Old 23rd September 2020, 19:41   #1021  |  Link
Ghitulescu
Ghitulescu's Avatar
It's the first time I hear that a player disobeys the commands
I think outgoing wanted to say that it's not enough to set the subtitles in one place, as the subsequent navigation may alter these (audio, angles etc.) somewhere else in the pathflow.
I made a guide on how to put series on BD (original menu or own menu - although the latter can be created with MultiAVCHD), yet at 2MB it's way above the handling possibilities of the forum. I also lingered for a guide, until I decided to read the documentation I have and try to understand "who's who" in BDEdit (which copies some data structures, literally). The same procedure I used for IFOedit (a similar thing) until the more user-friendly PGCedit arrived. Unfortunately most of the documentation is NDA, this may explain some but not all.
Born in the USB (not USA)
Old 3rd October 2020, 18:21   #1022  |  Link
AVX
any new on Pel??
AVX is offline   Reply With Quote
Old 10th November 2020, 10:10   #1023  |  Link
nsonline
I donated, and didn't receive anything.
So how can i get a download link.
nsonline is offline   Reply With Quote
Old 10th November 2020, 15:35   #1024  |  Link
LowDead
Elit Amans
Have patience, you will manually be sent the download link from pel.
//LD
Windows 11 Pro 64-bit, AMD Ryzen 9 5950X@3.40GHz, 32GB, NVIDIA RTX 2070 8GB, PIONEER BDR-S09XLT, ASUS BW-16D1HT, LG CX 65", Panasonic DP-UB820EB-K, Sony PS3 & PS5
LowDead is offline   Reply With Quote
Old 1st December 2020, 15:27   #1025  |  Link
no-one
lated version is 0.50b?
no-one is offline   Reply With Quote
Old 13th December 2020, 00:37   #1026  |  Link
Pelagic
Replicant
Pelagic's Avatar
BDedit 0.50b bug
Editing start time on 4K mpls not working
Only 3 of 4 values updated
File Type: zip 00040.mpls.zip (476 Bytes, 74 views)
There are 10 types of people in this world, those who understand binary and those who don't
Pelagic is offline   Reply With Quote
Old 26th January 2021, 03:20   #1027  |  Link
Frozen7
Hello, how many days does it take? I also donated a few days ago and I have not received anything at the moment
By Google Translate.
Frozen7 is offline   Reply With Quote
Old 27th January 2021, 11:21   #1028  |  Link
pel9
pel9's Avatar
Donation
Sorry guys, paypal stopped to notify me about donations so I can't send the download link immediately to you.
Please send me an email to pel@pel.hu if you want to receive the link sooner.
pel9 is offline   Reply With Quote
Old 17th February 2021, 02:13   #1029  |  Link
Frozen7
Hello, I need help, I am adding a subtitle track to a Japanese bluray, everything is fine at the time of playing the modified MPLS, the problem is when I want to select the subtitle track, it comes out blocked "cannot be chosen"
I tried adding "NOP" to default the subtitle track "49153" but it didn't work
PS: The bluray only has 2 audio tracks and does not have any subtitles.
Sorry for my english
Old 7th April 2021, 01:51   #1030  |  Link
Lear
A shot in the dark...
Can BDedit tell my simple, custom made bluray (authored in Adobe Encore) to stop resetting the audio track to default audio every time the Resume menu button is chosen in the main menu?
I've seen SetStream commands that set what audio or subtitle plays, but haven't seen instructions for how to get it to make no change such that whatever audio track was playing before the user hit the Menu button...should be the audio that resumes when the user hits the Resume menu button to return to the movie.
FYI, my menu has only 'Play' and 'Resume' buttons. There is only one title, and it has two audio streams (English and Russian).
Further (maybe unnecessary) info:
Doing some googling, I found this reply to a question for Encore CS5. It seems to suggest a general bugginess with Encore audio track selection.
The problem is that the generated Blu-ray instructions for selecting the subtitle (and audio) tracks is just plain wrong. The way it was supposed to work is that a GPR (general purpose register) was supposed to retain the selected value, but among other things the code always immediately clears the register after saving the correct value.
Lear is offline   Reply With Quote
Old 11th April 2021, 11:40   #1031  |  Link
gliniak
Kapitan Bomba
Menu edit errors
Hi guys.
i'm trying to edit menu of one uhd bluray, but BDedit constantly shows up errors. Doesn't matter if it's 0.45 or 0.50b6.
that's what i get when i'm trying to mux the menu, even untouched.
1: https://prnt.sc/119izqk
2: https://prnt.sc/119j06f
gliniak is offline   Reply With Quote
Old 14th April 2021, 09:22   #1032  |  Link
ocean
Hi gliniak, the problem is given by the empty spaces between png, post 204:
https://forum.doom9.org/showthread.p...07#post1896307
ocean is offline   Reply With Quote
Old 16th June 2021, 02:42   #1033  |  Link
FREEDONOR
How to disable subtitles in BDedit?
50400001 8001800A 00000000 SetStream GPR1,GPR10,(0),(0)
FREEDONOR is offline   Reply With Quote
Old 17th June 2021, 20:45   #1034  |  Link
outgoing
Be careful with deactivating a subtitle, if it has a button in the menu, then it is likely that it will also be deactivated in the menu and therefore the button will not work properly. If it is a forced subtitle then there will be no problem.
outgoing is offline   Reply With Quote
Old 18th June 2021, 19:46   #1035  |  Link
FREEDONOR
There is no button in the menu. These are the default subtitles in additional content. How do I write a command to disable them by default?
Old 19th June 2021, 23:10   #1036  |  Link
outgoing
In GPR commands I haven't tried it but you can try the following, first make a backup, maybe it will work.
50400001 8001800A 00000000 ---> 50400001 80010000 00000000
Old 20th June 2021, 03:57   #1037  |  Link
FREEDONOR
It didn't work. This is what the structure looks like. 005.006.007.008 these are four additional materials. And in each, subtitles are enabled by default.
Old 20th June 2021, 04:03   #1038  |  Link
FREEDONOR
50400001 8001800A 00000000 I made a mistake
51400001 8001800A 00000000 Correctly
Old 20th June 2021, 11:05   #1039  |  Link
outgoing
Try the following:
51400001 8001800A 00000000 ---> 51400001 80010000 00000000
Old 20th June 2021, 13:37   #1040  |  Link
FREEDONOR
Try the following:
It didn't work.
bd menu, bdedit, blu-ray
