14th January 2020, 21:56 | #18221 | Link |
Send me something and i will figure out correct method. For now I think those episodes will require manual selection of telecined sections. Final file should be 29.97 progressive instead of 23.976 FPS.
15th January 2020, 01:03 | #18222 | Link |
RipBot264 1.25.0 keeps hanging
I'm having an issue where RipBot264 hangs if I do either of the following:
I just built a new server with Windows Server 2019, so I initially just zipped up my existing 1.25.0 from my old server, and then extracted to C:\Program Files\RipBot264. It hung under the conditions above, so the first thing I tried was using Ripbot264.ini and updater.ini files from the download, but same problems. Then I tried a an unmodified 1.25.0 download, and whether files were in C:\Program Files\ or C:\, it still hangs. I should also say that I've already performed about 4 encodes with no issues. It just seems that the only 2 actions you can perform from the tray icon are hanging the application. |
15th January 2020, 03:44 | #18224 | Link | |
Grumpy Old Man.
That made the error go away, but it still won't play properly. I have provided a 100mb sample which does play using VLC & Potplayer, with both video & audio, however, using MPC-HC (standalone), it only plays the audio https://www.mediafire.com/file/dblag...9-001.mkv/file So as this is your default player, it makes it a bit difficult to determine what changes are required.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) |
15th January 2020, 03:48 | #18225 | Link | |
Grumpy Old Man.
15th January 2020, 12:30 | #18226 | Link | |
Try checking all options here (both columns)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th January 2020 at 12:33. |
15th January 2020, 12:56 | #18227 | Link | |
Grumpy Old Man.
I will try your suggestion (of course), so check EVERYTHING ?, but I will also try it on a different pc, as well. Have you got any codec packs installed on your pc ?? (I haven't)
15th January 2020, 13:38 | #18228 | Link |
No codec packs! Zero! Null!
15th January 2020, 13:46 | #18229 | Link |
Grumpy Old Man.
Well, I just tried, checking all options, didn't make any difference !!
Copied the file, and tried it on my pissy little Dell laptop, and it worked with your default MPC settings.....shit !!! Sorry for wasting your time on this one, I'll have to figure this weirdness out myself. Will try on other pc's as well...isn't it ALWAY's the way, the pc you want to do certain "project's" on, stuff's up !!!!
15th January 2020, 14:40 | #18230 | Link |
For some reason, RipBot (1.25) is having problem with this file:
https://www9.zippyshare.com/v/f4hZV4Ym/file.html (60MB, 17sec sample file, no copyright infringements) The MPC preview shows as green, and the job ends up with a bad encode without any errors. Here's the output on CQ 16 HEVC, copy audio, default AviSynth settings: https://www9.zippyshare.com/v/ctf6KMR4/file.html Sorry if you prefer Mediafire to Zippyshare. For some reason, I get "failed to upload" there. Here's the job's log: Code:
E:\>"C:\Program Files (x86)\RipBot264\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "C:\Temp\RipBot264temp\job1\job1.avs" -strict -1 -f yuv4mpegpipe - | "C:\Program Files (x86)\RipBot264\tools\x265\x265_x64.exe" --colorprim bt709 --transfer bt709 --colormatrix bt709 --crf 16 --fps 24000/1001 --min-keyint 24 --keyint 240 --frames 414 --sar 1:1 --profile main10 --output-depth 10 --ctu 32 --merange 25 --y4m --output "C:\Temp\RipBot264temp\job1\video.265" - y4m [info]: 1920x1080 fps 24000/1001 i420p8 sar 1:1 unknown frame count raw [info]: output file: C:\Temp\RipBot264temp\job1\video.265 x265 [info]: HEVC encoder version 3.2+22-a8a2c4c37267 x265 [info]: build info [Windows][GCC 9.2.0][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2 x265 [info]: Main 10 profile, Level-4 (Main tier) x265 [info]: Thread pool created using 12 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 