22nd October 2012, 16:00 | #14981 | Link |
Nicolas Robidoux
Non, mais je parle le joual. http://en.wikipedia.org/wiki/Joual
22nd October 2012, 17:10 | #14983 | Link |
Nicolas Robidoux
Ah! With the optimization criterion that gives 0.981..., it does not make a difference if you restrict yourself to a 6x6. (It makes a difference with the other criterion.)
So: Just keep 0.981..., the deblur I would guess works best for Jinc3 with AR. |
22nd October 2012, 17:23 | #14985 | Link |
madshi, can you figure out why this file won't deinterlace with any field order setting in MadVR? I have a feeling MKV Merge is to blame but I'm not sure. EVR struggles with it too - stepping frame-by-frame shows it deinterlaces properly but plays at 46-48 fps instead of 50 and has a bit of a dodgy graph, resulting in jerkiness.
Sample Clip The original TS file plays fine using both EVR and MadVR.
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7 |
22nd October 2012, 17:25 | #14986 | Link |
I'm sorry, but if the original file plays fine then it can't be madVR's fault, can it? I really don't have time to look into how mkvmerge might have screwed things up. It's already more than enough work to only work on my own bugs...
22nd October 2012, 17:33 | #14987 | Link | |
LG Pioneer (kuro) Panasonic I bought the 60" LG plasma in the fall of 2010. By the spring of this year (1,5 years) I was unable to get it to display the blacks that it initially had during the first period. It became so bad (black was literally grey) that I simply decided to sell it and got Sony's top-model LCD in 55", and now after half a year I still think it's the best TV I ever owned. Ok, 5" down in screen size but the 65" model was too expensive, he he. Bottom line: For plasmas, take the manufacturer claimed brightness reduction time with a grain of salt. I know the previous gen (2011) Panasonics also had this problem.
SETUP: Win 10/MPC-HC/LAV/MadVR HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750 |
22nd October 2012, 18:15 | #14989 | Link | |||
This video illustrates how Plasma draws its image: http://www.youtube.com/watch?v=tGpdah32n3c Quote:
For what it's worth, some of the best LCD panels out there are approaching 5,000:1 native contrast, and it is only this year that Panasonic has managed to exceed that. Edge LED and "local dimming" (ha!) Edge LED sets really aren't any good in my opinion. However, the best local-dimming sets that use a full array backlight with hundreds of zones combined with a high contrast panel (for example LG try it with 1,000:1 IPS panels and it looks terrible) will exceed Plasma contrast easily with very little haloing. Examples would be the Sharp Elite and Sony's UV2A HX900. (I hear the newer Sonys with Samsung panels fare worse) Even the Kuros with their 30,000:1 CR (when calibrated) weren't nearly enough for me, because they still never look black in a dark room. Local dimming achieves that with ease. Image retention is still a very real issue with Plasma despite what people claim online. (just try only watching 2.37:1 films for a while, or getting hooked on a game for a week without watching anything else and see how "resistant" they really are...) Plasma still doesn't handle ambient light very well, though they are getting better with it these days. The thing that kills Plasma for me though, is the "ABL circuit" which starts to dim the screen when the image gets over a certain brightness. With most plasmas you lose over half their brightness when you go from a small white window pattern and a full white screen. It makes bright daylight scenes in films look dull/washed-out, and is a considerable problem if you play games or want to use the screen with a PC. (not that I recommend either due to image retention) It's not an issue of the image not being able to go bright enough - I only watch at reference levels (100cd/mē) but that to achieve that brightness with "brighter" images, you need to calibrate the panel to 200cd/mē or more, which is far too bright for a dark room, or try and compromise somewhere in-between where the image is too bright in some scenes but not bright enough in others etc. LCD does not have this problem at all, and while it affected CRTs, most were well within 10% of their calibrated brightness, not 50% or more. Motion handling is moot between the two technologies these days. Now that scanning backlights have been introduced, LCDs can match