2nd September 2007, 00:01 | #201 | Link |
No, Fox, you are cropping the black bars that are "burned in" the video stream (that are encoded in the source video). So you are not losing effective pixels (or image pixels), you are simply losing black pictures. He advised you to do so in order to help the codec encode only the image itself, and no black bars with it.
Try creating an AVS script with a tool, such as MeGUI, that will help you crop the black bars properly. Zambelli, thank you very much for you fast help. Here are what you asked me: -a_mode 1 (bitrate OK) Code:
PS D:\home\rash\Development\Eng test\wav> cscript "C:\Program Files\Windows Media Components\Encoder\WMCmd.vbs" -input e ng_test.wav -output eng_test.wma -a_codec WMA9PRO -a_mode 1 -a_setting 384_48_6_24 Microsoft (R) Windows Script Host Version 5.7 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) Windows Media Encoder Command Line Script Utility Copyright (C) Microsoft Corporation. All rights reserved. ======== Begin Pass1 ======== Read: 201.5s (97.5%) Elapsed: 00:01:14 Left: 00:00:02 [2.72x] ======== Begin Pass2 ======== Encoded: 141.2s (68.3%) Elapsed: 00:00:04 Left: 00:00:02 [35.3x] ======== Encoding Completed ======== Audio : Codec: Windows Media Audio 10 Professional Expected bit rate: 384000 bps Average bit rate: 384000 bps Expected sample rate: 2929 Average sample rate: 2929 Dropped byte count: 0 bytes Dropped sample rate: 0 Total bytes: 9994240 bytes Overall: Encoding time: 83 seconds Average bit rate: 384000 bps File size: 10018183 bytes File duration: 206.955 seconds Code:
PS D:\home\rash\Development\Eng test\wav> cscript "C:\Program Files\Windows Media Components\Encoder\WMCmd.vbs" -input e ng_test.wav -output eng_test.wma -a_codec WMA9PRO -a_mode 4 -a_setting 384_48_6_24 Microsoft (R) Windows Script Host Version 5.7 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) Windows Media Encoder Command Line Script Utility Copyright (C) Microsoft Corporation. All rights reserved. ======== Begin Pass1 ======== Read: 203.8s (98.6%) Elapsed: 00:00:34 Left: 00:00:00 [5.99x] ======== Begin Pass2 ======== Encoded: 202s (97.7%) Elapsed: 00:01:20 Left: 00:00:02 [2.52x] ======== Encoding Completed ======== Audio : Codec: Windows Media Audio 10 Professional Expected bit rate: 384000 bps Average bit rate: 565490 bps Expected sample rate: 2929 Average sample rate: 4314 Dropped byte count: 0 bytes Dropped sample rate: 0 Total bytes: 14630912 bytes Overall: Encoding time: 119 seconds Average bit rate: 565490 bps File size: 14664574 bytes File duration: 207.093 seconds This file of mine is part of an audio/video project. This is a 5.1 audio channel encoded from 6 mono wavs (in the test above they are in a wav_ext file, but encoding from a wme project for the 6 mono channels result the same). I was encoding audio (6 mono wavs) and video all from a wme project when I noticed this effect. If I set 128_48_6_24 I get an aproximate 386 kbps file. But Windows Media Player reports it as 128 VBR 6 channel, though the file properties states 386 kbps. Doing the math (well, the script does it for us), taking the filesize and duration we can see that the real bitrate is indeed 565kbps. Now that I have encoded everything, I came about a new question. How do I set a delay for audio? My audio is -275ms delayed, so I have to delay the video -275 ms (but -v_buffer doesn't allow me to set negative numbers) or delay the audio 275 ms. Is it possible? The resulting video quality is amazing! With just 2.8Mbps for a 720x480 video. Thank you ver much for your help. Last edited by Rash; 2nd September 2007 at 00:08. |
2nd September 2007, 01:35 | #202 | Link | |
Can anyone tell me how to figure out what resolution i should use depending on what the aspect ratio of the source is? Is there some formula or something? |
2nd September 2007, 08:38 | #203 | Link | |
Doom9ing since 2001
Most of the time you can just figure this out practically by loading the .avs in VirtualDub and using the Crop function of the Null transform filter to figure out how far the black bars go. |
