9th February 2006, 09:22 | #481 | Link | |
clueless n00b
9th February 2006, 10:23 | #482 | Link | ||
Just add Code:
/r:%windir%\Microsoft.NET\Framework\v2.0.50727\Microsoft.VisualBasic.dll |
9th February 2006, 10:25 | #483 | Link | |
clueless n00b
9th February 2006, 10:59 | #484 | Link | |
BeHappy/MeGUI developer
@Doom9 MeGUI still written un C# but I'm using one VB.NET function - InputBox (Microsoft.VisualBasic.dll is part of .NET Runtime) Later it can be replaced by custom form
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
9th February 2006, 15:11 | #485 | Link |
version 0.2.3.20.81
You can now select a default audio track for DGIndex in the settings tab, but not 2 independant languages, ie track 2 automatically defaults to track 1 default language. (I tried changing to other languages, same problem) Also the same if change track 2, track 1 changes to the same language. Just to add, the following came up when compiling: Code:
Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. AviSynthWindow.cs(1555,10): warning CS1030: #warning: 'This is just quickfix, please check it!' JobUtil.cs(559,30): warning CS0618: 'MeGUI.LanguageSelectionContainer.getLanguages()' is obsolete: 'Use LanguageSelectionContainer.Languages instead' mkvMuxWindow.cs(116,21): warning CS0618: 'MeGUI.LanguageSelectionContainer.getLanguages()' is obsolete: 'Use LanguageSelectionContainer.Languages instead' MuxWindow.cs(127,21): warning CS0618: 'MeGUI.LanguageSelectionContainer.getLanguages()' is obsolete: 'Use LanguageSelectionContainer.Languages instead' Microsoft (R) Visual C# 2005 Compiler version 8.00.50727.42 for Microsoft (R) Windows (R) 2005 Framework version 2.0.50727 Copyright (C) Microsoft Corporation 2001-2005. All rights reserved. Last edited by Sh4nn0w; 9th February 2006 at 15:16. |
9th February 2006, 15:54 | #486 | Link |
fixed
9th February 2006, 16:44 | #488 | Link | |
9th February 2006, 17:15 | #490 | Link |
No, I does not need warnings
9th February 2006, 17:26 | #492 | Link | |
9th February 2006, 20:32 | #493 | Link |
BluRay Maniac
I found error i avs creator in lastest build he can create script.
I get this script LoadPlugin("c:\....\dgdecode.dll") mpeg2source() <-this is wrong other is not interstenig I have d2v input and i get message There is not Mpeg2Source. |
9th February 2006, 21:06 | #497 | Link | |
