Old 20th December 2006, 23:54   #1161  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
have you tried reinstalling MeGUI?
check is offline
Old 21st December 2006, 12:29   #1162  |  Link
Seroxat
Same problem here, unable to load d2v in AviSynth scrip creator. Following error message pops up (version 2.4.1012):
"Error message for your reference: Attempted to read or write protected memory. This is often an indication that other memory is corrupt."
I do have a YU12 codec installed, and opening d2v works in all other applications including MeGUI versions 2.3.xxxx.
Seroxat is offline
Old 21st December 2006, 15:06   #1163  |  Link
weaver4
Does MeGui support single pass XviD? I did not see it. What profile would one use?
weaver4 is offline
Old 21st December 2006, 18:22   #1164  |  Link
Sh4nn0w
Just setup your own profile. One isn't provided.
Sh4nn0w is offline
Old 23rd December 2006, 15:01   #1165  |  Link
karasu
karasu's Avatar
yes, twice. And reinstalling Avisynth too. No change.
karasu is offline
Old 30th December 2006, 08:53   #1166  |  Link
parcival
Same problem with karasu for me too.
It worked OK with previous versions (2.3.x.x)
parcival is offline
Old 30th December 2006, 09:24   #1167  |  Link
check
phjbdpcrjlj2sb3h
check's Avatar
try reinstalling your YV12 decompressor
check is offline
Old 2nd January 2007, 22:13   #1168  |  Link
parcival
I tried everything.
The problem is with MeGUI.
I just replaced latest MeGUI version (AutoUpdate) with MeGUI v0.2.3.2193 (megui.exe, MessageBoxExLib.dll and ICSharpCode.SharpZipLib.dll) and everything works fine. So it is not the decoder or Avisynth. Something changed in MeGUI v0.2.4.x and it messed things up.
parcival is offline
Old 3rd January 2007, 01:34   #1169  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Works here...
Sharktooth is offline
Old 3rd January 2007, 07:56   #1170  |  Link
chadamir
I can't seem to put in a decimal value i.e. 18.3 for crf encoding.
chadamir is offline
Old 3rd January 2007, 14:29   #1171  |  Link
parcival
Let me try to be more specific.
I use ffdshow as the only decoder in my system (2006-12-30 build by clsid) together with Haali Media Splitter (28/12/2006). AviSynth v2.5.6 is also installed.
Let me clarify that I am talking ONLY about Avisynth builder included in MeGUI tools. Everything else works for me too. When I try to open a d2v file created with DGIndex.exe (version 1.4.8) I get the error message.
As I already said this doesn't happen with MeGUI v0.2.3.2193
parcival is offline
Old 3rd January 2007, 14:30   #1172  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
CRF and QP accept only integer numbers.
@parcival: i cant reproduce... it works perfectly here.
Old 3rd January 2007, 23:00   #1173  |  Link
parcival
Do you use the same codecs etc with me or different?
I could give AviSynth v2.5.6a a go too just in case...
parcival is offline
Old 4th January 2007, 11:57   #1174  |  Link
nurbs
CRF accepts fractional values since rev. 591.
nurbs is offline
Old 4th January 2007, 14:35   #1175  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i meant in megui.. he cant specify fractional values coz it accepts only integer numbers.
Old 5th January 2007, 05:32   #1176  |  Link
chadamir
I knew what he meant, any plans to change that?
chadamir is offline
Old 5th January 2007, 14:20   #1177  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
is it really necessary? I mean, i cant see the reason akupenguin implemented fractional CRF values...
Old 5th January 2007, 15:30   #1178  |  Link
parcival
I tried to my other computer with windows XP and exactly the same codecs/programs installed and it works fine.
It seems something is wrong with MeGUI 2.4.x.x and 2K. Do Windows 2K miss something? (I have latest Windows updates installed on both machines)
parcival is offline
Old 5th January 2007, 16:42   #1179  |  Link
chadamir
http://forum.doom9.org/showthread.php?t=116773 Take a look at this thread, they basically figured out how to get crf to an exact bitrate without taking any significant hit to quality over two pass.
chadamir is offline
Old 5th January 2007, 17:00   #1180  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
ooook.