or exceed Plasma motion handling due to the reduced persistence on the retina. (but it may introduce some degree of flicker if you are sensitive to that) On the plus side, Plasmas actually have a good image when viewed off to the side, if that is a concern for you (I never sit to the side of my TV) because even the best IPS panels still look terrible when you aren't sitting directly in front of them. They also update the panel progressively, so fast motion won't skew like it does on LCDs. I agree with your sentiment on the life of these displays - it isn't something you should be concerned about with either LED sets or Plasma, though Plasmas did have a tendency to die early due to power supply failures. Modern Plasma is considerably more efficient now though, so that should be less of a concern. Another thing is that Plasmas are significantly cheaper to get a well calibrated, high contrast image than LCDs. Panasonic's Plasmas are very cheap compared to LED backlit LCDs. (not edge LED) If Plasmas image quality problems or other potential issues are not a concern for you, Panasonic's Plasmas have by far the best price/performance ratio out there today. Quote:
I keep seeing the price of a good DLP projector drop and thinking I should buy one again, but I don't really have the space for one now. (there's no way I would buy another SXRD - they're far too soft, and motion handling sucks, JVC's D-ILA is far too expensive, and has similar problems) Last edited by 6233638; 22nd October 2012 at 18:17. |
22nd October 2012, 18:47 | #14991 | Link | |||
Strange enough, people here are clever enough to know that one bad LCD model doesn't mean all LCD models are bad, and that there are different LCD panels with very different properties and problems. But then, 3 different people now mentioned bad LG plasmas, without really acknowledging that maybe not every plasma is the same. Quote:
Anyway, we've now heard enough pro and con views about LCD vs. plasma, I think. So maybe we should really give it a rest now? |
22nd October 2012, 19:12 | #14992 | Link | |||
Exactly those might end up wrong coulored in MadVR when Madshi would implement EBU for *all* 25fps SD content, even with additional check in WxH. Quote:
Does this mean we should abandon all (up)scaling from our avisynth scripts if we use these to encode !!? Strong statements you make here, I must say... Quote:
CCFL has a higher black-point and a much less stable curve at low Y. From the physical POV, controlling a CCFL at low output is much harder than walking over a cord ! The only reason that CCFL is still in the market is price €/m2 compared to LED and other. Last edited by Pat357; 22nd October 2012 at 19:49. |
22nd October 2012, 19:28 | #14993 | Link | |||
For what it's worth, Pioneer's driving scheme meant that they had very limited gradation, and had to use a lot of dithering. At anything other than 60Hz, gradation was extremely poor. Blue phosphors are still considerably quicker, and red/green still have mis-matched responses. Here is a chart from Panasonic a couple of years ago when they switched to newly developed phospors to better meet the requirements of 3D: Quote:
As someone that has owned, tested and reviewed Plasmas from a number of manufacturers, I can tell you that it affects them all. Quote:
With a well-calibrated full array LED set, I think your opinion would change. I don't like edge LED sets at all though, the uniformity is too bad, and they have far too few zones for dimming to be effective. (16-32 at best I think?) |
22nd October 2012, 19:28 | #14994 | Link | |
QuickSync Decoder author
BTW, all the samples he showed belong to the "flat world" class - focus distance is identical to all pixels. Since (out of) focus blurring can be measured and approximated, finding the inverse filter is doable. It gets really hard when there're multiple areas in the image with different distances. The CSI style operation is usually done by applying weak deblurring kernels again and again to smooth parts of the image. The trick is when to stop. It never looks really good in end but some details can surface. So the CSI use case is valid but fixing your home photos will not work right. I've read what you wrote on the Jinc function in your website. Basically an ellipse (2D) shaped Sinc like function (right?). But I didn't see any head to head compares against Lanczos. Is the Jinc AR algorithm proprietary?
