17th September 2008, 20:38 | #25 | Link |
my post in http://forum.slysoft.com/showthread.php?t=20116 has a reply that leads me here.
For the layman, what does 'read the Volume ID without aacs authentication' mean, and why would I need to be able to do it ? Thanks for the help. |
18th September 2008, 01:37 | #26 | Link |
Hi everybody,
@mrr19121970 at the beginning of the aacs decryption process of a HD-DVD or BD you need to know two data blocks: A processing key suitable for the media key block version used on that disk, and the volume unique id of the disk to be decrypted. Both data together are used to calculate the volume unique key, which then is used to decrypt the title keys, and at last the title keys are used to decrypt the content on the disk. To prevent a hacker from doing this, the firmware of a HD-DVD / BD reader normally will refuse to unconditionally tell you the volume unique id. Instead, the player software on your pc ( e.g. WinDVD or PowerDVD ) needs to authenticate itself as a "legitimate" application with a player key, which has to be send to the drive first. And only after the drive has accepted the player key as "valid", it will report back with the volume unique id. If a player key is known to be compromised, it can be invalidated through an update mechanism included on newly released disks. A list of invalidated player keys is stored in the flash rom of the drive. So e.g. if the aacs authorities may find out the player key used by AnyDVDHD to authenticate itself as a legitimate application, they would be able to invalidate this key, which would make AnyDVDHD temporarily inoperationable ( until Slysoft integrates a new player key into AnyDVDHD, which should not take longer then a few hours ) At this point, the patch provided by Oopho2ei comes into the game: This patch modifies the drive firmware in a way that it will report the volume unique id without the need of an authentification with a player key. By doing so, one part of the aacs protection is completly knocked out, because it is no longer possible to prevent anybody from getting the volume unique id by invalidating the player key used by the ripping software. C.U. NanoBot |
21st September 2008, 10:36 | #27 | Link |
Posts: n/a
Has anyone tried the patched firmware with a MKBv10 (or higher?) disc yet? According to "james" from the slysoft team they are now "poisoned".
Would it break anything if we disable the "update from disc" function of the drive? Last edited by Oopho2ei; 21st September 2008 at 11:29. |
22nd September 2008, 00:13 | #29 | Link | |
Posts: n/a
22nd September 2008, 02:14 | #30 | Link |
I think he just meant that the Host Certificate used by Anydvd HD got revoked, nothing more. What else should that MKBv10 disc have done? I don't believe that it has checked the firmware for hacks and has done evil things because of that.
22nd September 2008, 08:11 | #31 | Link |
Posts: n/a
I know it's unlikely but it's not impossible to exploit a missing boundary check in the firmware (buffer overflow) to execute some code on the drive. I have logged the communication between anydvd and my drive and no authentication took place. Maybe this is only done for unknown discs?
22nd September 2008, 21:10 | #32 | Link |
Hmm, because the drive updates itself, wouldn't that mean it has to exploit itself ?
Indeed, Anydvd does authentication only if it doesn't have the disc in its database. So if you don't have a newer disc, try an older Anydvd. |
24th September 2008, 14:07 | #33 | Link | ||
24th September 2008, 16:43 | #34 | Link |
Posts: n/a
Yes, there is no reason to panic. I have so far received no complaints about the patched firmware and i am really concerned it works perfectly for everyone. If there should be a problem with newer discs i would like to hear about it as soon as possible to fix it before more people run into the same problem. There is always a risk when using a patched firmware and because a respectable member of slysoft company called the new discs (MKBv10) "poisoned" and was referring in the same posting to this thread i felt like i had to issue this "warning" above.
I personally believe that using a patched firmware on blue ray drives will continue to be a reliable way to retrieve the volume id and that our patch for LG/Plextor drives won't cause any problems. |
26th September 2008, 17:16 | #35 | Link |
For information, i've installed this patched bios on my LG drive with success directly under Linux with wine. (I have now windows OS at home so...)
