2nd June 2013, 10:10 | #162 | Link |
Here's a link to a file with the same codec, bitrate and resolution: http://www.sendspace.com/file/rvmjv8
It's a 1080p24 ProRes HQ .mov file, 7.5 seconds and 151 MB. Happy testing! Last edited by colinhunt; 2nd June 2013 at 10:13. |
2nd June 2013, 14:36 | #163 | Link | |
It appears that Quicktime decoding is simply sloooow. |
8th August 2013, 12:25 | #165 | Link |
Hey everyone, I was wondering if someone could help here although maybe only Hank would know...
I'm trying to compile my own custom matrix.dll for experimental purposes on windows, but it looks like I need the Intel fortran compiler... I tried using gfortran and made the .dll, but the encoder gives an error saying it can't find the EXTMATRIX function. Looking into the DLL I realized that gfortran uses different conventions when it comes to function name exports and the exported function was being lowercased to extmatrix... Does anyone know how to successfully compile a matrix.dll on windows? Maybe I could use C++ or some other language? |
8th August 2013, 12:57 | #166 | Link |
What's a Matrix.dll? A quantisation matrix isn't a DLL. The ones in HCEnc are all CQMs. Or am I misunderstanding you? Care to show us the matrix you created? There are already quite a few available in HCEnc.
If you're looking to create custom matrices, maybe LigH's Custom Quantization Matrix Editor will prove useful: http://forum.doom9.org/showthread.php?p=469040 Or maybe the Rockas Rebuilder Matrix Editor will do: http://www.jdobbs.com/Pages/Downloads.htm |
8th August 2013, 13:02 | #167 | Link | |
There is an option to manipulate the matrices procedurally based on the motion and luminosity per GOP. To do this you need to compile a custom dll. Sample fortran code is provided for this. |
7th September 2013, 10:31 | #169 | Link | |
Are you planning to integrate Intel Quick Sync Video in HC Enc by using the Intel's Media SDK for its 4th gen processor, Intel claims that by using this, the video creation and conversion is 17x faster since its uses the dedicated media processing which is built right into their processor. Handbrake started using it (in Beta) and some commercial converters are already on it. |
9th September 2013, 21:53 | #170 | Link | |
HCenc author
I've recently started again doing some work on HCenc after not seeing the code for about 2 years.
Until now some small improvements are done. Things I'm also thinking about: - 64 bit version It will improve speed, not because its 64 bit but more 128 registers available to work with. This will take a while, all hand written assembler code has to updated and optimized. - 4:4:4 color space - Update bitrate and VBV control For some high bitrate encodes this could be better... - Trellis quantization The articles I've read about it clearly show a full trellis will be slow as hell, if I ever finish it it will probably be some kind of pseudo-trellis. And now find some time for it Quote:
Some dedicated asm code using the latest SIMD SSE/AVX instructions will probably be a better choice for HCenc.
HCenc at: http://hank315.nl |
9th September 2013, 23:36 | #171 | Link |
Hi Hank,
good to see you back after such a long time... I already thought you had abandoned HCenc for good. HCenc 0.26 Beta is in almost daily use here - I only use it for DVD output, no problems whatsoever (I even hexedited out the 'Beta' from the title bar). Welcome back! manolito |
10th September 2013, 04:23 | #172 | Link |
47.952fps@71.928Hz
Wonderful to see you are well (enough to post).
I had wondered about updated instruction sets for AVX. My current machine I use HCenc on (mostly) has AVX instrcution set but SSE4 (4.2) is used instead. 64bit would make for an interesting update to play with. Question regarding 64x HCenc: If the input is an AVS script, would the AVS version have to be x64 as well?
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
12th September 2013, 14:01 | #173 | Link | |
Currently the following converter are using it as per Intel: Arcsoft MediaConverter Arcsoft MediaImpression Badaboom Media Converter Corel Digital Studio CyberLink MediaEspresso CyberLink PowerDirector MainConcept Movavi Video Converter Roxio Creator along with freeware's like Mediacode HQ and Handbrake, I personally have not used any of the above commercial softwares but reading the feedback posted by some endusers definitely mention the gains in terms of speed and time. Dvdfab has posted this comparison sheet on their website. You are the best judge of what will work better for HCenc. |
24th September 2013, 11:02 | #174 | Link |
47.952fps@71.928Hz
Might I ask but a humble request for any future considerations?
Request: If the source is an AVS script, would it be possible to copy the script to the designated *LOGFILE? It would come in handy when doing multiple samples with different AVS scripting; such as, brightness tweaking, etc.
3rd October 2013, 05:29 | #175 | Link | |
FishmanMod Android Dev
"Cinderella story, out of nowhere, former greenskeeper, now about to become the Masters champion. It looks like a mirac- it's in the hole!" |
13th December 2013, 16:55 | #176 | Link |
All of a sudden I'm getting a crazy Visual Fortran popup window when I try to encode more than 961 frames with HCenc 0.26 beta.
[EDIT: Err. I figured out the issue. The drive I'm writing to ran out of space. Perhaps this could be handled with a more elegant message.] "Visual Fortran run-time Error forrtl: severe (27): too many records in I/O statement, unit -5, file Internal Formatted Write Image PC Routine Line Source HCenc.exe 00593B5A Unknown Unknown Unknown Stack trace terminated abnormally." Also, HCgui 0.26 crashes upon attempting to open a script whose return value is not a video clip (undefined), rather than rendering an error message. Example: Code:
BlankClip(30,720,480,"YV12",30000,1001) X = 0 Last edited by ChiDragon; 13th December 2013 at 17:14. |
30th May 2014, 01:32 | #177 | Link |
47.952fps@71.928Hz
Is there any simple math to calculate the *LOSSLESS temp file?
I'd like to better guess a better place for it instead of going to largest place (usually USB 2.0 external with at least 500GB free space). I use anamorphic resolution (NTSC) 704x480.
4th June 2014, 23:39 | #178 | Link |
HCenc author
The size of the lossless file can't be calculated exactly, the size is variable, it depends on the compressibility of the source.
In your case (YV12 color space): each plane: 704 x 480 = 337920 bytes (Y plane) 2 x 352 x 240 = 168960 bytes (UV planes) total per plane: 506880 bytes per minute: 23.976 x 60 x 506880 = 730 MB Each frame is compressed, average compression: 40 - 50%, so per minute the file size will be approx. 330 MB.
5th June 2014, 00:37 | #179 | Link |
47.952fps@71.928Hz
Thank you, this should be plenty enough to work with.