Eric Gur, Processor Application Engineer for Overclocking and CPU technologies Intel QuickSync Decoder author Intel Corp. |
22nd October 2012, 19:38 | #14995 | Link | ||
Kid for Today
Avisynth? processed in 8bit? Yes, this will temper with the PQ I'm afraid and encoding upscaled pixels is a waste of bits. We can easily upscale at playback by setting the right DAR. Last edited by leeperry; 22nd October 2012 at 19:43. |
22nd October 2012, 19:40 | #14996 | Link | |
Nicolas Robidoux
----- Basically: Take the inverse Fourier transform of the characteristic function on a centered interval (a.k.a. the "ideal low pass filter") in 1D -> Sinc Take the inverse Fourier transform of the characteristic function on a centered disc in 2D -> Jinc. ----- All my stuff is academic research with no patents or what not. (I am an ex-prof.) This includes the million variants of EWA LanczosSharp = Elliptical Weighted Averaging Jinc-windowed Jinc, the basis of madVR's Jinc method. It builds on ideas of, among other people, Paul Heckbert, Andreas Gustafson (and, I would guess, his thesis advisor Heikki Saikkonen), Craig deForest and Anthony Thyssen. AR is Mathias Rauen's baby, and I'm not in a position to comment on legalese. Last edited by NicolasRobidoux; 22nd October 2012 at 20:04. |
22nd October 2012, 19:55 | #14997 | Link |
Nicolas Robidoux
@Eric Gur: I don't have a ready made head to head comparison of plain vanilla tensor Lanczos and EWA LanczosSharp (=madVR's Jinc3 AR minus the AntiRipple, which again, is Mathias' private baby).
But you can easily do one yourself. (Warning: I'm a *n*x snob.) Install HDRI ImageMagick http://www.imagemagick.org/script/hi...amic-range.php, for otherwise you get a version of tensor Lanczos that has clipping artifacts. Once it's done: convert input.png -filter Lanczos -resize 800% output.png gives you plain tensor Lanczos 3-lobe, while convert input.png -colorspace RGB -filter Lanczos -resize 800% -colorspace sRGB output.png gives you gamma corrected results. To get EWA LanczosSharp: convert input.png -filter LanczosSharp -distort Resize 800% output.png convert input.png -colorspace RGB -filter LanczosSharp -distort Resize 800% -colorspace sRGB output.png If you have a reasonably standard 16-bit (not HDRI) version of ImageMagick, the above code will give you correct EWA LanczosSharp results, so if you generate the Lanczos results with some other piece of software, you can compare. ---- If you want to discuss the EWA Jinc part of this (but not AR, which again is linked to madVR), I suggest you take it to the ImageMagick Forums http://www.imagemagick.org/discourse-server/index.php. P.S. You may want to use a non-bleeding edge version of ImageMagick: A png conversion bug appeared sometime in the last few releases (2 weeks ago? IM updates about 6 times/month). It affects, among other things, 3-channel greyscale. Last edited by NicolasRobidoux; 23rd October 2012 at 13:50. |
22nd October 2012, 20:00 | #14998 | Link |
Nicolas Robidoux
The disc becomes an ellipse when you warp. For aspect ratio preserving resize, it's always a perfectly round disc.
Elliptical Weighted Averaging was invented to deal with perspective transformations, and is commonly used for splatting. Using it to resize is a recent development. To make it competitive required "a few tweaks". Last edited by NicolasRobidoux; 22nd October 2012 at 20:03. |
22nd October 2012, 20:05 | #14999 | Link | |||
Jinc itself is available in open source software ImageMagic (they call it "EWA LanczosSharp", IIRC). The madVR AR filter is an add-on and is my private invention. madVR is closed source and I've not fully explained the AR algorithm anywhere in all detail. I'm still constantly tweaking the algorithm, anyway, so it's not final yet. I might be willing to explain how it works in concept, but I don't plan to publish the source/shader code. I don't want to make it too easy for my renderer competitors to simply copy my work with zero effort. FWIW, I've already explained some of the basics in this thread: http://forum.doom9.org/showthread.php?t=145358 |
22nd October 2012, 20:07 | #15000 | Link |
Any more details?
Do you scale using 1 pass in 2D? 2 passes in 1D? 2 passes in 2D? Does it work well in YCbCr? Is it any better or worse in linear light?
