11th June 2021, 08:08 | #41 | Link | |
So for this mode you noticed a speed increase? There was a fix indeed, but I couldn't tell the magnitude of this change, did not perform a before-after test. |
11th June 2021, 18:36 | #43 | Link |
SMDegrain 3.2.0d final is released. I had changed DCT to 5 by reading the changelog only, now I run some benchs and indeed, no speed gain so reverted. Also optimized ex_luma_rebuild() and some overall cleanup. In the future I want to add some frequency restoration system, this is something that I also looked into 6 years ago.
OLD DCT = 0 7.600fps OLD DCT = 5 6.300fps NEW DCT = 5 6.300fps NEW DCT = 0 7.700fps @pinterf, I was confused about bitdepth handling with motion vectors, is the next valid code or do I need MScaleVect()? Code:
super_search = MSuper(rfilter=2) bv3 = super_search.MAnalyse(isb = true, delta = 3, overlap= 4) bv2 = super_search.MAnalyse(isb = true, delta = 2, overlap= 4) bv1 = super_search.MAnalyse(isb = true, delta = 1, overlap= 4) fv1 = super_search.MAnalyse(isb = false, delta = 1, overlap= 4) fv2 = super_search.MAnalyse(isb = false, delta = 2, overlap= 4) fv3 = super_search.MAnalyse(isb = false, delta = 3, overlap= 4) convertbits(16) MDegrain3(MSuper(levels=1), bv1, fv1, bv2, fv2 ,bv3, fv3, thSAD=300, thSADC=150)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
11th June 2021, 19:43 | #44 | Link |
dct>0 can be quicker indeed, except for 8x8 block sizes at 8 bit videos. Other than that special format (which is computed by integer dct code) the others are using fftw3, which remained unchanged but the epilog code got a fix in the SSE2 code.
11th June 2021, 19:55 | #45 | Link | |
The super clip provided to MDegrain must be originated from the same format as the video to denoise. It can even be a 4:4:4 32 bit float as well, while the vectors can be computed from a plain 8 bit YV12. I still do not understand what is luma_rebuild for. "makes up for an extra 16% precision". If this extra range would help with anything then using a 16 bit clip for motion vector search would yield an extra 25600% precision increase. In real life: when you compare the vectors from a 8 bit clip or its ConvertBits(16) counterpart, there will be basically no difference. What I can imagine that you stretch the Y range and thus it will have a relatively larger weight when chroma is involved. Btw. you can adjust luma/chroma weights in SAD search with MAnalyze "scaleCSAD" parameter which fine tunes chroma SAD weight relative to luma SAD. |
11th June 2021, 20:53 | #46 | Link |
Bitdepth has more precision, but is not feature bound. Take for example the "opposite" of a TV->PC conversion, a source in log space (or a very low contrast processed source), the SAD will be misleading even in float precision because it doesn't represent human vision.
luma_rebuild() also has a brightening option for the dark areas for the same reason. Human vision is very adaptive to dark (more so in dim/dark surround) so it makes sense to brighten this up to give it more SAD weight and avoid smearing. If this wasn't true we would just try to find motion vectors in linear light and not gamma encoded sources. I'm using scaleCSAD (MAnalyze), but only for chroma subsampling as written in the docs. Does it have an effect on thSADC of MDegrain? Meaning are they mutually exclusive?
11th June 2021, 21:52 | #48 | Link | |
Acid fr0g
I am looking at your html file, that perhaps you have not updated yet looking at the changelog, and I can see the lsb_in and lsb_out parameters. Weren't they the parameters used when AVS did not support HBD? Let's have some example:
Thanks in advance.
@turment on Telegram Last edited by tormento; 11th June 2021 at 21:55. |
11th June 2021, 22:13 | #49 | Link |
The documentation hasn't been updated, not even real.finder updated it so it is very old by current terms. I will update when I finish Transforms Pack which will be very soon.
My updated SMDegrain tries to be as simple as possible so I removed redundant arguments like HBD in/out and things like that. For example 2 precede it with ConvertBits(bits), others need nothing.
12th June 2021, 08:27 | #50 | Link | |
Pig on the wing
12th June 2021, 10:04 | #51 | Link |
I don't remember what was the default before my recent edits but I usually try to leave defaults in "safe" settings otherwise people may complain too much, but if there's a consensus I can set it to 2.0, it's still safe (I've gone to 6.0 on a recent project). s0=1.0 by default just converts to PC levels so it appears darker when seen on TV levels preview (ie. AvsPmod)
16th June 2021, 23:51 | #52 | Link |
Acid fr0g
I just updated to 1.7 version and I get:
Script error: Invalid arguments to function 'ex_Yexpr'. (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.2.0d~Dogway.avsi, line 618) (D:/Programmi/Media/AviSynth+/plugins64/SMDegrain-3.2.0d~Dogway.avsi, line 161) (F:\In\1_30 Febbre da cavallo\febbre_4.avs, line 20) (F:\In\1_30 Febbre da cavallo\febbre_4_temp\febbre_4_source.avs, line 1) My script is simple: SetMemoryMax() SetFilterMTMode("DEFAULT_MT_MODE", 2) LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll") DGSource("F:\In\1_30 Febbre da cavallo\febbre.dgi",ct=24,cb=24,cl=0,cr=0) ConvertBits(16) SMDegrain (tr=4, thSAD=400, refinemotion=true, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Prefetch(6) 1.6 is working fine, SMDegrain is the last one.
