Old 3rd July 2010, 01:40   #1881  |  Link
adiabatic
adiabatic's Avatar
Would some kind souls please test the 32-bit DGIndexNV version linked below to see if it delivers faster indexing without breaking anything. I'm getting indexing about twice as fast as the 2018 release version on initial testing. Thank you.
http://neuron2.net/misc/DGIndexNV_perftest.zip
"The requested URL /misc/DGIndexNV_perftest.zip was not found on this server"
No need for further testing? Your own results seem promising... I'm willing to participate if you still need it.
adiabatic is offline   Reply With Quote
Old 3rd July 2010, 01:52   #1882  |  Link
That one did not use low-level IO. I'll post the new one shortly. Thank you for your willingness to assist in the testing.
Old 3rd July 2010, 02:31   #1883  |  Link
OK, it's there. Use the same link as before.
Old 3rd July 2010, 03:04   #1884  |  Link
adiabatic
adiabatic's Avatar
Hmmm. It gives slightly slower performance on a 11.5 GB file. Both tests repeated twice.
My system:
Windows 7 Pro 64-bit
Intel Core i7-920
GTX275 196.21 drivers
80GB Intel X25-M G2 SSD
2018 release version - 32-bit
Stream Type: Transport [188]
Video Type: MPEG2
Profile: main@high
Coded Size: 1920x1088
Display Size: 1920x1080
Aspect Ratio: 16:9 [3]
Frame Rate: 29.970030 fps
Colorimetry: BT.709*
Frame Structure:
Frame Type:
Coded Number: 200807
Playback Number: 200810
Frame Repeats: 0
Field Repeats: 7
Bitrate: 11.926
Bitrate (Avg): 13.750
Bitrate (Max): 19.111
Audio Stream: 14: AC3 3/2 48 384
Elapsed: 0:04:13
Remain: 0:00:00
FPS:
Info: Finished!
2018 test
Video Type: MPEG2
Profile: main@high
Frame Structure:
Frame Type:
Frame Repeats: 0
Field Repeats: 7
Bitrate: 11.926
Elapsed: 0:05:03
Remain: 0:00:00
FPS:
Info: Finished!
<edit> looks like I'm behind on driver versions.... updating and repeating tests.
Old 3rd July 2010, 03:12   #1885  |  Link
That's hard to believe.
I'm testing on WinXP 32-bit with mechanical drives. I'll try it on my i7-960 64-bit.
I see you have an SSD. That is probably going to be a lot different from a mechanical drive. Your read rate is probably four times what I get. That makes the actual buffer size important because the smaller the buffer the more calls are made. I could try increasing the buffer in multiples of 4096 until it starts to deteriorate performance.
If I have to choose, I will optimize for mechanical drives, at least at this point in time.
Can you test on a mechanical drive?
Old 3rd July 2010, 03:25   #1886  |  Link
adiabatic
adiabatic's Avatar
OK, I'm also getting the same results with the SSD and the latest Nvidia drivers.
I'll now re-run the tests with the conventional HD.
Old 3rd July 2010, 03:48   #1887  |  Link
adiabatic
adiabatic's Avatar
OK mechanical HD (7200rpm Western Digital SATA).
With the same test file as above.
2018 "release" - 5:09
2018 "test" - 6:23 (during this test I opened Resource Monitor and I was reading and writing at about 28 MB/sec for both)
Just to be clear so I don't lead you down a false path... your earlier comment about caching related to read caching, right? I have write caching enabled for my drives which was the default Windows setting for the drives.
I did this test with the source file and demux output on the mechanical HD. Does it matter to your testing if my pagefile and the DGIndex folder is on the SSD?
I'm heading out for an hour or so now... but am willing to test more later.
Old 3rd July 2010, 03:54   #1888  |  Link
Jeez, don't have resource monitor opened for the test.
That's just incredible. I can't believe it. I get a 3.5 times speedup on my system!
Let's wait and see what happens with other people.
Are you running the X32 versions in both cases?
I would so love to get to the bottom of this.
Old 3rd July 2010, 04:15   #1889  |  Link
adiabatic
adiabatic's Avatar
That's just ridiculous. I can't believe it. I get a 4 times speedup on my system.
BTW, I just popped Resource Monitor open for a minute.
Yes, x32 (double checked in task manager (*32)). Your x64 binaries are tucked away in another folder. Feel free to ask other questions or wait for other testers. The last thing I want to do is be making an error here that wastes your time.
I agree, let's see what others get. Later tonight I'll run this test on a more plain-vanilla machine in the house (mech. HDs, Core2Duo 2.0, Nvidia 8600GT card).
