Old 25th June 2009, 08:46   #21  |  Link
G_M_C
If, for technical reasons, we still need to force IDR frames every once in a while despite open-GOPs being perfectly fine keyframes, the value should be really large.
only 1 IDR is needed in a stream.
If add these up, then the vanue DS is speaking of, could be set eqqual to the number of frames in the input-stream ? If you then make first frame of the output-stream an IDR, you wont get another one (if not needed/requested).
G_M_C is offline   Reply With Quote
Old 25th June 2009, 13:52   #22  |  Link
Trahald
Wewkiee
Trahald's Avatar
That would still fall under 'lying' to the scene-cut routine.
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline   Reply With Quote
Old 25th June 2009, 13:55   #23  |  Link
Trahald
Wewkiee
Trahald's Avatar
Originally Posted by Selur View Post
how about two two parameters 'max IDR interval' and 'may key frame interval' ? (I need IDR frames to cut lossles, don't I?)
A lot of sample streams i got when making h264info were cut at open gop. all that happens is first few b-frames (any that pts < the pts of the i-frame) are discarded during playback. same as what happens when seeking in an open gop stream. and yeah... just need a smart enough cutter. or maybe dumb enough, ie most probably just look for i frames , not necessarily IDRs.
Old 25th June 2009, 14:06   #24  |  Link
Trahald
Wewkiee
Trahald's Avatar
@DS
I understand the changes you request for code-sake and I'll try to make them. Only that it probably will have to start with 'git reset --hard' except for maybe the SEI part. since i wrote it in a way that required me to understand the least about frame type decisioning. so might be a while. I really didnt make it with a commit in mind. just that noone else has bothered so i made something that worked (result wise if not code wise) mostly for myself although I dont mind sharing.
Would you explain why x264 even cares at all about max keyframe interval in scene cut decisions. AFAIK that is unique to x264. Im willing to code it (time permitting) without agreeing w/it but it would help if i could wrap my head around the idea behind it.
Old 25th June 2009, 14:07   #25  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by Dark Shikari View Post
Well, you probably can cut at a recovery point, the cutting software just has to be smarter.
So we will have "recovery points" in between IDR frames, that are not IDR frames themselves ???
Can you explain a bit: How does that work? I mean, if we start decoding at a Non-IDR frame, we will require references from previous frames, don't we?
Okay, as far as I understand, a recovery point says "output will be good again in x frames, if you start decoding here". There may be "scrambled" output until frame x is reached.
But how does the encoder know? Does it keep track of all macro-blocks and write a recovery point after each macro-block has been "refreshed" at least once? Or what?
Old 25th June 2009, 17:23   #26  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Originally Posted by Trahald View Post
@DS
I don't think it's that hard at all; what you've done is almost right. All you have to do is consider recovery points to be keyframes, and you're done. You don't need to understand frametype decision at all; you only need to not change it.
Because if x264 is near the end of the GOP, x264 is more willing to place extra I-frames than if it had just placed one two frames ago.
That's called periodic intra refresh, and this patch isn't related to that.
Old 25th June 2009, 17:24   #27  |  Link
Manao
The encoder can enforce it by preventing frames temporally after the I to reference frames temporally before the I. Don't forget that even if a frame is in the reference buffer (aka DPB), you are allowed not to use it (they'll be flushed out of the DPB in good time, ie, when you'll have encoded enough new reference frames)
Manao is offline   Reply With Quote
Old 25th June 2009, 17:48   #28  |  Link
LoRd_MuldeR
Software Developer
Hmm, I see. But what is the benefit of placing a "recovery" Non-IDR I-Frame instead of a "true" IDR-Frame, if we don't reference the frames before that I-Frame anyway?
Does x264 support/use periodic intra refresh yet?
Old 25th June 2009, 18:00   #29  |  Link
Dark Shikari
x264 developer
No; it's really only useful for extremely-low-delay situations where your VBV is too small to allow periodic I-frames.
Old 25th June 2009, 18:07   #30  |  Link
Manao
You can still open the gop, while an IDR forces to close the gop.
Old 25th June 2009, 18:17   #31  |  Link
LoRd_MuldeR
Software Developer
Sorry, what exactly does that mean then?
