13th March 2012, 20:35 | #12761 | Link | ||
14th March 2012, 06:37 | #12763 | Link | |
I just wanted to make sure I was correctly using (and understanding madVR's inverse telecine... MikeY similar EDIT to my last post - I think I "get it" now...I can get IVTC to be enabled if I force "film mode" and turn on madVR de-interlacing on a 29i interlaced DVD (mpeg2.) Why would I do that in the first place though instead of leaving it in video-mode? Am I simply confused since I never watch DVD-movies? (I only use DVDs for videos such as Simpsons or Futurama.) I only watch movies in Blu-Ray or HD-MKV formats. I apologize for the wasted posts if this revelation is correct. Last edited by Mikey2; 14th March 2012 at 07:44. |
14th March 2012, 08:31 | #12764 | Link |
I apologize for the double post; but this time I have a real problem - I promise.
Like many people, since installing madVR in MPC I received the error "DVD: Macrovision fail" when trying to open a DVD. This is old news - I fixed it by doing the following: DVD Macrovision qdvd fix However, as of the new version of madVR, I cannot play DVD's anymore. MPC simply freezes up. (It simply says "not responding" and I have to use task manager to shut it down.) (For my previous posts, I accessed the VOB files directly; however, for several reasons, this is troublesome on several DVDs/) I tried rolling back the qDVD fix and a few other things, such as trying various mpeg2 decoders, eliminating extraneous filters like ReClock, but nothing seems to work. Any ideas? Last edited by Mikey2; 14th March 2012 at 08:33. |
14th March 2012, 08:48 | #12765 | Link | |
14th March 2012, 15:52 | #12766 | Link | |
Hi madshi, I have 2 problem:
1. Regarding the fix on v0.81 Quote:
2. I'm using 2 monitors setup (extended). When FSE in main monitor, all the stuff in 2nd monitor will keep lost focus as if the video is trying to take all the focus. This made me couldn't type or open anything properly. If I FSE in the 2nd monitor, everything works fine on main monitor. I'm using MPC-HC 1.6.1.4144, madVR 0.82.5, ATi Mobility HD4670. Do I need to create debug log or something ? |
15th March 2012, 20:04 | #12770 | Link |
madshi, today I had a situation where the image after seeking seemed to freeze and then start flickering. The decoder queue started showing huge numbers like 17-26 / 12. Sound kept running fine in the background, just the image never appeared correctly.
I don't know how that could happen. If I can reproduce is there anything I can do to help? All I did today was take a screenshot showing the strange figures. EDIT: I'm using Windows 8 CP 64bit, seeking in non fullscreen windowed mode,mpc-hc, lav video decoders 0.49. Last edited by mark0077; 15th March 2012 at 20:07. |
15th March 2012, 20:28 | #12771 | Link | |
Attached the logs. Click file > save as for the zip file, or click on individual text files, as appropriate. |
16th March 2012, 03:50 | #12772 | Link |
Mad,
I got an error message on the "dbghelp.dll" included in the zip from Madvr v0.82.5. The first thing I did after booting up was start MPC with Madvr. When I wanted to look with Systinternals Process Explorer, I got the message saying that the "dbghelp.dll" was not for my windows version (Win7 Prof x64). I came on a link to the Microsoft site to download a "debug" package. Is the included version from maybe XP / older version of a develop tool ? In my windows dir I have dbghelp.dll v6.1.7601.17514, the one included is 6.12.0002.633. Can I replace the one in the Madvr directory with this one ? Or is it better the remove it and let windows use its own ? I noticed that mine has a lot of dependencies , while yours has only 4 or so. Yours is probably one with most needed files statically linked in. It's obviously not a big issue, but i thought it's better to let you know : maybe next release with an updated dbghelp.dll. Last edited by Pat357; 16th March 2012 at 03:54. |
16th March 2012, 08:30 | #12773 | Link | |
Also, I have a silent film on Blu-ray @1080i that seems to have an odd cadence... madvr's IVTC won't identify the cadence at all, it'll just say "unknown". There is very slight combing without any IVTC or deinterlacing applied, but with IVTC the combing seems to go away. Playback @ 60Hz seems to be smooth, but I get frame drops when I try @ 24Hz. I can provide a short sample if you'd like Thanks, that fixed it. |
16th March 2012, 09:23 | #12774 | Link | |||||||||||||||
What I wrote above only applies if you are using the "delay playback start until..." option in the madVR settings. You're using that option, right? The reason why I changed it was that some users still has stuttering at playback start and after a seek, which seems to be gone now with the latest madVR version. Some users having slower seeking now is not nice, of course, but I think it's a smaller problem compared to the stuttering some other users had. Quote:
With which codec (MPEG2, VC-1, h264, other) and which decoder and which splitter? Quote:
If you only watch Blu-Rays or HD-MKV stuff then in most cases you don't need deinterlacing at all. Some (very few) Blu-Rays can be interlaced, but it's really rare. Quote:
Does MPC-HC still respond to your input (e.g. menus show, button react etc)? If so, please create a debug log for me. If MPC-HC is totally frozen, please create both a freeze report and a debug log. Thanks. Quote:
16th March 2012, 10:50 | #12775 | Link | |
What about the shortcut key problem? |
16th March 2012, 11:32 | #12776 | Link | |
16th March 2012, 11:36 | #12777 | Link | |
I'm not sure if there is anything I can do here. You're saying that everything works fine if you play video on the secondary monitor. Since that works fine, probably all that doesn't work fine is not madVR's fault, because madVR doesn't really care which is your primary and which your secondary monitor. I guess that Direct3D or Windows itself is reponsible for the different behaviour. Or maybe the GPU driver, I don't really know. The problem only happens if you play the video on the primary monitor, correct? If you play on the secondary monitor, the shortcut keys are not being swallowed, correct? I think this is probably a consequence of the primary monitor video stealing the focus. Again, I fear there's not much I can do about it. |
16th March 2012, 11:49 | #12778 | Link | |
16th March 2012, 15:02 | #12779 | Link | |
