Old 17th July 2007, 05:37   #461  |  Link
ChuckUFarley
Dude, I'm sorry. That all sucks.
But I was not dogging you personally. I assumed more people (besides you) had some experience and might have tips.
Finally, I will request a name change, I wasn't aware it would be an issue.
ChuckUFarley is offline
Old 19th July 2007, 01:02   #462  |  Link
ChuckUFarley
I managed to completely encode the movie, but it required splitting it into 5 scripts of about 30-45 minutes each.
Any more and CCE would throw an error.
Possible memory leak?
I intend to encode the same script in x264 later. Hopefully that will be able to make it in one go.
Old 19th July 2007, 02:56   #463  |  Link
You can also try a different MPEG2 encoder, such as HC. That would help us to determine if the problem is in DGAVCDec or CCE.
BTW, your nick has been declared OK by the powers that be, so there's no need to change it. I disagree, but I just work here.
Guest is offline
Old 19th July 2007, 22:11   #464  |  Link
ChuckUFarley
HC is unable to completely encode either. I got a standard Windows error that wasn't informative.
I don't know if I mentioned that the script uses multiple trim commands to edit the film... if that makes any difference.
Old 20th July 2007, 00:28   #465  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
May be, I found a bug. Look at the screenshots I made. Source ist totally fine. Indexing with DGAVCIndex brings big block artefacts.
Uploaded 1 min of the source stream. I use Alpha 6 with Original libavcodec.dll. Didn't try tryout.dll, just recognized it yet.
http://rapidshare.com/files/43901389/dga.h264.html
Source has 720p.
Deinorius is offline
Old 20th July 2007, 02:43   #466  |  Link
ChuckUFarley
You probably should install one of the tryout libavcodec's first.
Most people aren't even able to get DGAVCDec to load video with the older versions of the .dll let alone get it to index properly.
Old 28th July 2007, 10:32   #467  |  Link
Gannjunior
Gannjunior's Avatar
hi Neuron,
i know that dgindex is able to read mpeg2 video inside .evo container from hd-dvd.
What's about vc1 video inside .evo? Is dgindex able to read it?
Because i would like a little raw clip from an hd-dvd of my friend, but i would like to cut it, because he's not able to upload me a big file... So, since Dgindex is able to get cut operations, i would like to know if it is possible or not with vc1-evo...
TIA
ciao
P6T| 12Gb DDR3| i7-920 D0@3.8Ghz@1.168v+NOCTUA NH-U12P| Liberty 620| Stacker|2xRAID0 (4x500gb) Seag.72k.11| Seag. 500gb 72k.12| Seag. 1.5Tb 72k.11| GTX470@668/1843| U2410 24"| Se7en x64 on VRapt 300gb
Gannjunior is offline
Old 28th July 2007, 13:37   #468  |  Link
No VC1. DGIndex works on MPEG only.
Guest is offline
Old 30th July 2007, 12:16   #469  |  Link
SpAwN_gUy
Junglist
SpAwN_gUy's Avatar
try this one .. but .. unfortunately it IS halted(i guess).. and ther is NO seeking.
OFFTOP: maybe, after completeing AVCDec, neuron could make the TRUe DGVC1Dec ... (i assume this will not be such a problem, when ffvc1(???)decoder will be there, and after messing around with ffavcdecoder (names are probbably wrong)).. so we would get DG(HD)Index and Decoders
Rule Number 6: Concentrate!!!
(c)Hercules, Disney
"I like to build planes.... in the air" (c) some ADV.
tutorials
How to Setup agent-based encoding with x264farm (the easy way)
SpAwN_gUy is offline
Old 2nd August 2007, 13:42   #470  |  Link
hajj_3
any update on progress neuron?
hajj_3 is offline
Old 12th August 2007, 21:09   #471  |  Link
harissa
can anyone help me i can't open the ts h264 hdtv file
my guess is that i have to convert it to raw 264 so it can be loaded in dgavcdec100a6 , but i cant find any procedure anywhere
harissa is offline
Old 13th August 2007, 04:22   #472  |  Link
harissa
I manage to extract the raw *.264 from the ts hd file with mencoder
but i got this msg in DGAVCDec
"" paff interlacing not currently supported ""
any help ?
hd file is 1440*1080 29.9frame , so it s interlaced
harissa is offline
Old 13th August 2007, 05:11   #473  |  Link
harissa
megaupload.com/?d=Q87R16OG
here s the file it was recorded with a dvb appz
so i used the TsRemux.exe to rewrite a new ts
and used mencoder to extract the h264
for information all h264 1280*720 60fps can be easly open with DGAVCDec
only the interlaced one have this problem
harissa is offline
Old 13th August 2007, 05:22   #474  |  Link
mitsubishi
The error message is pretty clear, paff isn't supported, so it won't work until it is.
mitsubishi is offline
Old 13th August 2007, 05:25   #475  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Your stream isn't supported at all, it's been mentioned over and over in this thread, and it won't work in ffmpegsource either, so your only option is really directshowsource. Since development has stalled, there's no much point in waiting for the next version, which might be next week or next year.
foxyshadis is offline
Old 13th August 2007, 05:29   #476  |  Link
harissa
directshowsource
i ve tried that the file didnt load at all
do i have to keep the ts or directshowsource. the raw file ?
harissa is offline
Old 13th August 2007, 06:21   #477  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Whatever you have directshow splitters installed for. TS will probably be a lot easier to find than raw, haali's supports it for instance.
Old 18th August 2007, 08:45   #478  |  Link
pyrates
dgavcdec wrong framerate
I know that with a raw h.264 file, the framerate can't be found out. But if there can be an option that I can set what the framerate of the h.264 file should be, then the proper framerate can be set in the dga file that is created by opening it up in Notepad and making the change. Right now it defaults to 60000/2002, it should be either that, or 24000/1001 or 25/1. Or entering in a custom value would be good too for those weird sources.
pyrates is offline
Old 18th August 2007, 13:22   #479  |  Link
That's not always true. The frame rate is specified in the raw stream's SPS for fixed framerate files:
if (sps->vui_seq_parameters.fixed_frame_rate_flag == 1)
  nalu->time_scale = sps->vui_seq_parameters.time_scale;
  nalu->num_units_in_tick = sps->vui_seq_parameters.num_units_in_tick;
else
  nalu->time_scale = 50;
  nalu->num_units_in_tick = 1;
Then:
fprintf(p_aif, "\nFPS %d / %d", nalu->time_scale, 2 * nalu->num_units_in_tick);
Anyway, you can simply edit the DGA file and go to the bottom and change the FPS line.
Guest is offline
Old 20th August 2007, 15:31   #480  |  Link
pyrates
Yeah thats what I do right now, but it would be nice if the gui had an option to specify the framerate. But even better to detect it using that code.
pyrates is offline