2nd September 2007, 16:09 | #204 | Link | |
However i still have a problem when i try to encode with 2 pass peak vbr. I have now tried it with two different video files and its the same result, video is stuttering or acting like it is two video files overlapped and playing off sync by like half a second. Last edited by FoxRacR17; 2nd September 2007 at 22:30. |
3rd September 2007, 00:41 | #205 | Link | |
3rd September 2007, 08:46 | #208 | Link |
no, its only when i try 2 pass peak VBR. I can do 1 and 2 pass CBR and it turns out great. I have uploaded a sample of what i'm talking about, it starts out fine, but then after around 10 seconds it starts to mess out, check it out:
http://www.megaupload.com/?d=XLJCU1W8 This is my .avs script: DirectShowSource("E:\video.grf",fps=23.976,framecount=4315,seekzero=false,seek=true,audio=false) crop( 0, 140, 0, -140) Spline36Resize(1280,528) and this is my command line: cmd /k cscript.exe "C:\Program Files\Windows Media Components\Encoder\wmcmd.vbs" -input "E:\video.avs" -output "E:\final video.wmv" -v_codec WVC1 -videoonly -v_mode 4 -v_preset better -v_bitrate 8000000 -V_peakbitrate 12000000 -v_keydist 30 -v_buffer 60000 -v_peakbuffer 60000 |
3rd September 2007, 09:14 | #209 | Link | |
try that script... and here is a sample from my latest run... http://www.megaupload.com/?d=16027WNY Last edited by sportcenter; 3rd September 2007 at 09:51. |
3rd September 2007, 16:29 | #210 | Link |
what about this...never had this problem...
Microsoft (R) Windows Media Encoder Command Line Script Utility Copyright (C) Microsoft Corporation. All rights reserved. Warning: Encoder failed to retrieve duration attribute from source plug-in. . Warning: Encoder failed to retrieve source duration again. Encode process might not continue or progress report may be inaccurate. .................................................................................. and then closes...?.... |
3rd September 2007, 17:16 | #212 | Link | ||
So do the eac3to like normal, then do the tranzcode like normal to get the split up waves, then stop it before wavavimux makes the audio .avi file. Load the first .wav file in delaycut, and then click the little box for "delay" and put in a time (in ms), then repeat for the other five wavs. One you have that done you can continue with wavavimux and then encode to whatever you want. I found out that when i used the 100ms that evodemux told me on the original .evo, the audio was FINALLY right on with the video for batman begins. That movie was driving me crazy trying to figure that out. Quote:
5th September 2007, 00:31 | #215 | Link |
I too am having problems with a VBR peak bitrate encode. I have tried twice now with no luck. Once with a vpeakbuffer of 5000 and one try with a vpeakbuffer of 60000. No dice. I get what seem to be the same results as FoxRacr17.
Avs script for both: Directshowsource("E:\WMV-HD Encoding\Video_Only.grf", fps=23.976, audio=false, seekzero=false, seek=true, framecount=188890) spline36resize(1280,720) 1st try: cscript.exe "D:\Program Files\Windows Media Components\Encoder\wmcmd.vbs" -input "E:\WMV-HD Encoding\Video_Only.avs" -a_input "E:\WMV-HD Encoding\audio.avi" -output "E:\WMV-HD Encoding\output.wmv" -v_codec WVC1 -v_mode 4 -v_preset better -v_keydist 30 -v_peakbuffer 5000 -v_bitrate 8000000 -v_peakbitrate 12500000 -v_quality 100 -a_codec wmapro -a_setting 640_48_6_24 ....... Source duration retrieved: 7878.3 seconds. ======== Begin Pass1 ======== Read: 7878.1s (100%) Elapsed: 09:55:52 Left: 00:00:01 [0.22x] ======== Begin Pass2 ======== Encoded: 7878.3s (100%) Elapsed: 35:11:39 Left: 00:00:01 [0.06x] ======== Encoding Completed ======== Audio : Codec: Windows Media Audio 10 Professional Expected bit rate: 640032 bps Average bit rate: 640031 bps Expected sample rate: 5859 Average sample rate: 5859 Dropped byte count: 0 bytes Dropped sample rate: 0 Total bytes: 630295948 bytes Video : Codec: Windows Media Video 9 Advanced Profile Expected bit rate: 8000000 bps Average bit rate: 7937932 bps Expected fps: 23.976 Dropped frame count: 0 Total coded frames: 188890 Average sample rate: 23.952 Dropped bytes: 0 bytes Total bytes: 7817138838 bytes Overall: Encoding time: 162493 seconds Average bit rate: 8577963 bps File size: 8469844808 bytes File duration: 7878.314 seconds Audio in sync but video stutters consistently after about 5 minutes into the movie. 