4th December 2012, 02:40 | #21 | Link | |
EDIT: Did you try replacing this new vsvfw.dll? Though it maybe have nothing to do with your problem. If in doubt, just try encoding a small range of your video and see whether the encoding could finish, and whether the frames of the encoded file has problems or not. Last edited by HolyWu; 4th December 2012 at 08:46. |
4th December 2012, 02:57 | #22 | Link |
No- Vdub shows first frame and than does nothing- CPU stays at 0. I can't jump into any frame etc- just hangs.
I will try unmodified version, see if it changes anything. Looks like ultrafast uses different plugins than all others. |
9th December 2012, 00:54 | #23 | Link |
I found out how to increase WinXP's memory limit to 3GB. That helps to make the process to go longer, but it still crashes after using over 2.2 GB of memory. How much memory does QTGMC need anyway?
Also I tried to use Vapoursynth's set_max_cache_size() but couldn't figure out how to use it. So then I tried using vs.Core(threads=2) to see if it would use less memory instead of utilizing all 4 CPU cores. The program hangs and doesn't do anything. Ditto with threads=1. The lowest I can go is threads=3, and even that reaches to 2.2gb and crashes. I tried the vsvfw.dll too. No luck. I tried Vdub, x264, and FFPlay. Same results on all. I'm wondering if I have a bad version of a plugin. Is there a way to monitor which plugin is utlizing the most memory?
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. |
9th December 2012, 02:29 | #24 | Link | |
Professional Code Monkey
9th December 2012, 03:15 | #25 | Link |
I haven't been able to figure out how to do set_max_cache_size().
If I do it this way Code:
import vapoursynth as vs import sys import havsfunc core = vs.Core().set_max_cache_size(1) haf = havsfunc.HAvsFunc(core) #plugins# I'm not sure exactly where it's supposed to go. I guess I'll wait until next week for the new release.
Pirate: Now how would you like to die? Would you like to have your head chopped off or be burned at the stake? Curly: Burned at the stake! Moe: Why? Curly: A hot steak is always better than a cold chop. Last edited by Revgen; 9th December 2012 at 03:35. |
9th December 2012, 05:10 | #27 | Link |
Thanks Are. No error messages this time, but it's still exhibiting the same behavior. Looks like I'll just have to wait til the next release to see if the situation improves.
14th January 2013, 14:32 | #28 | Link |
The download link is broken. If you have trouble finding reliable hosting I can put a copy of the scripts on my website.
14th January 2013, 15:24 | #29 | Link |
Updated r4.
Added 'dct' argument to SMDegrain to set the equivalent argument of MAnalyse. Added FFT3dGPU to QTGMC as another Denoiser to NoiseProcess. Since FFT3dGPU doesn't support bt=5, the maximum of NoiseTR is restricted to 1. Renamed 'DftThreads' of QTGMC to 'DenoiseThreads'. The threads of FFT3DFilter is not set in the original version. Now 'DenoiseThreads' sets the threads of both dfttest and FFT3DFilter. Added nnedi3_rpow2 function. Replaced HQDering function with HQDering mod(only 8-bit processing). Added ivtc_txt60mc function. Added InterFrame function. Replaced some filters with the native VapourSynth plugins if possible. Minor bug fixes. For ivtc_txt60mc there is a problem. MFlowInter seems to have problem running in VapourSynth when pel=2. So you have to set draft=True in ivtc_txt60mc to let it use pel=1 right now. For InterFrame there is a bigger problem. It's a pity that SVPflow runs about 10x slower in VapourSynth than it runs in AviSynth. Mostly because of the "Avisynth Compat: requested frame XXX not prefetched, using slow method that may deadlock" issue I guess. Ah...I was just about to update the new version so I deleted the old file. |
14th January 2013, 15:27 | #30 | Link |
I'll have a look at the svpflow stuff later. I think I simply needed to add it properly to the avisynth prefetch lists.
14th January 2013, 16:25 | #31 | Link | |
14th January 2013, 16:48 | #32 | Link |
typo lover
on nnedi3_rpow2, you should use only std.Transpose() instead of your TurnLeft/Right functions. FlipHorizontal and FlipVertical are useless in this case.
yexpr = 'x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?' and, since warpsharp package is not compatible with VS, you can't use UnsharpMask().
my repositories Last edited by Chikuzen; 15th January 2013 at 16:20. |
15th January 2013, 04:35 | #33 | Link |
The warpsharp package has been fixed since Chikuzen pointed it out and will work in r19 when that's done.
