17th February 2023, 00:25 | #121 | Link | |
What fixed it was: https://www.microsoft.com/en-us/down...ils.aspx?id=35 Last edited by OrangeColaJuice; 17th February 2023 at 00:28. Reason: fixed the issue |
17th February 2023, 03:43 | #122 | Link | |
Formally known as .......
17th February 2023, 04:21 | #124 | Link |
avisynth shader here:
https://github.com/mysteryx93/AviSynthShader/releases |
17th February 2023, 04:39 | #125 | Link |
@ kedautinh12 & pdr,
Thanks guys, it's a goer. Code:
#Custom SetCacheMode(1) SetMemoryMax(16384) LoadPlugin("%AVISYNTHPLUGINS%\PD_TOOLS\AviSynthShader\Shader-x64.dll") Import("%AVISYNTHPLUGINS%\PD_TOOLS\AviSynthShader\Shader.avs") Import("%AVISYNTHPLUGINS%\PD_TOOLS\AviSynthAiUpscale\AiUpscale.avs") video=ConvertBits(video,16) video=AiUpscale(video, luma="HQ Sharp") |
17th February 2023, 08:58 | #128 | Link |
For chroma resampling with factor=1 and CResample= any AiUpscale model, the source must be 4:2:0. With a 4:2:2 source you can also use CResample="KrigBilateral".
Chroma resample is done first if CResample is set, and then all planes are upscaled if factor>1
AviSynth AiUpscale Last edited by Alexkral; 17th February 2023 at 09:18. |
21st February 2023, 08:44 | #129 | Link | |
The first picture is without upscaling. I was just trying a basic 720 upscale in the others. Did I do it wrong? Code:
MPEG2Source("DVD.d2v") TFM() TDecimate() propSet("_FieldBased", 0) z_ConvertFormat(colorspace_op="601=>709") BalanceBorders(0,0,0,5) FineDehalo() AiUpscale(Factor=2, CResample="KrigBilateral", Mode="LineArt") z_Spline36Resize(1280,720) Last edited by PoeBear; 21st February 2023 at 10:48. Reason: answerd my own question lol |
5th October 2023, 17:24 | #130 | Link | |
9th October 2023, 04:04 | #132 | Link |
No, this uses hlsl shaders via Avisynth Shader. I haven't tried avslibplacebo, but vs-placebo was considerably slower, probably due to the need to both send and receive 16-bit planes.
The added mpv user shaders should be usable on both. It's great to have all the functionality of libplacebo available though.
AviSynth AiUpscale Last edited by Alexkral; 9th October 2023 at 04:13. |
11th November 2023, 16:49 | #133 | Link | |
7th January 2024, 18:11 | #134 | Link |
I have some problem with StaxRip. See here:
Script Error Cannot load file 'C:/StaxRip-v2.31.0-x64/Apps/Plugins/AVS/AviSynthShader/Shader-x64.dll'. Platform returned code 126: The specified module was not found. (L:\Videobearbeitung\Video_Sample_new.avs, line 3) Although the file "dll" is on location at StaxRip. Last edited by DeafYakuza; 7th January 2024 at 20:07. |
8th January 2024, 13:02 | #135 | Link | |
There are multiple binary versions of the same thing [that one is versioned v9.29.1974.1, Feb/20/2021]. Some years since I updated my archived version, so I'll down that one assuming is newer than the one I've got somewhere.
8th January 2024, 18:18 | #136 | Link |
Error Index LWLibav (v2.32.0)
Index LWLibav returned exit code: -1313558101 (0xB1B4B1AB) StaxRip.ErrorAbortException: Index LWLibav returned exit code: -1313558101 (0xB1B4B1AB) bei System.ComponentModel.ReflectPropertyDescriptor.SetValue(Object component, Object value) bei System.Windows.Forms.BindToObject.SetValue(Object value) bei System.Windows.Forms.Binding.PullData(Boolean reformat, Boolean force) bei System.Windows.Forms.Binding.Target_PropertyChanged(Object sender, EventArgs e) bei System.EventHandler.Invoke(Object sender, EventArgs e) bei System.Windows.Forms.Control.OnTextChanged(EventArgs e) bei System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e) bei StaxRip.UI.TextBoxEx.OnTextChanged(EventArgs e) in D:\Code\Github\staxrip\staxrip\Source\UI\Controls\Controls.vb:Zeile 649. bei System.Windows.Forms.Control.set_Text(String value) bei System.Windows.Forms.TextBoxBase.set_Text(String value) bei System.Windows.Forms.TextBox.set_Text(String value) bei StaxRip.UI.TextEdit.set_Text(String value) in D:\Code\Github\staxrip\staxrip\Source\UI\Controls\Controls.vb:Zeile 3036. bei StaxRip.MainForm.OpenVideoSourceFiles(IEnumerable`1 files, Boolean isEncoding) in D:\Code\Github\staxrip\staxrip\Source\Forms\MainForm.vb:Zeile 2203. |
11th January 2024, 00:07 | #137 | Link |
All I can say is that I also have frequent problems with Staxrip, with scripts working perfectly just by passing the command line to the encoder via Virtualdub2.
AviSynth AiUpscale |
12th March 2024, 15:50 | #138 | Link |
Is there a way to avoid the jaggies that occur when upscaling?
This is what I use in AvsPmod. QTGMC deinterlaces to progressive and then AiUpscale to enlarge: Code:
SetFilterMTMode ("QTGMC", 2) AVISource("video.avi", audio=true) #720x576 AssumeFPS(25) AssumeBFF() QTGMC(preset="Slower", EdiThreads=2) AiUpscale(Factor=2, Luma="HQ Sharp", Chroma="Lanczos", CResample="", Mode="Photo", CPlace="MPEG2", OutDepth=8) Crop(0,36,0,-36) Prefetch(5) |
12th March 2024, 16:11 | #139 | Link |
Big Bit Savings Now !
This is in the source, still.
Such sources got to be prefiltered. I get those vertical strip patterns also with certain maimed sources fed into Topaz VEAI. I am guessing on careless NTSC <-> PAL normconversions involving certain too-sharp resizing kernels or not caring for interlaced content. AI uprezzing is not to blame, it only finds something tiny that it thinks is desired detail to be enhanced.
12th March 2024, 16:47 | #140 | Link | |
The source is original PAL dv video. There's no NTSC conversion involved. The resizing is applied after the deinterlacing. |