Though since I can't let go of this bone... for fun I've moved my dgdecnv folder and pagefile to the mech. HD. The source and target folder are also on the same HD. The only part of this equation that should now be on the SSD are core Windows files and Nvidia driver files.
(no Resource Monitor this time!)
2018 "release" - 5:11
2018 "test" - 6:08
The only thing I'm doing on this system while the demux is running is light web-browsing with Firefox but I've been doing that constantly through all tests with all variations of testing tonight.
Now I am really leaving the house for a little while
Old 3rd July 2010, 04:22   #1890  |  Link
My results:
2018 - 21:30
2018 test - 5:51
Look at the graph in here:
http://pisa.ucsd.edu/cse125/2006/Pap...ing_in_C++.pdf
It shows an approximate 3-4 times speedup from using low-level IO versus C IO, consistent with my findings.
Old 3rd July 2010, 04:35   #1891  |  Link
linyx
Un-Registered User
linyx's Avatar
I just tried out the test version, and am seeing errors like this one with it (lots, 5 out of 7 streams tested).
These errors do not show up with the 64-Bit or the 32-Bit of 2018. Want a stream?
linyx is offline   Reply With Quote
Old 3rd July 2010, 04:42   #1892  |  Link
Originally Posted by linyx View Post
Want a stream?
Yes, please. Also diff the DGI files. They would have to be different. My tests show no differences between release 2018 and test 2018 DGI files (except for the path at the top).
Any timing results to report?
Old 3rd July 2010, 04:51   #1893  |  Link
woah!
My results 24.5GB file:
2018 - Elapsed: 0:13:36
2018 test - Elapsed: 0:05:24
the test version is much better here
woah! is offline   Reply With Quote
Old 3rd July 2010, 05:04   #1894  |  Link
I'm not imagining it then.
Old 3rd July 2010, 05:09   #1895  |  Link
woah!
but vc1 files are not showing as much speedup as h264 bluray files. 8.5GB file
2018 - Elapsed: 0:02:17
2018 test - Elapsed: 0:01:59
will do some more files here for you..
Old 3rd July 2010, 05:49   #1896  |  Link
adiabatic
adiabatic's Avatar
OK, now I'm on my "basic" system.
32-bit Vista Home Premium
Core 2 Duo 2.0
8600GT video card (latest drivers)
good ol' mechanical HDs
Same test file as before
2018 - 10:16
2018 test - 12:26
It must be something unique to this clip. Video source is MPEG-2 TS 1080i with AC3 audio from Motorola DCT-3416 cable box. It's been edited with VideoRedo and (I'm not 100% sure) probably run through MPEG2Repair before editing.
sample: http://www.mediafire.com/file/4nm5kn...crew_donald.ts
Old 3rd July 2010, 08:44   #1897  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Great work neuron2, per usual! I'm testing now on my system.
System Spec
Core i7 Q820 (mobile, 4 cores + HT)
4GB DDR3
Quadro FX 2800M
2x 250GB 2.5" HDD RAID 0
Windows 7 x64
Source Spec
1080p24 H.264 HP @ L5
45mbps average, encoded by x264 1542
CAVLC, Deblocking, B-Frames
TS Container (remuxed from an MKV via TSMuxeR 1.10.6)
24436 frames (just under 17 mins)
1018 vanilla
93 seconds = 262.75fps = ~11x realtime = ~ 495mbps
1018 perftest
136 seconds = 179.68fps = ~7.5x realtime = ~ 337mbps
So.. maybe I'm stupid and am being taunted by Windows caching as you warned us about, neuron2... is my sample just too short to avoid this? I tried deleting the source after indexing and muxing a fresh copy, but got similar results.
Any other suggestions?
BTW.. I did all this testing over UltraVNC. No broken CUDA! Slick!
Derek
Old 3rd July 2010, 12:48   #1898  |  Link
Looks like it might be a Win7 versus WinXP issue.
@woah!
Please give your system details.
Old 3rd July 2010, 13:34   #1899  |  Link
My results on my i7-980X Win7 64bit with VelociRaptor (same project as my WinXP results).
2018 - 3:16
2018 perf - 3:12
This supports my WinXP versus Vista/Win7 theory. I'm tending towards going with the perf version due to the big gains it gives XP users. I don't know why some of you see drops on Vista/Win7; could it be the RAID 0?
@linyx
Need your stream and your diff results, please.
Old 3rd July 2010, 17:24   #1900  |  Link
Zep
I have SSD also. In fact my system is basically a clone of adiabatic's
can you make the buffer size a var we can pass? i.e.Default 1=4096 internally , 2=8192 internally etc... then everyone can fine tune to their own PC.
Zep is offline   Reply With Quote