I though using references from the previous GOP (that is: before the last I-Frame) inside the current GOP is the definition of an "open" GOP
If we now decide to not use references from before the I-Frame (to get a valid "recovery point"), wouldn't that result in "closed" GOP's ???
Old 25th June 2009, 18:34   #32  |  Link
Manao
In temporal order :
closed gop : PbbbPbbbPI
open   gop : PbbbPbbbbI
In coding order :
closed gop : PPbbbPbbbI
open   gop : PPbbbIbbbb
Note how, in coding order (ie, in the bitstream), the b frames temporally before the I frame are actually after the I frame. That's why the gop is called open. If you start decoding at the I, you won't be able to decode the b (you'll have to skip them), but it's no big deal because they are temporally before the I. IDR prevents you to use bframes in the open gop fashion because it flushes the reference buffer (thus, were you to use an IDR in an open gop situation, the bframes wouldn't not be able to reference the preceding P : they wouldn't be bframes anymore).
Old 25th June 2009, 18:42   #33  |  Link
LoRd_MuldeR
Software Developer
Ah, I see
Old 28th June 2009, 12:17   #34  |  Link
juGGaKNot
juGGaKNot's Avatar
Trahald can you explain in n00b terms how does this help/affect the quality of fades and where is it usefull ( high resolutions only ? )
thnx.
This patch really is only useful if you have small gops (ie bluray) . my tests were at min keyint of 12. This patch is not for your production encodes as it is experimental. Do not create any binaries with this patch that may be in automatic upgrading scripts to protect the innocent.
Hmm a link about gops/gops-keyint relation ?
juGGaKNot is offline   Reply With Quote
Old 28th June 2009, 13:55   #35  |  Link
Manao
As Trahald already said, this patch is useful mostly when you use a low max keyint interval. The reason for its usefulness is that, without the patch, x264 considers that key frames are IDR, which are special picture types that prevents the previous picture type to be a B frame. So, even if x264 would have wanted to use a B frame, if the following frame must be a key frame because of max keyint, without the patch the B will be transformed into a P frame, which isn't as good.
Furthermore, open gops will help reduce the problem of intra "pumping" at low bitrates and small gops.
Finally, a gop, in the mpeg2 terminology, is a group of picture starting on an intra frame, and stopping just before the next one. For mpeg2, all intra frames are entry points in the video, so settings the gop period set the entry points period. For h264, not all intra frames are sync points, but somehow the gop remained aliased to the idea of sync point (and not intra frames). So a gop can be seen as starting on an entry point (be it a IDR or a plain I frame) and stopping just before the next one.
With that definition, max-keyint sets the maximum gop size, and min keyint sets the minimum gop size.
Old 28th June 2009, 14:20   #36  |  Link
juGGaKNot
juGGaKNot's Avatar
Yes, thnx, most of this i have read ( not in such depth ) but i am asking about where to use them.
Sets the maximum interval between IDR-frames (aka keyframes) in x264's output.
As far as i know when i render uncompressed from vegas every frame is a keyframe, is this wrong ?
Old 28th June 2009, 14:25   #37  |  Link
LoRd_MuldeR
Software Developer
I don't know what VEGAS does. But x264 in "lossless" mode uses I-Frames (probably IDR and Non-IDR) as well as P-Frames.
Only B-Frames are disabled, because they don't help in the special case of lossless encoding.
If you want to enforce an I-Frame only stream for some reason, you can simply set the value of min_keyint to 1
Old 28th June 2009, 14:27   #38  |  Link
Manao
It's normal. Uncompressed video doesn't have temporal dependencies between frames, so you can seek instantaneously wherever you want in an uncompressed video. The same would be true if you were encoding with mjpeg (all frames are intra), or ASP/AVC with only intra frames (max-keyint set to 1 with x264 for example).
As for when to use open gop : always. There are no (valid) reason not to use it. It's better, period.
Old 28th June 2009, 14:33   #39  |  Link
juGGaKNot
juGGaKNot's Avatar
K, i will test so maxkeyint 1 ?
Again, "max keyint" in scenecut routines should be the distance between keyframes, not the distance between IDR frames.
Old 28th June 2009, 14:52   #40  |  Link
Manao
What for ?
