24th March 2005, 10:39 | #361 | Link |
6502 fan
and with 0.22 beta 1 when I add ac3 and select convert to wav,
it has an progressbar quickly go to filled full (there two labels showing 0%). and wait some minutes,they fill from null fo full second pass. is the problem been reported? windows 2003,besweet 1.5b29,belight 0.22 b1, |
24th March 2005, 13:52 | #362 | Link | |
Swallowed in the Sea
24th March 2005, 14:55 | #364 | Link | |
6502 fan
just means the progressbar gone full in 6sec,and progress label still freeze on %0. this ac3 file was ripped from Gundam seed episode 24,77M,2ch,24min07 and i have an ac3 that has right progressbar as progress,but at end 100% of 2nd pass get an error message:"Transcoding aborted",the result wave were comletive too. 7M,2ch,04min55 |
24th March 2005, 16:31 | #365 | Link | ||
24th March 2005, 22:55 | #366 | Link |
Posts: n/a
Feature request (maybe call it bug fixing).
If I transcode file.mp3 (128k) to file.mp3 (64k) belight should first write a temp file something like file.mp3.tmp and when the transcoding is complete delete original file.mp3 and rename file.mp3.tm to file.mp3. Right now if I do such a thing a 0 byte file is generated. Add GUI options for permanent command line switches like -noid3 and removing the -logfile switch. Thanks and keep up the good work |
24th March 2005, 22:57 | #367 | Link | |
Posts: n/a
25th March 2005, 09:23 | #368 | Link | |||
It could be dangerous to delete original file if you have miss something in the command line... Quote:
29th March 2005, 19:36 | #369 | Link | |
Posts: n/a
Can you make the advanced settings store in a file also like the codec setings...like if I select disable log file it is always like that and the file can have a text entry like "logfile=0" Bug Report: when I add a file.mp3 and select bitrate etc in the mp3 tab then I edit the command line to change file-new.mp3 to file2.mp3 and run it instead of using file2.mp3 it still uses file-new.mp3 as the name of the file. After clicking run the command like window doesnt disappear which I think should happen. Just a question wouldn't it be better using the besweet.dll instead of the exe? Last edited by aliumalik; 29th March 2005 at 19:44. |
30th March 2005, 18:09 | #370 | Link | ||||
30th March 2005, 18:30 | #371 | Link | ||
Posts: n/a
Another request when "Restrict encoder to cbr" is checked the bar in mp3 tab should move in jumps i.e from 64 to 128 to 160 to 192 (just like mp2 tab)... right now it works ok if the slider is around the bitrate but seems slightly confusing. A request for the future...I think this should be targeted at the BeSweet author but using the tag library from http://www.neilpopham.pwp.blueyonder.co.uk/tag.html tag retention could be added. Last edited by aliumalik; 30th March 2005 at 18:34. |
30th March 2005, 19:51 | #372 | Link | |||
31st March 2005, 17:29 | #373 | Link |
Hi Kurtnoise13,
I just discovered you GUI by chance seeing it in your sig and I went to check it out. I must say I was really impressed with it and have now switched to your GUI. I find the default BeSweet GUI a bit mind boggling and confusing at times but your one is easier on the eyes and far better laid out and easier to get to grips with for noobs. Great work I wish you luck with furthur development and improvements. Keep up the great work. Love this GUI.
Regards Michael. |
18th April 2005, 00:40 | #379 | Link | |
Source is ac3, producing aac. At the end it says "Transcoding aborted" in info field, but the resulting file plays fine so far, correct length. If possible in any way, the "pregain" progress should be indicated as such, or as a job itself. It was confusing that at first both the current track and total progress bar quickly reached 100% and then restarted while as seen below the total bars percent indication shows o% all the time. Apart from this, great job, Kurt!
I'm probably misconfused... Last edited by Bluedan; 18th April 2005 at 00:44. |
18th April 2005, 08:48 | #380 | Link | ||
Sorry for the delay concerning the new release...I try to add lst & mux input files and it's not easy with the new batch mode. |
