24th November 2011, 00:52 | #11081 | Link |
Kid for Today
so I'm playing around w/ the queue settings:
-on non-CUVID stuff, mVR reports higher GPU RAM usage(216MB) than GPU-Z(158MB) -on CUVID, it's the other way around...209MB in mVR, 269 in GPU-Z I've got a 384MB 8800GS G92, so who should I trust? Is there any point in filling the GPU RAM with cache? I guess not? And is there any point in maxing out the CPU queue size? any ill effect such as increased CPU load? I've got it maxed out atm, and seeking seems snappier...maybe my imagination, though Last edited by leeperry; 24th November 2011 at 00:57. |
24th November 2011, 20:17 | #11084 | Link |
Grand Fruitioner
Don't know if it's new. madVR recovers when switching between multiple desktops, but not when enabling/disabling desktops. The whole screen flickers when you do this, so I assume dwm.exe or perhaps the video driver is being restarted. Resuming from sleep causes the same issue.
Lanczos4, Spline36, what!? Don't know how to pick a resizer? Take a look at my kernel visualizations. Want a high-quality, gamma-aware resizer? Check out my ResampleHQ filter. |
24th November 2011, 21:16 | #11085 | Link | |
or http://forum.doom9.org/showthread.php?t=153191&page=7 The first thread is Microsoft's Navigator...from Windows XP. The second link is a directshow wrapper to the open source libdvdnav navigation filter bwing developed by cb2000. It's not perfect but I find that it works better in some ways as compared to the Windows XP navigation filter...however it is less stable than Windows XP's filter. |
24th November 2011, 21:18 | #11086 | Link |
Also madshi I think I brought this up earlier but switching from exclusive mode on one screen to exclusive mode on the other screen freezes the current frame and the other monitor does not go to exclusive mode for a long time.
25th November 2011, 05:15 | #11087 | Link |
thanks dansrfe so i downloaded the test.zip and put it into my madvr folder thou im not sure if thats the right folder since i havent noticed any difference still macrovsion fail -.-' , but tbh i really hope madshi integrates some type of fix for madvr that we wont get this macrovision fail anymore -.-'
25th November 2011, 05:44 | #11088 | Link | |
25th November 2011, 07:05 | #11090 | Link |
You don't need any of that for DVD playback. Just use ffdshow for video decoding, and in its configuration, enable the "DVD Decoding" option for MPEG2 in the codecs section.
Some other filters may cause macrovision errors too, so you may have to selectively disable them until it works. My filter list is LAV Filters, ffdshow video decoder (only applies to DVDs) and ffdshow audio processor. (downmixes audio for headphones) |
25th November 2011, 07:38 | #11091 | Link |
well but then my dvds display lesser quality then with madvr -.-' , so wheres the hack tool please
my list looks like this http://imouto.my/watching-h264-video...#comment-14414 after this faq ive setup my external filter list for the best of the best in quality |
25th November 2011, 12:49 | #11092 | Link |
You're still using madVR as the renderer, ffdshow just does the MPEG2 decoding.
Many of the things listed in that guide are either redundant, or detrimental. All 4:2:2, 4:4:4, and in most cases, all RGB formats should be disabled in ffdshow/LAV Video decoder's output options. (madVR needs the raw 4:2:0 data to work best) Just make sure that ffdshow is lower priority than LAV Video decoder, it should only be loaded with DVDs. |
25th November 2011, 13:14 | #11093 | Link | |
I should probably finish dvd playback, so we can remove ffdshow video from the equation.
25th November 2011, 14:25 | #11094 | Link | |
Can't wait! |
25th November 2011, 15:24 | #11095 | Link | |
p.s: thanks for the suggestions 6233638 but nevcairiel seems to have abit of experience id say and as said i used that guide to setup my external list and everything else too, since ranpha seems to be kinda pro too hmmm... Last edited by sexus; 25th November 2011 at 15:26. |
25th November 2011, 17:53 | #11099 | Link | |
Try running uninstall.bat, and then install.bat in your madVR folder and see if that helps. Not sure if I also reset all settings. Fixed it for me. Suit yourself, but DVDs work just fine in madVR using this method without resorting to replacing system files. |
26th November 2011, 00:19 | #11100 | Link |
yeah but if the lav author sez he is gona integrate support natively then id say wait for that since i can imagine better quality/performance coming from that and less filter clutter
