28th April 2011, 17:47 | #641 | Link |
Is it definite that Lagarith is decoding to YUY2? Perhaps it decodes to RGB ...
--------------------------------- SetMemoryMax(600) SetMTMode(5, 6) AviSource("c:\temp\jj.avi" ,audio=false ) # lagarith lossless yuy2 video return( info() ) #Converttoyv12() AssumeTFF() SetMTMode(2) QTGMC( Preset="Very Slow", EdiThreads=3) ------------------------------------------
29th April 2011, 05:59 | #645 | Link |
@ttatcs
I am using following version Code:
31.12.2010 18:13 966144 mt_masktools-25.dll 24.10.2007 10:41 33280 RemoveGrainSSE2.dll 24.10.2007 10:41 24576 RepairSSE2.dll 11.04.2005 12:16 30720 SSE2Tools.dll 28.02.2008 08:03 11776 VerticalCleanerSSE2.dll --------------------------- VirtualDub Error --------------------------- Avisynth open failure: mt_makediff : unsupported colorspace. masktools only support planar YUV colorspaces (YV12, YV16, YV24) (QTGMC-3.31.avsi, line 775) (QTGMC-3.31.avsi, line 387) (E:\Video\Mother\new\2002\deint2002.avs, line 9) --------------------------- ОК --------------------------- yup. Last edited by yup; 29th April 2011 at 06:03. |
29th April 2011, 13:31 | #646 | Link | |
I kept both "mt_masktools-25.dll" and "mt_masktools-26.dll " in the plugin directory . After I put "mt_masktools-26.dll" out of that directory then the error was gone. Really appreciate your work . |
29th April 2011, 13:35 | #647 | Link |
Im getting heavy ghosting using QTGMC for deshimmer in an IVTC'ed anime source.
I use this line, is this normal? Code:
QTGMC(Preset="Slower", InputType=1,sharpness=0.0)
i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub + Discussion thread |
30th April 2011, 00:12 | #649 | Link |
Although I know a number of people use it with success, QTGMC is not really designed for anime. QTGMC relies on identifying the motion from frame to frame. With a film source the frame rate is fairly high and movements between frames are usually small; the detail of film means good matches can often be found. Anime will run at a lower rate, may contain duplicate frames, have stylized/artificial movement, and be hard to track if there is a lack of fine detail. So motion matches on anime can be poor, which will lead to ghosting on the temporal steps of the algorithm (and possible blurring / halo strengthening). The same problems can apply to game captures to a lesser extent.
Tweaking parameters might help a little [for example, reduce the temporal radiuses - QTGMC( "Slower", TR0=1,TR1=1,TR2=0) ], but if you're getting heavy ghosting then it may simply be that QTGMC is not going to work for this task. Last edited by -Vit-; 3rd September 2011 at 17:36. |
1st May 2011, 09:36 | #650 | Link |
partially-informed layman
For anyone who is interested, I did some 1080-60i to 480i DVD test renders and converted them to a ready-to-burn DVD project for comparison. One of them uses the "IResize" script referred to a couple of pages back, and another includes a QTGMC pass as suggested by Didée. See here.
5th May 2011, 06:38 | #651 | Link |
To all interested about support YUY2.
For all Avisynth build (2.58, 2.58 MT, IanB 2.6, SEt 2.6) will be properly work only mt_masktools-25***.dll, because mt_masktools-26***.dll need YV16 planar colorspace (not from Interlevead2Planar). see http://forum.doom9.org/showthread.ph...83#post1497883 If we want use 26 masktools we could work with 3 types colorspace YUY2, hacked Kassandro (Interleaved2Planar) and native YV16 it is ridiculous. yup. |
5th May 2011, 07:22 | #652 | Link |
I've been getting errors running QTGMC 3.31 when using qtgmc("slow", shutterblur=2, fpsdivisor=2) or any other faster preset. The error displays as "super clip does not contain needed color data". Could this be due to that slight speedup in a previous version?
5th May 2011, 14:31 | #653 | Link | |
5th May 2011, 15:06 | #654 | Link |
Hy All!
