30th April 2016, 18:12 | #1362 | Link | |||
Software Developer
30th April 2016, 18:20 | #1363 | Link |
Ok thanks for quick answer.
But, after i enable qaac in lamexp, qaac encodes the same file with success. Opus encoder still fails. How is that possible? Tried it twice now, and both success with qaac... Wav file should still be same size, right? edit, i saw the 4gb warning in the log....yuck encoded file had a longer playtime...
MCFish Last edited by MCFish; 30th April 2016 at 18:30. |
30th April 2016, 19:01 | #1364 | Link |
Software Developer
The original WAV format, the one that actually has wide support, is limited to 4 GB. Some implementations are even limited to 2 GB, because they interpret the "size" field as signed (the specs don't say it, but only unsigned makes sense).
Then there are the WAVE64 and RF64 formats: While WAVE64 is a proper extension of the WAV standard to 64-Bit and thus what everybody should be using in an ideal world (but not backwards compatible to original WAV), the RF64 format is pretty much a "dirty" hack to allow more than 4 GB in a single WAV file (note: RF64 is nothing but several standard WAV file structures dumped into one contiguous file) and provides at least some backwards compatibly to original WAV. Now, what happens when the writing application writes a normal WAV files but the size exceeds 4 GB? Some application just fail. Some create a normal WAV file with more than 4 GB of content, which means you get a non-standard (broken) WAV file. And some switch over from WAV to RF64 "on the fly" when the 4 GB limit is exceeded. At least in the latter case there is a certain chance that the reading application will be able to read the file. But there is no guarantee it will work! (In the end, WAV files larger than 4 GB are always problematic and things may fail on you randomly)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 30th April 2016 at 22:37. |
30th April 2016, 19:55 | #1365 | Link |
47.952fps@71.928Hz
Thanks for the explaination!
It makes so much more sense now. It's quite hard to keep track of what actually supports w64 formats these days. Thankfully, eac3to does. Custom builds of SoX. My eyes.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
30th April 2016, 21:59 | #1366 | Link |
As a workaround, you may want to try saving to FLAC (lossless, fast compression) to get around the 4 GB limitations of WAV files. Then you can pipe the decoded output from FLAC straight into neroaac or some other audio encoder that supports raw / piped input
2nd May 2016, 06:05 | #1368 | Link |
We had this discussion about WAV files > 4GB before in this thread. LoRd_MuldeR made it very clear that he wanted LameXP to be a universal solution, and since other tools used by LXP do not (or only partly) support WAV64 of RF64 there is no way to support the conversion of large multichannel sources.
To me the only workaround was to give up on universality, so I definded some special cases and the corresponding work flows. Generally the problem occurs for 6-ch (or more than 6) sources with a length of a little over 2 hours. For these cases I needed solutions which did not use intermediate WAV files. AC3 to AAC: BeSweet or EAC3To DTS to AC3 or AAC: Eac3To AAC to AC3: For this I made my own converter which uses FAAD, SoX and Aften. (Neither BeSweet nor Eac3To support AAC input.) http://forum.doom9.org/showthread.ph...04#post1616904 Of course it can be done differently using FFmpeg (and QAAC with piping). Cheers manolito |
11th May 2016, 01:25 | #1369 | Link |
well most tools supports pipe in/out, so maybe using ie sox to do it can be a workaround to feed those tools.
also ffmpeg has its own aac codec, and can be build with libfdk_aac too
powered by Google Translator Last edited by Motenai Yoda; 11th May 2016 at 01:30. |
22nd May 2016, 16:53 | #1370 | Link | |
Software Developer
LameXP v4.14 Beta-2
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 21st October 2016 at 21:14. |
18th June 2016, 05:07 | #1371 | Link |
Hi LordMulder:
In February formatted my pc and 4.13 LameXP had not installed. I switched from avast to avg and now the program only runs disabling the antivirus. If active the antivirus the pc hangs me, not even placing .exe exclusions works. I like very much this program but clarify that I have no intention of changing AV, sorry. I have WXP SP3. |
18th June 2016, 05:57 | #1373 | Link | |
I have last version offline updated. |
18th June 2016, 12:19 | #1375 | Link | |
Software Developer
Personally, I can not recommend to accept this new form of censorship though. (Technically there nothing I can do on my side - unless they showed me the exact line of code in my program that justifiably classifies as "malware" behavior - which of course doesn't exist)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th June 2016 at 12:29. |
18th June 2016, 14:01 | #1376 | Link |
IMHO, change a AV to run a program would put the garbage under the carpet.
If you are interested, Simplex264 serves me right, but by LameXP, spend several times in the Recovery Console with chkdsk /p yesterday was unpleasant. If the manufacturer does not listen to a client nothing can be done. It's a shame, because your programs are good. Maybe that's the problem. Last edited by GMJCZP; 18th June 2016 at 14:17. |
18th June 2016, 14:25 | #1377 | Link | |
Software Developer
The so-called "anti-virus" software blocks a program that, without the slightest doubt, is 100% legitimate (if you want say the opposite, then show me the exact lines of code in my program that unambiguously classify "malware" behavior"), so the bug/problem is in the anti-virus software! Consequently the one and only place where the bug could be fixed is the anti-virus software. Because anti-virus software is a "blackbox" and they keep their algorithms secret, any kind of speculation why anti-virus software XYZ is failing horribly this time is totally pointless. Especially because there is a zillion of anti-virus softwars out there and because their behvious can (and most often will) change with the next update. NOTE: You have to understand that "FALSE POSITIVES" are an important part of the business model of anti-virus companies. They sell "premium" contracts to the big software companies, so the programs of those companies get "whitelisted" immediately. If there wasn't a sufficiently high probability that 100% legitimate programs get blocked due to "FALSE POSITIVES", then this business model wouldn't work. Of course it means that if you are not one of those big companies, you stuff just gets censored! That's how blackmail works in the 21st century. For independent software developers and smaller companies this has become a HUGE problem. I also work on a couple of commercial projects, so I know what I'm talking about... (Buying an EV software-signing certificates helps, to some degree, but the price is WAY beyond what I can afford for my hobby projects. Let alone that you need to be a registered business in order to get this kind of certificate)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 18th June 2016 at 14:32. |
7th July 2016, 15:42 | #1379 | Link | |
In February formatted my pc and 4.13 LameXP had not installed. I switched from avast to avg and now the program only runs disabling the antivirus. If active the antivirus the pc hangs me, not even placing .exe exclusions works. I like very much this program but clarify that I have no intention of changing AV, sorry. I have WXP SP3. __________________ By law and justice! RescueFrame" http://finance.yahoo.com/news/avast-...063000656.html What will you do ? Last edited by lethedoom; 10th July 2016 at 15:29. |
17th July 2016, 17:36 | #1380 | Link |
Buglet in file naming in 4.13
4.13 introduced a buglet in file naming that I believe 4.12 did not have. I have the advanced option "Rename Output Files" unchecked (no checkmark) so file names should not be changed. Yet a buch of filenames are changed. All of them end in a period -- file names such as "Maestro E.K.E." or "Wach uff myn Hört etc." that are created by another program reading external sources. The filetype I am using is ".wav", and the files are being converted to ".mp3". When a filename ends in a period, the period is stripped during conversion. So, for example, "M:\Music\For Ellington\Maestro E.K.E..wav" does not become "M:\Music\For Ellington\Maestro E.K.E..mp3" but becomes "M:\Music\For Ellington\Maestro E.K.E.mp3" instead. I do note that double internal spaces are now preserved, but I persist in thinking that not checking "rename output files" should mean that I get out the same name I put in.
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