Wine just pops-up me for a missing dll. I've dl it from the net, put it in the .wine tree and it did the trick. Thx a lot for the patched firmware. Cheers. |
29th September 2008, 14:56 | #36 | Link |
problem with firmware patch in linux
@TomZ:
I tried to do the firmware patch as you indicated, in linux but i don't think it is working. I had the same problem as you to start - i needed that dynamic link library. i dled it and put it in the .wine directory. I got this output when i ran wine with the patch executable: Code:
$ wine GGC-H20L_1.03_VolumeID_Patch.exe wine: Call from 0x402f2d to unimplemented function MFC42.DLL.6648, aborting wine: Unimplemented function MFC42.DLL.6648 called at address 0x402f2d (thread 0009), starting debugger... Unhandled exception: unimplemented function MFC42.DLL.6648 called in 32-bit code (0x7bc4569c). Register dump: CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b EIP:7bc4569c ESP:0032e898 EBP:0032e8fc EFLAGS:00000206( - 00 - -IP1) EAX:000019f8 EBX:7bc88444 ECX:0032e920 EDX:00d406a4 ESI:0032e8a4 EDI:ffffffff Stack dump: 0x0032e898: 00000000 00000048 00000002 80000100 0x0032e8a8: 00000001 00000000 00402f2d 00000002 0x0032e8b8: 00410980 000019f8 7bc683db 00d406a4 0x0032e8c8: 0032fd44 0000003b 0000003b 00d406a4 0x0032e8d8: 0000005c 7ee3bb76 00d406a4 0000005c 0x0032e8e8: 00d406be 00000000 0032e920 00000000 Backtrace: =>1 0x7bc4569c in ntdll (+0x3569c) (0x0032e8fc) 2 0x00402f2d in ggc-h20l_1.03_volumeid_patch (+0x2f2d) (0x0032ff08) 3 0x7b877b27 in kernel32 (+0x57b27) (0x0032ffe8) 0x7bc4569c: subl $4,%esp Modules: Module Address Debug info Name (61 modules) PE 400000- 418000 Export ggc-h20l_1.03_volumeid_patch PE 5f400000-5f4ed000 Deferred mfc42 ELF 7b800000-7b92d000 Export kernel32<elf> \-PE 7b820000-7b92d000 \ kernel32 ELF 7bc00000-7bca4000 Export ntdll<elf> \-PE 7bc10000-7bca4000 \ ntdll ELF 7bf00000-7bf03000 Deferred <wine-loader> ELF 7e4a5000-7e506000 Deferred rpcrt4<elf> \-PE 7e4b0000-7e506000 \ rpcrt4 ELF 7e506000-7e5aa000 Deferred ole32<elf> \-PE 7e510000-7e5aa000 \ ole32 ELF 7e5e2000-7e5f5000 Deferred libresolv.so.2 ELF 7e60a000-7e628000 Deferred iphlpapi<elf> \-PE 7e610000-7e628000 \ iphlpapi ELF 7e628000-7e65b000 Deferred uxtheme<elf> \-PE 7e630000-7e65b000 \ uxtheme ELF 7e683000-7e68c000 Deferred libxcursor.so.1 ELF 7e68c000-7e691000 Deferred libxfixes.so.3 ELF 7e691000-7e694000 Deferred libxcomposite.so.1 ELF 7e694000-7e69a000 Deferred libxrandr.so.2 ELF 7e69a000-7e6a2000 Deferred libxrender.so.1 ELF 7e6a2000-7e6a5000 Deferred libxinerama.so.1 ELF 7e6a5000-7e6c5000 Deferred imm32<elf> \-PE 7e6b0000-7e6c5000 \ imm32 ELF 7e6c5000-7e6ca000 Deferred libxdmcp.so.6 ELF 7e6ca000-7e6e2000 Deferred libxcb.so.1 ELF 7e6e2000-7e6e5000 Deferred libxau.so.6 ELF 7e6e5000-7e7cc000 Deferred libx11.so.6 ELF 7e7cc000-7e7da000 Deferred libxext.so.6 ELF 7e7da000-7e7df000 Deferred libxxf86vm.so.1 ELF 7e7f4000-7e88b000 Deferred winex11<elf> \-PE 7e800000-7e88b000 \ winex11 ELF 7e8c2000-7e8e3000 Deferred libexpat.so.1 ELF 7e8e3000-7e90d000 Deferred libfontconfig.so.1 ELF 7e90d000-7e922000 Deferred libz.so.1 ELF 7e922000-7e992000 Deferred libfreetype.so.6 ELF 7e992000-7e994000 Deferred libxcb-xlib.so.0 ELF 7e9a7000-7ea66000 Deferred comctl32<elf> \-PE 7e9b0000-7ea66000 \ comctl32 ELF 7ea66000-7eabf000 Deferred shlwapi<elf> \-PE 7ea70000-7eabf000 \ shlwapi ELF 7eabf000-7ebd2000 Deferred shell32<elf> \-PE 7ead0000-7ebd2000 \ shell32 ELF 7ebd2000-7ed19000 Deferred user32<elf> \-PE 7ebf0000-7ed19000 \ user32 ELF 7ed19000-7ed6b000 Deferred advapi32<elf> \-PE 7ed30000-7ed6b000 \ advapi32 ELF 7ed6b000-7ee06000 Deferred gdi32<elf> \-PE 7ed80000-7ee06000 \ gdi32 ELF 7ee06000-7ee70000 Deferred msvcrt<elf> \-PE 7ee20000-7ee70000 \ msvcrt ELF 7ef90000-7ef9b000 Deferred libnss_files.so.2 ELF 7ef9b000-7efa5000 Deferred libnss_nis.so.2 ELF 7efa5000-7efbd000 Deferred libnsl.so.1 ELF 7efbd000-7efc6000 Deferred libnss_compat.so.2 ELF 7efc6000-7efeb000 Deferred libm.so.6 ELF f7c34000-f7c38000 Deferred libdl.so.2 ELF f7c38000-f7d87000 Deferred libc.so.6 ELF f7d88000-f7da0000 Deferred libpthread.so.0 ELF f7db5000-f7eeb000 Deferred libwine.so.1 ELF f7eed000-f7f0c000 Deferred ld-linux.so.2 Threads: process tid prio (all id:s are in hex) 00000008 (D) Z:\home[...]\GGC-H20L_1.03_VolumeID_Patch.exe 00000009 0 <== 0000000c 00000013 0 00000012 0 0000000e 0 0000000d 0 0000000f 00000015 0 00000014 0 00000011 0 00000010 0 00000016 00000017 0 Backtrace: =>1 0x7bc4569c in ntdll (+0x3569c) (0x0032e8fc) 2 0x00402f2d in ggc-h20l_1.03_volumeid_patch (+0x2f2d) (0x0032ff08) 3 0x7b877b27 in kernel32 (+0x57b27) (0x0032ffe8) wine: Call from 0x402f2d to unimplemented function MFC42.DLL.6648, aborting wine: Call from 0x402f2d to unimplemented function MFC42.DLL.6648, aborting can you offer any advice? thanks. |
30th September 2008, 00:05 | #40 | Link | |