I'd like you to check some of my footages and give me some advice. I use QTGMC mainly for deinterlacing video game materials and I'd be glad if you could help me in some ways. I've uploaded a .zip file here including the following files: -3 .avs files (details below) -source file (150 frames), UtVideo codec (in this case ULY0 due to QTGMC's obvious colorspace requirements) -a test conversion with my script I normally use (x86 edition, with my PC it required 38m52s) -a test conversion (x64) with the same specs I use in the .avs for x86 (12m1s but because of the quality loss and huge 'artifact' problem or something, I don't know what to call this deterioration of the frames) -a test file (x64) with modified specs from my x86 .avs (35m35s ; see 'x64 without Blocksize & Overlap.avs' below) -last test material (x64) with VirtualDub x86 (23m46s & exact filesize as x86's ; somehow x86 & x64 avisynths were installed at the same time but independently, Windows\System32 contained only 32-bit files for the process) For all normal 64-bit conversions I used Veedub64 and in every case the output codec was ULY2 (in my opinion it's the fastest and makes the best possible results after the 'almighty' raw uncompressed; after a few identical tests it was waaay much faster than using the uncompressed output format in this case of ). All the 64-bit and 32-bit plugins needed for QTGMC are the latest, I can list them with the version numbers if you would like to. When I first met QTGMC, I read literally all the intructions in the QTGMC.avsi (now we know it's separated into 2 files) and after that I started to use these following avisynth scripts I found the toughest : x86.avs: SetMTMode(5,0) AVISource("test.avi") QTGMC( Preset="Placebo", NNeurons=4, EdiQual=2, Sharpness=0.25, SubPel=4, Blocksize=32, Overlap=16, SourceMatch=3, MatchPreset="Placebo", MatchPreset2="Slower", MatchEnhance=0.6, Lossless=2, Sigma=3, GrainRestore=0.5, FPSDivisor=2, ChromaMotion=false ) -------------------- x64.avs (the same as the x86 edition above but contains redirection to 64-bit plugins after installing avisynth64): SetMTMode(5,0) AVISource("test.avi") SetWorkingDir("c:\Program Files (x86)\AviSynth 2.5\plugins64") QTGMC( Preset="Placebo", NNeurons=4, EdiQual=2, Sharpness=0.25, SubPel=4, Blocksize=32, Overlap=16, SourceMatch=3, MatchPreset="Placebo", MatchPreset2="Slower", MatchEnhance=0.6, Lossless=2, Sigma=3, GrainRestore=0.5, FPSDivisor=2, ChromaMotion=false ) -------------------- x64 without Blocksize & Overlap.avs (after removing these specs from the script, the image became as clean as it should be): SetMTMode(5,0) AVISource("test.avi") SetWorkingDir("c:\Program Files (x86)\AviSynth 2.5\plugins64") QTGMC( Preset="Placebo", NNeurons=4, EdiQual=2, Sharpness=0.25, SubPel=4, SourceMatch=3, MatchPreset="Placebo", MatchPreset2="Slower", MatchEnhance=0.6, Lossless=2, Sigma=3, GrainRestore=0.5, FPSDivisor=2, ChromaMotion=false ) -------------------- Usually for normal length gameplay videos (4-5 mins) the average conversion speed is 0,25fps with my PC & the .avs files above. Please help me in improving my script and make the best out of the source material. Thanks in advance, K1CS1K Our YouTube channel |
5th May 2011, 17:46 | #655 | Link |
That source is not interlaced. It's progressive that has been weaved strangely. One field of each frame exactly matches the other field of the next frame. A capture issue maybe? Anyway, no deinterlacing is needed:
AviSource( "YourPathTo\test_150_frames.avi" ) ComplementParity() # Might not always need this line SeparateFields().Trim(1,0).Weave() You might prefer the look of your encodes because the QTGMC temporal processing smooths things a little. However, QTGMC is not the right tool for this job. [Those QTGMC settings were overkill for any source. MatchPreset="Placebo" is never worth it.] |
11th May 2011, 07:38 | #657 | Link |
maybe it's out topic but shall i compress with qtgmc using selecteven if i want to deinterlace a pal dv source. I want to transfer it to dvd but i'm not sure if dvd players are compatible with pal 50fps progresive. Hope you cand help.
I7 920 @ 3.60GHz + Thermalright Ultra 120 Extreme Asus P6T Deluxe, 6GB Corsair XMS3 1600MHZ 8-8-8-24 2x1TB Samsung + 1x500GB Samsung, Corsair 520W, Thermaltake Soprano DX GeForge GTX280 Last edited by egrimisu; 11th May 2011 at 07:49. |
11th May 2011, 07:53 | #658 | Link |
Pig on the wing
I think you might want to experiment with the single-rate output options in QTGMC instead of using QTGMC+SelectEven. You could get a more film-like appearance to the result.
11th May 2011, 08:06 | #659 | Link |
so basicly that means that i can't use 50fps in a pal dvd. i haven't found any single-rate option in qtgmc, plese guide me.
I7 920 @ 3.60GHz + Thermalright Ultra 120 Extreme Asus P6T Deluxe, 6GB Corsair XMS3 1600MHZ 8-8-8-24 2x1TB Samsung + 1x500GB Samsung, Corsair 520W, Thermaltake Soprano DX GeForge GTX280 |
11th May 2011, 08:08 | #660 | Link |
Pig on the wing
You cannot use 50fps streams for DVD. See the "Shutter Speed Motion Blur / Frame Rate" section in the QTGMC documentation, that's where the magic is.