2nd try cscript.exe "D:\Program Files\Windows Media Components\Encoder\wmcmd.vbs" -input "E:\WMV-HD Encoding\Video_Only.avs" -a_input "E:\WMV-HD Encoding\audio.avi" -output "E:\WMV-HD Encoding\output.wmv" -v_codec WVC1 -v_mode 4 -v_preset better -v_keydist 30 -v_peakbuffer 60000 -v_bitrate 8000000 -v_peakbitrate 12500000 -v_quality 100 -a_codec wmapro -a_setting 640_48_6_24 ..... Source duration retrieved: 7878.3 seconds. ======== Begin Pass1 ======== Read: 7877.9s (100%) Elapsed: 09:51:36 Left: 00:00:02 [0.22x] ======== Begin Pass2 ======== Encoded: 7878.3s (100%) Elapsed: 35:09:50 Left: 00:00:01 [0.06x] Blew up with one second left! Incomplete file has out of sync audio from the start of the movie. Is this because the file failed to complete processing? Video STILL stutters just like the first encode, about 5 minutes in. Stutters exactly as FoxRacr17 describes above. It takes my old school P4 3 ghz HT about 48 hours per encode, so any help would be greatly appreciated..... Thanks.. |
5th September 2007, 00:46 | #216 | Link |
do only video encoding first....then audio...then mux together w/ windows media encoder
try this... cmd /k cscript.exe c:\windows\wmcmd.vbs -input c:\encodes\hotfuzz.avs -output c:\encodes\hotfuzz.wmv -v_codec WVC1 -videoonly -v_width 1280 -v_height 544 -v_mode 4 -v_preset best -v_bitrate 8765000 -v_peakbitrate 12000000 -v_peakbuffer 10000 -v_mmatch 0 obviously you can take the v_width and v_height out if you have spline36resize in your avs and you can replace "best" w/ "better" if you like also why are you guys not using ConverttoYV12() Asharp(1,3) in your avs scripts? it will make your video look almost identical to the source if the above script doesn't work, i hate to say it but it may be the equipment you guys are using - it may be too slow 2-pass "best"takes me around 16 hours on my pc Q6600 4GB RAM 74GB Raptor |
6th September 2007, 17:25 | #220 | Link |
I encoded some videos here though I think my VC-1 encodes were too blurred. Here is my cmd
"C:\Windows\SysWOW64\cscript.exe" "C:\Program Files (x86)\Windows Media Components\Encoder\wmcmd.vbs" -input "ignoringu.avs" -output "video\ignoringu.wmv" -videoonly -v_codec WVC1 -v_mode 3 -v_preproc 0 -v_bitrate 2560000 -v_buffer 10000 -v_performance 100 -v_compopt 1 -v_dquantstrength 3 -v_percopt 3 -v_denoise 0 -v_median 0 -v_codedwidth 720 -v_codedheight 480 -pixelratio 40 33 -log ignoring.log Oh, by the way Zambelli, WMA's 5.1 is still giving me some headaches. Code:
D:\Home\Rash\Development\Pitty IgnorinU\audio>"C:\Windows\SysWOW64\cscript.exe" "C:\Program Files (x86)\Windows Media Components\Encoder\wmcmd.vbs" -input "igno ringu synced.wav" -output "ignoringu.wma" -a_codec WMA9PRO -a_mode 3 -a_setting 384_48_6_24 Microsoft (R) Windows Script Host Version 5.7 Copyright (C) Microsoft Corporation. All rights reserved. Microsoft (R) Windows Media Encoder Command Line Script Utility Copyright (C) Microsoft Corporation. All rights reserved. ======== Begin Pass1 ======== Read: 265.8s (96.7%) Elapsed: 00:00:40 Left: 00:00:01 [6.64x] ======== Begin Pass2 ======== Encoded: 260.5s (94.8%) Elapsed: 00:00:42 Left: 00:00:02 [6.2x] ======== Encoding Completed ======== Audio : Codec: Windows Media Audio 10 Professional Expected bit rate: 384000 bps Average bit rate: 1030045 bps Expected sample rate: 2929 Average sample rate: 7858 Dropped byte count: 0 bytes Dropped sample rate: 0 Total bytes: 35389440 bytes Overall: Encoding time: 86 seconds Average bit rate: 1030045 bps File size: 35462651 bytes File duration: 275.071 seconds Thank you all. [EDIT] Oh, by the way, that program do you guys use to mux wmv and wma into a wmv file?. Thank you. Last edited by Rash; 6th September 2007 at 17:46. |
