Old 14th August 2010, 00:46   #21  |  Link
-Vit-
Originally Posted by Didée View Post
Yeah, hard-loading a plugin in the script is not nice.
Fair point. I wanted to avoid requirements on the calling script, but I see that leads to other problems. Happy to get rid of that bit of ugly really.
I've put an updated version in the OP that doesn't explicitly load Yadif.
-Vit- is offline
Old 17th August 2010, 20:00   #22  |  Link
-Vit-
Found a reproducible MT instability when using Super Fast and Ultra Fast presets, with mt_average throwing an exception. Couldn't say if the problem originated in mt_average or not because the particular setup was complex and unusual. However, replacing mt_average with merge remedied the situation. A quick test seems to show merge to be faster in any case. Updated version in the OP.
-Vit- is offline
Old 20th August 2010, 09:46   #23  |  Link
Bi11
Architect
Bi11's Avatar
Great work!
Just a few suggestions:
  • Supply sclip to eedi3 for more accurate interpolation.
    For example,
    (EdiMode == "EEDI3")    ? ediInput.EEDI3(sclip=ediInput.NNEDI3(field=-2, nsize=NNSize, nns=NNeurons, qual=EdiQual), field=-2, mdis=EdiMaxD) : \
  • Super-sampled eedi3 after QTGMC removes most residual aliasing.
    For example,
    QTGMC(EdiMode="eedi3", Blocksize=8, Overlap=4, Search=5, SearchParam=4).SelectEven()
    w=width h=height
    lanczosresize(w*2,h*2,taps=8).eedi3().lanczosresize(w,h,taps=8)
  • RestoreLossless is called with only some parameters in the script. Why not pass all parameters it expects?
  • IMHO the ShowSettings output could be more spaced apart, like
    		addNoise.Subtitle( "tr0=" + string(tr0) + " | tr1=" + string(tr1) + " | tr2=" + string(tr2) + " | rep0=" + string(rep0) + " | rep1=" +  string(rep1) + \
    		" | rep2=" + string(rep2) + "\nEdiMode='" + EdiMode + "' | NNSize=" + string(NNSize) + " | NNeurons=" + string(NNeurons) + " | EdiQual=" + \
    		string(EdiQual) + " | EdiMaxD=" + string(EdiMaxD) + "\nSharpness=" + string(Sharpness, "%.2f") + " | SMode=" + string(SMode) + " | SLMode=" + \
    		string(SLMode) + " | SLRad=" + string(SLRad) + " | SOvs=" +  string(SOvs) + " | SVThin=" +  string(SVThin, "%.2f") + " | Sbb=" + string(Sbb) + \
    		"\nSrchClipPP=" + string(SrchClipPP) + " | SubPel=" + string(SubPel) + " | SubPelInterp=" + string(SubPelInterp) + " | BlockSize=" + string(BlockSize) + \
    		" | Overlap=" + string(Overlap) + "\nSearch=" + string(Search) + " | SearchParam=" + string(SearchParam) + " | PelSearch=" + string(PelSearch) + \
    		" | TrueMotion=" + string(TrueMotion) + "\nLambda=" + string(Lambda) + " | LSAD=" + string(LSAD) + " | PNew=" + string(PNew) + " | PLevel=" + string(PLevel) + \
    		" | GlobalMotion=" + string(GlobalMotion) + " | DCT=" + string(DCT) + "\nLossless=" + string(Lossless) + " | LosslessTR=" + string(LosslessTR) + \
    		" | LosslessEdi='" + LosslessEdi + "'\nNoiseBypass=" + string(NoiseBypass) + " | NoiseRemove=" + string(NoiseRemove, "%.2f") + " | NoiseRestore=" + \
    		string(NoiseRestore, "%.2f") + "\nNoiseDeint='" + NoiseDeint + "' | Sigma=" + string(Sigma, "%.2f") + " | BT=" + string(BT) + "\nBorder=" + \
    		string(Border) + " | Precise=" + string(Precise) + " | SafeMode=" + string(SafeMode) + "\nPreset='" + Preset + "' | Tuning='" + Tuning + "'", \
    		font="Lucida Console", size=11, lsp=12 )
Bi11 is offline
Old 24th August 2010, 15:58   #24  |  Link
-Vit-
Originally Posted by Bi11 View Post
Great work!
Thank you, and thanks for the feedback.
The EdiExt parameter allows you to use any interpolator:
clip.QTGMC( Preset="Slow", EdiExt=clip.EEDI3(sclip=clip.NNEDI3(field=-2), field=-2) )
I work with naturalistic sources, so I almost exclusively use NNEDI2/3. So when it came to adding EEDI3, I just followed the style that TempGaussMC had used for EEDI2. I didn't think to use the new sclip parameter. The EdiMode strings are just shortcuts for the most common use cases. Bearing that in mind, do you think I should update EdiMode="EEDI3" to use "sclip" or add a new EdiMode="EEDI3x"...
