Old 7th January 2012, 01:55   #1  |  Link
vincentw56
Some MKV files lockup Windows Explorer
Sorry, I am a little new to this. Some of the MKV files I have won't play and seem to lockup Windows Explorer. I can't delete them, move them, etc. Could this be a codec issue? Seems weird to me.
Also, if I take one that plays fine, and open it using the mkvtoolnix GUI and merge or edit anything, the resulting MKV file will lockup Windows Explorer.
Any help would be appreciated.
Thanks
vincentw56 is offline   Reply With Quote
Old 7th January 2012, 01:58   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Probably a buggy shell extension
Try to run this command from an (elevated) console:
regsvr32.exe /u shmedia.dll
Old 7th January 2012, 02:12   #3  |  Link
Marin85
Do you have by any chance DivX thumbnail generator installed?
Marin85 is offline   Reply With Quote
Old 7th January 2012, 02:23   #4  |  Link
vincentw56
Tried the unreg command and that .dll isn't on my system (as far as I know). I did a search and didn't find it either.
I have the Divx codec, but I don't have Divx thumbnail generator. At least I don't see it listed anywhere. I only installed the Divx codec, not the full software.
Old 7th January 2012, 08:02   #5  |  Link
vincentw56
Looks like it was the Divx codec. I uninstalled it and installed the Community Combined Codec Pack and all is well. The movie wouldn't even play before and now it plays fine. Thanks for the suggestions.
mkv, mkvtoolnix
