1st December 2013, 20:08 | #12541 | Link |
is there a way to force eac3to to encode AC3 with libav instead of aften? Justin Ruggles himself said that libav is better than aften and aften shouldn't be used anymore... he should know, since he developed aften and is now involved in libav... is there a way to force eac3to to use it? is there any reason not to use libav by default?
also on a similar matter, any way to get eac3to to use the DTS-HD Master Audio Suite (if you own it) for encoding DTS? would definitely be an improvement to surcode... Last edited by Q-the-STORM; 1st December 2013 at 21:02. |
1st December 2013, 23:47 | #12542 | Link | ||
SuperVirus
5th December 2013, 10:15 | #12545 | Link |
6th December 2013, 01:26 | #12547 | Link | |
other question still remains, why is libav not used by default in eac3to? Last edited by Q-the-STORM; 6th December 2013 at 04:48. |
9th December 2013, 12:40 | #12549 | Link |
The "eac3to and more" GUI does not work well at my Windows 8.1. It looks blown out of proportion and many menus/buttons are hidden. I tried disabling DPI scaling and it still doesn't look right. Is there any way to fix it? Or are there any other GUIs for eac3to that have the same amount of options?
9th December 2013, 14:30 | #12550 | Link | |
Yes, I'm weird.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain |
9th December 2013, 18:35 | #12552 | Link |
One more thing: I'm trying to get eac3to to extract a 6.1 Discrete DTS-ES stream from a DVD (.VOB) into a 7-channel .dts file with no loss in quality. I have installed Arcsoft DTS decoder, but it will only work when I export it to .WAV or .FLAC (it's still lossless, but the exported files are, of course, unnecessarily large). Is there a bit-perfect method to demux the stream to a 7-channel .dts?
9th December 2013, 22:01 | #12553 | Link | |
eac3to "VTS_01_1.VOB"+"VTS_01_2.VOB" "output.dts" |
10th December 2013, 10:38 | #12554 | Link | |
10th December 2013, 10:46 | #12555 | Link |
How certain are you that the dts audio stream in the VOBs actually is 6.1 DTS-ES, and that the demultiplexed file is not anymore? Which tools did you use to check their properties?
30th December 2013, 14:56 | #12558 | Link | |
Anyone can help me how to properly extract this into FLAC?
eac3to |