____
I assume this is an observation rather than a suggestion?
____
The lossless code is a second simpler deinterlacing pass on the difference between the initial TGMC output and the source. As such it has some similar parameters to the main deinterlacing script. However, I'm not necessarily convinced that the same parameter values would be the most effective. I'm not unconvinced either, I just haven't had the time to test in detail.
The difference image is quite different in nature to the original source. It's largely gray (the origin, i.e. no difference, is at 128), with the edges made prominent (due to changes from the blur->resharpen tgmc process) and areas of noise (that removed by tgmc). One observation is that interpolator choice is slightly different here. NNEDI2 works OK, but even for naturalistic sources I found EEDI3 to work well, probably because of the prominence of edges in this difference image. Then again changes made to the lossless deinterlacing parameters are much less noticable than in the main script as it is working with small values.
I added the parameters to the lossless function out of good practice / coding habit. However, I don't think I want to add so many more parameters to the script itself as I'm reaching the limit. So if necessary I may add a boolean "LosslessDefaults" or similar, which determines whether to use the main deinterlacing parameters for the lossless step too, or whether to use the default lossless settings instead (as it does now). One reason to favor the defaults would be to speed up lossless scripts using high quality settings, which would be overkill if passed to the lossless step. Memory use is currently high when using lossless (especially MT), another reason to use simpler settings on that step.
____
IMHO the ShowSettings output could be more spaced apart, like...
I like it, thanks. I will update to something like this in the next revision.
-Vit- is offline
Old 25th August 2010, 14:07   #25  |  Link
Bi11
Architect
Bi11's Avatar
Yes, I've noticed.
Because my live sources are usually crappy quality, I usually use QTGMC like so:
edi=eedi3(sclip=nnedi3(field=-2,nsize=3,qual=2),field=-2,vcheck=3).raa()
QTGMC(ediext=edi,blocksize=8,overlap=4,search=5,searchparam=4).selecteven()
# Residual Anti-Aliasing
function RAA (clip input) {
w=input.width()
h=input.height()
input.spline64resize(w*2,h*2).eedi3(vcheck=3).spline64resize(w,h)
It's fairly aggressive at connecting straight lines, giving smooth lines and curves with little or no flickering.
I haven't tried eedi3/nnedi2, but from my observations eedi3/nnedi3 always gives more accurate interpolation and less artifacts than eedi3 alone when used for deinterlacing. So IMO sclip=nnedi3 should be the default.
I use vcheck=3 instead of the default vcheck=2 because it gives a bit less artifacts imo.
I use blocksize=8 and overlap=4 because from my observations it gives noticeably better quality than the defaults 16/8.
search=5 and searchparam=4 gives slightly more accurate motion vector search.
raa() is the super-sampled eedi3, which I use just after deinterlacing to smoothen any remaining jagged edges. raa() could be an optional feature, which could be included in some of the slower presets.
With regard to the lossless parameters, I understand now that higher quality settings may not be worthwhile. If anything, you could have a LosslessPreset option, which takes one of the preset values already defined, and uses the parameters it requires from that preset. But is there really a big difference in overall speed if lossless settings are the same as the preset settings, considering it's a difference clip that's being interpolated?
On a related note, I would like for a possible way to keep the EdiMode and LosslessEdi values in sync. Currently, if I specify LosslessEdi="nnedi3" then the script still tries to use nnedi2, which is not in my plugin directory.
One possible solution is to have LosslessEdi default to EdiMode, and a different LosslessEdi value can be explicitly specified if needed.
Bi11 is offline
Old 26th August 2010, 12:20   #26  |  Link
yup
-Vit-!
Which version I could use wit SET 2.6 Avisynth mt_masktools-25.dll or mt_masktools-26.dll.
I get constantly crash.
yup.
yup is offline
Old 26th August 2010, 15:01   #27  |  Link
henryho_hk
Can you add an int parameter "NNEDIthreads" to control the number of threads of nnedi2/3?
henryho_hk is offline
Old 26th August 2010, 16:57   #28  |  Link
yup
I remove
 Lossless=1
and now work O'k both version masktools 2.5 and 2.6 with Set Avisynth 2.6 MT build.
yup.
yup is offline
Old 19th September 2010, 08:52   #29  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
This script is insanely awesome. I'm so thoroughly impressed with the quality / speed ratio. Wow.