That's one confusing expression. What does it look like in readable form anyway?
15th January 2013, 10:49 | #35 | Link |
typo lover
a benchmark result
import vapoursynth as vs import sys def expr(x, y): if (x - 128) * (y - 128) < 0: return 128 if abs(x - 128) < abs(y - 128): return x return y def get_lut(): lut = [] for y in range(256): for x in range(256): lut.append(expr(x, y)) return lut core = vs.Core(threads=1) core.std.LoadPlugin('vsrawsource.dll') c0 = core.raws.Source('720p50_mobcal.y4m') c0 = core.std.Loop(core.std.ShufflePlanes(c0, 0, vs.GRAY), 4) #2016(504x4) frames c1 = core.raws.Source('720p50_parkrun.y4m') c1 = core.std.Loop(core.std.ShufflePlanes(c1, 0, vs.GRAY), 4) #2016(504x4) frames clip = core.std.Expr([c0, c1], ['x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?']) #clip = core.std.Lut2([c0, c1], get_lut(), planes=0) clip.output(sys.stdout) ------------------------------------------------------------- $ for i in {1..3}; do time python3 benchmarch.py > /dev/null; done std.Expr std.Lut2 1st 0m22.792s 0m17.316s 2nd 0m22.782s 0m16.963s 3rd 0m22.791s 0m17.004s
my repositories Last edited by Chikuzen; 15th January 2013 at 10:56. |
16th January 2013, 14:02 | #36 | Link |
The most complicated expression in the script is probably the one used by LSFmod's Smode=5.
'x y = x x x y - abs 16 / log 1 4 / * exp 16 * 0.75 * x y - dup abs / * x y - dup * 16 dup * 4 + * x y - dup * 4 + 16 dup * * / * 1 48 0 = 0 16 48 / dup * dup * ? + 1 48 0 = 0 x y - abs 48 / dup * dup * ? + / * + ?' # Infix notation: (x==y) ? x : (x+(((((((abs(x-y)/16)^(1/4))*16)*0.75)*((x-y)/abs(x-y)))*((((x-y)^2)*((16^2)+4))/((((x-y)^2)+4)*(16^2))))*((1+((48==0) ? 0 : ((16/48)^4)))/(1+((48==0) ? 0 : ((abs(x-y)/48)^4)))))) Code:
import vapoursynth as vs import sys def get_lut(): lut = [] for y in range(256): for x in range(256): if x==y: lut.append(x) else: lut.append(max(min(round(x+(((((((abs(x-y)/16)**(1/4))*16)*0.75)*((x-y)/abs(x-y)))*((((x-y)**2)*((16**2)+4))/((((x-y)**2)+4)*(16**2))))*((1+(0 if 48==0 else (16/48)**4))/(1+(0 if 48==0 else (abs(x-y)/48)**4))))), 255), 0)) return lut core = vs.Core() core.avs.LoadPlugin(r'C:\Program Files (x86)\AviSynth 2.5\plugins\DGDecodeNV.dll') core.std.LoadPlugin(r'C:\Program Files (x86)\VapourSynth\filters\genericfilters.dll') clip = core.std.Trim(core.avs.DGSource(r'a 1080p24 video.dgi'), 0, 4999) blur = core.generic.Blur(clip, planes=0) clip = core.std.Expr([clip, blur], ['x y = x x x y - abs 16 / log 1 4 / * exp 16 * 0.75 * x y - dup abs / * x y - dup * 16 dup * 4 + * x y - dup * 4 + 16 dup * * / * 1 48 0 = 0 16 48 / dup * dup * ? + 1 48 0 = 0 x y - abs 48 / dup * dup * ? + / * + ?', '']) #clip = core.std.Lut2([clip, blur], lut=get_lut(), planes=0) clip.output(sys.stdout) ------------------------------------------------------------- $ time python test.vpy > /dev/null std.Expr std.Lut2 10m10.820s 1m49.963s |
16th January 2013, 14:21 | #37 | Link |
I suspect you can speed it up a bit. Not that it really matters when a lut is so much faster...
