Old 28th July 2016, 18:16   #1  |  Link
asdf013cv
Questions about Reference Pixel Handling in HEVC intra prediction
Hi, I am reading the paper, Intra Coding of the HEVC Standard.
After figuring out reference sample substitution and smoothing, I have 2 questions about Reference Pixel Handling.
From the paper,
"all sample locations within one prediction block are projected to a single reference row or column
depending on the directionality of the selected prediction mode
(utilizing the left reference column for angular modes 2 to 17 and the above reference row for angular modes 18 to 34).",
can anyone explain what exactly it mean? (for example, 4x4 prediction block)
Also, the paper says
"The intra sample prediction process in HEVC is performed by extrapolating sample values
from the reconstructed reference samples utilizing a given directionality.",
why do I need extrapolation? All reference samples is available, isn't it? If it is, why cannot I use reference samples directly?
I also read the book, High Efficiency Video Coding (HEVC) Algorithms and Architectures, but it just make me more confused....
asdf013cv is offline   Reply With Quote
Old 28th July 2016, 22:30   #2  |  Link
FancyMouse
You just choose to start from row array, (exclusively) or column array, depending on your mode. That becomes the source of your prediction block.
Because most of the predictions have a non-trivial angle (i.e. not 0/45/90 degree). In those cases, to predict a pixel (x,y), its projection to reference row/column (x',0) or (0,y') might have a non-integer coordinate x' or y'. However you only have samples at integer coordinates.
FancyMouse is offline   Reply With Quote
Old 29th July 2016, 06:33   #3  |  Link
asdf013cv
for example, the prediction block is
4 5 6 7
8 9 10 11
12 13 14 15
if the prediction mode is 18, the reference row (after projecting) will be
if the prediction mode is 2, the reference column (after projecting) will be
4
8
12
is that right?
(how about other pixels? such as 5, 6 and 7.)
Old 29th July 2016, 22:08   #4  |  Link
FancyMouse
I don't understand what you mean. When you want to predict a block (meaning you have no knowledge on current block, and you try to guess the block using other information), you have some samples from above/left. You compute reference row/column from them. Then the prediction procedure fills the prediction of your current block using reference row/column (ultimately predict from above/left). You don't predict from the first row/column of the current block - you don't even have that information.
Old 30th July 2016, 11:50   #5  |  Link
asdf013cv
I always think I have the information about the current block...
Thanks a lot!
hevc. h.265, intra-prediction
