? this ?
Old 22nd February 2022, 23:50   #52  |  Link
Ceppo
With
bob = QTGMC()
CTelecineNew(nt=2,bob=true,thr60i=0.2,inputTxt=true)
I don't see any problem aside QTGMC ghosting.
If you don't specify an edeint clip, is default.
Old 22nd February 2022, 23:57   #53  |  Link
real.finder
With
bob = QTGMC()
ok, so QTGMC was not a good replacment, bob=TDeint(1) should do it
Old 22nd February 2022, 23:59   #54  |  Link
Ceppo
About CTelecineNew getting the wrong frame, can you point a frame number from that clip?
EDIT:
I don't have TDeint
EDIT2:
I think there is a misunderstanding here.
If you asked me to use TDeint, then what you should do is to check:
CPostProcessing(0.1,0.9,isbob=true,edeint=bob,edeint2=bob)
and see if it still does it.
Old 23rd February 2022, 00:17   #55  |  Link
real.finder
you mean the image above? 1444
if you mean CTelecineNew(bob=true) vs bob then it's seems fine with any bob now! maybe I did something wrong in the first time
Old 23rd February 2022, 00:20   #56  |  Link
Ceppo
I'm glad it works now. Tomorrow I will add ex_vinverse() as a mode.
EDIT:
I also need to rewrite the old modes and make a single CTelecine function and CDecimate function. For now, I will wait some days for bugs reports. Then I will get to it. I will also add old comb detection methods to CPostProcessing for everyone's tastes. And I will add yet another field matching mode.
Old 23rd February 2022, 00:27   #57  |  Link
real.finder
EDIT:
I don't have TDeint
EDIT2:
yes that what was missing, thanks
bob1=CTelecineNew(bob=true)
bob2=stgmc(useEdiExt=2,EdiExt=sanimebob(useBWDIF=true, FastNnediHBD=true),Sharpness=0,tr2=2,ESearchP=true, Refinemotion=true, fastma=true)
CPostProcessing(0.1,0.9,isbob=true,edeint=bob1,edeint2=bob2)
Old 23rd February 2022, 00:38   #58  |  Link
Ceppo
Just wondering, you guys prefer 2 dlls, one with IVTC stuff and one with CDuplicate stuff or is fine a single one?
Old 23rd February 2022, 01:21   #59  |  Link
kedautinh12
Tdeint here:
https://github.com/pinterf/TIVTC/releases
Old 23rd February 2022, 01:58   #60  |  Link
real.finder
I don't mind either case
I did vfr test with dvd, seems ok in everything for now but I note that the 60i detected not work good with some sources even with thr60i=0.1 here small sample https://www.sendspace.com/file/96xnbn
