6th February 2010, 20:49 | #1064 | Link |
Pig on the wing
I just tried encoding a 32-bit stereo WAV with the latest version, no problems here.
6th February 2010, 20:58 | #1065 | Link |
^maybe its my file... I tried the first file on this webpage ( M1F1-Alaw-AFsp.wav): http://www-mmsp.ece.mcgill.ca/Docume...E/Samples.html
and I got the same error. does that one work for you? ps: the second one also gives me the same error(M1F1-AlawWE-AFsp.wav). somethings definately wrong with my setup. i am running v4.4 from the zipped package |
6th February 2010, 21:03 | #1066 | Link |
Pig on the wing
I think it's a problem with the encoding type in the WAV file.. try some "regular", i.e. PCM encoded WAV. For example this one is such: http://www-mmsp.ece.mcgill.ca/Docume...int16-AFsp.wav
6th February 2010, 22:02 | #1068 | Link | |
how do I disable mono input mode? |
7th February 2010, 01:44 | #1070 | Link |
wow. I can't believe I missed something like that
thanks edit: I have another problem now... my wav source is not sampled to 48k and I have to feed an avs script into encwavtoac3 so that it will convert it. here's my script: Code:
#avisource("G:\temp\1.avi")+avisource("G:\temp\2.avi") #SoundOut() WavSource("G:\temp\bgf.wav") ssrc(48000) edit: I just found out that it only works with avs 2.5.7 and below as of Aug 2/'09. I guess that's still the case. I'll try it on 2.5.7 and give it a whirl. Last edited by canuckerfan; 7th February 2010 at 02:12. |
13th March 2010, 21:40 | #1074 | Link |
I keep getting "Encoder Error: Failed to initialize encoder". Funny thing is that when I start the program for the first time after system restart I can get it to encode, but then this error keeps appearing in logs. I'm on 64-bit Vista Ultimate. Any ideas?
14th March 2010, 11:37 | #1076 | Link |
Sorry for a false alarm, problem solved, my bad. I was trying to encode a 5.0 ac3 with LFE low-pass filter enabled. It was pure coincidence that the program started encoding after two reboots (different settings).
17th March 2010, 18:52 | #1077 | Link |
Unavailable
Aften-git, problem with 44.1kHz
Let's say, I have a 3min 36sec stereo WAV file (extracted from an Audio CD), and compress it with Aften.exe @ 192kbps, and then use spdifer.exe to obtain a DDWAV stream. Instead of getting a 36.3MB .wav, spdifer produces a 34.8MB one (and if I try a different bitrate, e.g., 256kbps, the resulting SPDIFed .wav has only 17.4MB ). This problem *does not* happen with ac3 files generated by Soft Encode, for example.
20th March 2010, 21:44 | #1078 | Link |
Unavailable
OK, today I found this post by madshi:
http://forum.doom9.org/showpost.php?...&postcount=945 which made me give a try to the latest release of EncWAVToAC3. Sadly the "44.1kHz problem" seems to be even worse in the libaften-GUI encoder: the same .WAV source-file mentioned in my post above becomes a 5.77MB .ac3 encoded at 224kbps by EncWAVToAC3, however spdifer.exe obtains a 12-byte .WAV file from that. Again, spdifer keeps working correctly on files created by a "Dolby-certified" encoder... |
21st March 2010, 02:53 | #1079 | Link | |
BTW, I can't understand the process. You have a stereo wav file 3m:36s (36,3 MB), encoded with ac3 192 Kb/s (4.9 MB) and spdifer convert the file to ddwav (34.7 or 36.3 MB) What is the benefit to have a lossy compressed audio with the same size than the lossless source? With my stereo samples, encoded with Aften and Soft Encode, obtain the same wrong output size when use spdifer. I have some 5.1 ddwav and the size isn't the size of the wav sources. Is the size of the ac3 x 2.2 ac3 file 31.5 M -> ddwav file 69.6 MB With spdifer I obtain the same ratio with 5.1 ac3 files. Maybe spdifer don't work properly with stereo files.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 21st March 2010 at 02:56. |
21st March 2010, 03:20 | #1080 | Link |
Unavailable
It depends on the spdifer's version one uses, I think. FWIW, I'm using the build 0.1a.
Anyway, I am not thinking in terms of "benefits", just in terms of "standard-compliance" --- if someone intends to create a multichannel AC3 Audio CD, it's better that they know they shouldn't be using Aften for doing that. Given that spdifer does work correctly with the 32kHz && 48kHz AC3 outputs from Aften, it seems to me, *now*, that the 44.1kHz encodes from Aften are not "correct enough". I remember that "many months ago", just for testing/learning purposes, I created some stereo AC3s @ 44.1kHz with aften.exe, and realized that most of them were played back @ 48kHz when decoded by AC3Filter. Because such files were played back @ 44.1kHz when decoded by ffdshow, I (erroneously) concluded that the actual problem "had to be" in AC3Filter, "not" on the 44.1kHz files generated by Aften.exe. P.S.: So, żżż is there any better alternative to spdifer.exe ??? P.P.S.: ffdshow (r1376) audio processor is not an option, because its AC3 encoder supports only 48kHz and 32kHz. Last edited by Midzuki; 21st March 2010 at 12:05. Reason: add P.S.s, clarification, info update |