@turment on Telegram Last edited by tormento; 17th June 2021 at 00:04. |
17th June 2021, 00:51 | #53 | Link |
Yes, ExTools is a bit developed ahead as I'm making time to solve this issue and rebase the other filters.
For the moment use v1.6. I think I will doing other things until the issue which is critical is solved.
17th June 2021, 17:42 | #57 | Link |
it's still needed for https://github.com/Dogway/Avisynth-S....2.0d.avsi#L39
edit: and also https://github.com/Dogway/Avisynth-S...2.0d.avsi#L145 also there are bug that case error in this line https://github.com/Dogway/Avisynth-S...2.0d.avsi#L170 with subpixel=3 that fixed in https://github.com/Dogway/Avisynth-Scripts/pull/11
See My Avisynth Stuff Last edited by real.finder; 18th June 2021 at 01:50. |
17th June 2021, 22:38 | #58 | Link | |
18th June 2021, 01:50 | #59 | Link |
See My Avisynth Stuff |
18th June 2021, 16:59 | #60 | Link |
Acid fr0g
Tried pure speed comparison between SMDegrain and NotSMDegrain on an old movie. Latest versions of AviSynth+, AVSI and dll filters.
Script for SMDegrain SetMemoryMax() SetFilterMTMode("DEFAULT_MT_MODE", 2) LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll") DGSource("F:\In\1_30 Febbre da cavallo\febbre.dgi",ct=24,cb=24,cl=0,cr=0) ConvertBits(16) SMDegrain (tr=6, thSAD=600, refinemotion=true, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Prefetch(6) Script for NotSMDegrain SetMemoryMax() SetFilterMTMode("DEFAULT_MT_MODE", 2) LoadPlugin("D:\Eseguibili\Media\DGDecNV\DGDecodeNV.dll") DGSource("F:\In\1_30 Febbre da cavallo\febbre.dgi",ct=24,cb=24,cl=0,cr=0) NotSMDegrain (tr=6, thSAD=600, refinemotion=true, n16_out=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Prefetch(6) SMDegrain (tr=6, thSAD=600, refinemotion=true, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) AVSMeter 3.0.8.0 (x64), (c) Groucho2004, 2012-2021 AviSynth+ 3.7.1 (r3413, master, x86_64) (3.7.1.0) Number of frames: 2712 Length (hh:mm:ss.ms): 00:01:48.480 Frame width: 1920 Frame height: 1032 Framerate: 25.000 (25/1) Colorspace: YUV420P16 Frames processed: 2712 (0 - 2711) FPS (min | max | average): 0.918 | 959.8 | 5.764 Process memory usage (max): 2162 MiB Thread count: 75 CPU usage (average): 72.4% Time (elapsed): 00:07:50.498 NotSMDegrain (tr=6, thSAD=600, refinemotion=true, n16_out=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Frames processed: 2712 (0 - 2711) FPS (min | max | average): 0.956 | 125000 | 6.124 Process memory usage (max): 1961 MiB Thread count: 76 CPU usage (average): 73.0% Time (elapsed): 00:07:22.854 SMDegrain (tr=7, thSAD=700, refinemotion=true, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Frames processed: 2712 (0 - 2711) FPS (min | max | average): 0.788 | 1055 | 4.498 Process memory usage (max): 2020 MiB Thread count: 75 CPU usage (average): 73.2% NotSMDegrain (tr=7, thSAD=700, refinemotion=true, n16_out=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Frames processed: 2712 (0 - 2711) FPS (min | max | average): 0.477 | 243903 | 5.029 Process memory usage (max): 1783 MiB Thread count: 74 CPU usage (average): 72.5% SMDegrain (tr=9, thSAD=900, refinemotion=true, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Frames processed: 2712 (0 - 2711) FPS (min | max | average): 0.683 | 714286 | 3.412 Process memory usage (max): 2278 MiB Thread count: 75 CPU usage (average): 73.1% NotSMDegrain (tr=9, thSAD=900, refinemotion=true, n16_out=true, mode=0, contrasharp=false, PreFilter=4, truemotion=true, plane=4, chroma=true) Frames processed: 2712 (0 - 2711) FPS (min | max | average): 0.835 | 625000 | 3.909 Process memory usage (max): 1964 MiB Thread count: 75 CPU usage (average): 72.7%
@turment on Telegram Last edited by tormento; 18th June 2021 at 17:03. |
avisynth, dogway, filters, hbd, packs |