For example "16 dup *" is a constant expression and there are several more constants recalculated every time. You can also rewrite X ^ (1/4) as sqrt(sqrt(X)) which probably is a lot faster than using exp and log.
16th January 2013, 14:46 | #38 | Link |
typo lover
'x y = x x x y - abs 16 / log 1 4 / * exp 16 * 0.75 * x y - dup abs / * x y - dup * 16 dup * 4 + * x y - dup * 4 + 16 dup * * / * 1 48 0 = 0 16 48 / dup * dup * ? + 1 48 0 = 0 x y - abs 48 / dup * dup * ? + / * + ?' # Infix notation: (x==y) ? x : (x+(((((((abs(x-y)/16)^(1/4))*16)*0.75)*((x-y)/abs(x-y)))*((((x-y)^2)*((16^2)+4))/((((x-y)^2)+4)*(16^2))))*((1+((48==0) ? 0 : ((16/48)^4)))/(1+((48==0) ? 0 : ((abs(x-y)/48)^4)))))) also, "... (1+((48==0)) ? 0 : ((16/48))^4)" why you don't write just "1.012346"
my repositories |
16th January 2013, 14:59 | #39 | Link |
In the original expression some constants are parameters, and are replaced with the function's argument values, for example (1/4) is one of it, so can't simply using sqrt(sqrt(X)) if someone specified (1/3) or so. I replaced all parameters with the default values for convenience here. That's why you wonder why I don't write values which could be calculated beforehand like (1+((48==0) ? 0 : ((16/48)^4))).
16th January 2013, 18:25 | #40 | Link | |
typo lover
another benchmark (Since HolyWu's script did not work on my box, I rewrote it by myself. )
import vapoursynth as vs import sys core = vs.Core(threads=1) core.std.LoadPlugin('vsrawsource.dll') core.std.LoadPlugin('genericfilters.dll') def func(x, y, strength, szrp, spwr, sdmplo, sdmphi): if x == y: return x diff = x - y diff2 = diff * diff tmp0 = ((abs(diff)/szrp)**(1 / szrp))*szrp*strength * (diff/abs(diff)) tmp1 = szrp ** 2 + sdmplo tmp2 = szrp ** 2 tmp3 = 1 + ((szrp/sdmphi) ** 4 if (sdmphi != 0) else 0) tmp4 = 1 + (abs(diff)/sdmphi ** 4 if (sdmphi != 0) else 0) tmp3 /= tmp4 ret = x + tmp0 * ((diff2 * tmp1) / ((diff2 + sdmplo) * tmp2)) * tmp3 return min(255, max(0, int(round(ret)))) def get_lut(strength, szrp, spwr, sdmplo, sdmphi): lut = [] for y in range(256): for x in range(256): lut.append(func(x, y, strength, szrp, spwr, sdmplo, sdmphi)) return lut c0 = core.raws.Source('720p50_mobcal.y4m') c0 = core.std.ShufflePlanes(c0, 0, vs.GRAY) c1 = core.generic.Blur(c0) strength, szrp, spwr, sdmplo, sdmphi = 0.75, 16, 4, 4, 0 expr = ('x y = x x x y - abs {Szrp} / log 1 {Spwr} / * exp {Szrp} * {Str} * x y - ' 'dup abs / * x y - dup * {Szrp} dup * {SdmpLo} + * x y - dup * {SdmpLo} + ' '{Szrp} dup * * / * 1 {SdmpHi} 0 = 0 {Szrp} {SdmpHi} / dup * dup * ? + 1 ' '{SdmpHi} 0 = 0 x y - abs {SdmpHi} / dup * dup * ? + / * + ?') expr = expr.format(Szrp=szrp, Spwr=spwr, Str=strength, SdmpLo=sdmplo, SdmpHi=sdmphi) clip = core.std.Expr([c0, c1], [expr]) #clip = core.std.Lut2([c0, c1], get_lut(strength, szrp, spwr, sdmplo, sdmphi), planes=0) clip.output(sys.stdout) Quote:
Probably, HolyWo would use anime as a sample. Since x and y become equal in many cases in the case of anime, almost part of expression does not evaluate and finishes with the head of them(if x == y then return x).
my repositories Last edited by Chikuzen; 17th January 2013 at 07:08. |
