Old 26th October 2006, 21:07   #1381  |  Link
sillKotscha
what's this for?
sillKotscha's Avatar
Hi Kurtnoise13,
I have a question about the BeLight Log-file...
it states that two encoder are missing but AFAIK I should have all off them in my BeLight-Folder...
does BeLight doesn't recognize them - therefor the error message - or do I have wrong versions (= too old version?)
thanks in advance, Sill
Log:
my "installed" *.exe files:
my "installed" *.dll files:
EDIT:
btw, do I have obsolete files in my BeLight directory? And it is impossible to reach http://www.corecodec.org/frs/?group_...se_id=292#r292 at the moment... is there any other place to download dimzon's latest files?
latest mix sets: http://soundcloud.com/sill
sillKotscha is offline   Reply With Quote
Old 26th October 2006, 22:25   #1382  |  Link
slicksta
Processing mulitple files
Im trying transcode a whole heap of mp3s to mp4 or AAC+ to use in my W850 (sony/ericsson phone), but despite going over this forum, I cant seem to find a solution to getting more than 1 input file to process at a time. For some reason it only processes the last file in the list. I have a few thousand to do, so 1 at a time would take forever. Any help/advice appreciated. Im using 0.22beta9.
slicksta is offline   Reply With Quote
Old 26th October 2006, 22:49   #1383  |  Link
Bluedan
Bluedan's Avatar
@slicksta Your question has already been answered here.
Don't use drag'n drop, but open file(s) dialogue.
I'm probably misconfused...
Bluedan is offline   Reply With Quote
Old 27th October 2006, 12:58   #1384  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
This is not errors but just some warnings... Errors are reported with an other picture (the white cross with red background). Besides, BeLight works fine even these warnings.
I know there is a bug with enAacplusEnc. It's already fixed but I can't upload a new build at the moment as you can see...CC.org is down for me too. Maybe tonight...
About Aud-X encoder, this is not the right one. You just have to install Aud-X installer (BeLight uses the Aud-X encoder from Program Files\Aud-X\...) and that should be ok. Note that there is none obligation to install this compressor (only needed for mp3 surround).
About obsolete files : if you use NeroAACEnc.exe then aac.dll & aacenc32.dll are useless. Same thing with bsn.dll : if you use this last one then all bse_xxxxx.dll are not needed anymore.
Old 27th October 2006, 17:25   #1385  |  Link
sillKotscha
what's this for?
Hi Kurtnoise13,
thank you for the answer.
Old 28th October 2006, 16:51   #1386  |  Link
TheManuel
.avi and Aften
Is there a daily build of BeLight that supports both .avi files as input and the Aften encoder?
TheManuel is offline   Reply With Quote
Old 28th October 2006, 16:59   #1387  |  Link
Kurtnoise
Kurtnoise's Avatar
Nope...but avi support will be included soon.
Old 28th October 2006, 17:58   #1388  |  Link
TheManuel
Great! I look forward to that.
Thanks for sharing your work.
Old 29th October 2006, 01:43   #1389  |  Link
Audionut
Hi, I'm trying to mux 6 mono wav files to a 5.1 wave file. But all i'm getting is noise in return.
The transcode finishes completely and the file is created.
Old 2nd November 2006, 04:33   #1390  |  Link
slicksta
"@slicksta Your question has already been answered here.
Don't use drag'n drop, but open file(s) dialogue"
Like I said Ive been over this entire forum. This was the first thing I tried. For some reason its still not working. Only transcodes one file from the list. Am I missing something?
I tried different encoders as well as previous Belight versions, & still no go. Any suggestions/solutions?
Old 2nd November 2006, 07:23   #1391  |  Link
m0rtal
open source addict
m0rtal's Avatar
I have same issue
latest daily build, latest stable - doesn't matter...
Software is like sex - better when it's free!
m0rtal is offline   Reply With Quote
Old 2nd November 2006, 09:14   #1392  |  Link
Bluedan
Bluedan's Avatar
Indeed. Slicksta, sorry, you were right. I confirm.
Old 2nd November 2006, 10:44   #1393  |  Link
m0rtal
open source addict
m0rtal's Avatar
so it's a common problem? :-\
Old 4th November 2006, 07:06   #1394  |  Link
slicksta
Thanx for confirming Bluedan
Any suggestions Kurtnoise?
Old 5th November 2006, 10:38   #1395  |  Link
Kurtnoise
Kurtnoise's Avatar
Wait a new build...or use fb2k.
Old 5th November 2006, 16:45   #1396  |  Link
MacAddict
XviD User
The AC3 384kbps preset enables 'hybrid' gain. Is this correct or should I use 'pre-gain'? I'm using the Aften mode so should I have anything else turned on within the 'advanced' window such as DNR?
Any info is much appreciated. Thx again for such a great app!
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2
MacAddict is offline   Reply With Quote
Old 5th November 2006, 16:56   #1397  |  Link
Kurtnoise
Kurtnoise's Avatar
What kind of source do you have ?
Old 6th November 2006, 05:53   #1398  |  Link
MacAddict
XviD User
My source is 448kbps AC3. Just curious what people are using.
Old 6th November 2006, 09:29   #1399  |  Link
Kurtnoise
Kurtnoise's Avatar
Well, Hybridgain or PreGain don't hurt transcoding you know...Same thing for DNR.
Old 7th November 2006, 03:14   #1400  |  Link
MacAddict
XviD User
So DNR really has no effect when transcoding high bitrate AC3 to lower bitrate? Interesting! Thx