Blue_MiSfit is offline
Old 23rd September 2010, 20:04   #30  |  Link
ajp_anton
ajp_anton's Avatar
In the defaults, I think Overlap is supposed to be Blocksize/2 and not bs/s.
ajp_anton is offline
Old 23rd September 2010, 22:54   #31  |  Link
-Vit-
Well spotted, thanks. If you provided an explicit blocksize but left the default overlap then it would mistakenly base the overlap on the default blocksize. I've upped a fixed version in the first post.
____
I've been a bit busy of late but I have noted the suggestions that people have been making. I will be upping a new version relatively soon - just need to find the time to test. I mainly want to update the use of EEDI3 / NNEDI3 (particularly now NNEDI3 is faster).
-Vit- is offline
Old 9th October 2010, 13:11   #32  |  Link
Hagbard23
23sKiDdOo!
Hagbard23's Avatar
so true...
I've tried it with my old futurama PAL Discs. This Plugin is so f***ing good - it blasts me off the chair. OK Speed is no issue here... . I used it successfully with needi3 and preset "slower" and the result was perfect "placebo" pure progressive output.
Didee and ViT: Please keep up the good work - we strongly needed those two (tgmc / qtgmc) plugins.
Hagbard23 is offline
Old 11th October 2010, 12:17   #33  |  Link
Hagbard23
23sKiDdOo!
Hagbard23's Avatar
Nah...after tweaking for hours i found a "bug" now...:
I can't run any filters (i've tried warpsharp & fft3dgpu) after QTGMC? ViT do you know anything about it?
Old 11th October 2010, 13:01   #34  |  Link
aegisofrime
FFT3DGPU works fine here. You have to SetMTMode(5), but that's not specific to QTGMC since you have to do that in any multithreaded script.
aegisofrime is offline
Old 11th October 2010, 13:12   #35  |  Link
Didée
What's the actual problem? Does the additional filter simply have no effect, or does the script crash? If so, what's the error message?
Didée is offline
Old 11th October 2010, 13:20   #36  |  Link
Hagbard23
23sKiDdOo!
Hagbard23's Avatar
dgsource("E:\blah\VTS_01_1c.dgi")
assumetff()
QTGMC(EdiMode="NNEDI3")
awarpsharp2()
FFT3dGPU()
crop(12,2,-10,-0)
spline36resize(720,544)
That was the script..
(meanwhile i returned to TGMCBeta2, (w. NNEDI2). This worked just fine.)
With that script Virtual Dub crashed with some AccessViolation Error - sometimes i got "AviSynth Failure - Unknown Exception" when i seeked around in the video...
@aegisofrime
SetMTMode(5)
I worked without multithreading...
Old 19th October 2010, 01:02   #37  |  Link
-Vit-
I've used many different filters both before and after QTGMC without problem. Both single and multi-threaded. Unfortunately, the error message isn't very specific. Do you get the same effect if you use "NNEDI2" in QTGMC? Do you get errors in anything other than VirtualDub?
Only thing that I can think of is memory use. The script shouldn't use more memory than tgmc-b2 when using the "Slower" preset, but I don't know about NNEDI3's memory usage - it's a long shot but maybe that just tipped things over the edge. Try adding a SetMemoryMax at the start of the script...
-Vit- is offline
Old 19th October 2010, 10:49   #38  |  Link
Shon
-Vit-
What should I do to work only deinterlace, but the noise was not removed?
Shon is offline
Old 20th October 2010, 13:18   #39  |  Link
-Vit-
Originally Posted by Shon View Post
-Vit-
I'm not sure I understand. Are you asking how to keep the noise from the source? Or how to remove it? Here are both solutions...
Keep noise:
QTGMC( Preset="Slower", NoiseBypass=1, NoiseRestore=1.0 ) # Mode 1: Remove noise before, add back after. Medium effect
#or
QTGMC( Preset="Slower", NoiseBypass=2, NoiseRestore=0.4 ) # Mode 2: Get noise at start but don't remove it, add back after
                                                          # Stronger effect. Increase NoiseRestore for an even stronger
                                                          # effect (>1 for a very strong effect)
#or
QTGMC( Preset="Slower", Lossless=1, LosslessTR=3 ) # Lossless modes also retain noise. Combine with noise bypass if you want
Remove noise:
QTGMC( Preset="Slower", NoiseBypass=1, NoiseRestore=0.0 )
#or
QTGMC( Preset="Slower", Sigma=2.5, NoiseBypass=1, NoiseRestore=0.0 ) # Increase Sigma for noisier source (default is 2.0)
-Vit- is offline
Old 22nd October 2010, 04:41   #40  |  Link
Shon
-Vit- I needed a first option. Thank you!
Shon is offline