3 / wpp(34 rows) x265 [info]: Coding QT: max CU size, min CU size : 32 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 25 / 2 / 3 x265 [info]: Keyframe min / max / scenecut / bias : 24 / 240 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / off / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-16.0 / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra x265 [info]: tools: strong-intra-smoothing lslices=6 deblock sao [0.2%] 1/414 frames, 0.02 fps, 553.29 kbps, eta 6:13:41 [0.5%] 2/414 frames, 0.04 fps, 292.74 kbps, eta 3:11:06 [0.7%] 3/414 frames, 0.05 fps, 205.71 kbps, eta 2:10:09 [1.0%] 4/414 frames, 0.07 fps, 162.06 kbps, eta 1:42:24 [1.2%] 5/414 frames, 0.08 fps, 135.87 kbps, eta 1:24:40 [1.4%] 6/414 frames, 0.09 fps, 118.40 kbps, eta 1:12:49 [1.7%] 7/414 frames, 0.11 fps, 106.17 kbps, eta 1:04:23 [1.9%] 8/414 frames, 0.12 fps, 96.90 kbps, eta 0:58:01 [2.2%] 9/414 frames, 0.13 fps, 89.61 kbps, eta 0:53:03 [2.4%] 10/414 frames, 0.14 fps, 83.78 kbps, eta 0:49:06 [2.7%] 11/414 frames, 0.15 fps, 78.99 kbps, eta 0:45:49 [2.9%] 12/414 frames, 0.16 fps, 75.13 kbps, eta 0:43:06 [3.4%] 14/414 frames, 0.18 fps, 68.92 kbps, eta 0:37:48 [4.3%] 18/414 frames, 0.23 fps, 60.67 kbps, eta 0:29:12 [9.7%] 40/414 frames, 0.50 fps, 44.84 kbps, eta 0:12:27 x265 [info]: frame I: 2, Avg QP:20.21 kb/s: 142.61 x265 [info]: frame P: 13, Avg QP:21.00 kb/s: 33.26 x265 [info]: frame B: 28, Avg QP:23.43 kb/s: 31.97 x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0% x265 [info]: consecutive B-frames: 40.0% 6.7% 13.3% 6.7% 33.3% encoded 43 frames in 77.30s (0.56 fps), 37.51 kb/s, Avg QP:22.54 E:\>"C:\Program Files (x86)\RipBot264\tools\mkvtoolnix\mkvmerge.exe" -o "E:\TEST_16_AudioCopy.mkv" --compression 0:none --title "TEST_16_AudioCopy" --default-duration 0:24000/1001fps "C:\Temp\RipBot264temp\job1\video.265" --compression 0:none --language 0:eng --sync 0:0 "C:\Temp\RipBot264temp\job1\1_audio_English.dtsma" mkvmerge v41.0.0 ('Smarra') 64-bit 'C:\Temp\RipBot264temp\job1\video.265': Using the demultiplexer for the format 'HEVC/H.265'. 'C:\Temp\RipBot264temp\job1\1_audio_English.dtsma': Using the demultiplexer for the format 'DTS'. 'C:\Temp\RipBot264temp\job1\video.265' track 0: Using the output module for the format 'HEVC/H.265 (unframed)'. 'C:\Temp\RipBot264temp\job1\1_audio_English.dtsma' track 0: Using the output module for the format 'DTS'. The file 'E:\TEST_16_AudioCopy.mkv' has been opened for writing. 'C:\Temp\RipBot264temp\job1\video.265' track 0: Extracted the aspect ratio information from the HEVC video data and set the display dimensions to 1920/1080. The cue entries (the index) are being written... Multiplexing took 0 seconds. ------------------------- Elapsed Time: 00h:01m:20s Last edited by Ripmann; 15th January 2020 at 14:54. Reason: fixed the output link |
15th January 2020, 14:46 | #18231 | Link |
Speaking of job logs, here are some non-essential improvement ideas you may want to consider:
1) enable the CTRL+A (select all) shortcut for quicker selection. 2) add some sort of time stamp for reference to the log file, perhaps around the last line: Code:
Multiplexing took 0 seconds. ------------------------- Started: 12:30, 01/15/20 Finished: 17:46, 01/15/20 Elapsed Time: 05h:16m:57s |
15th January 2020, 15:08 | #18232 | Link |
ByteShare
This is an older issue but I just noticed something about it since using LSmash now. Job fails to start because of a character it doesn't like but...
Only an issue for the .ffindex_track00.kf, the actual .ffindex looks fine. The .lwi is fine too. I'm not using FFMS2 but it seems to still cause the job to fail. Thé > Thé Some other ones but there are many many more: ¡ :(not an actual colon ":") ; # ¦ “ ’ ` |
15th January 2020, 15:13 | #18233 | Link | |
My glass ball tells me that you may have some GPU driver issues. I'm speculating now...
15th January 2020, 15:16 | #18234 | Link | |
http://forum.doom9.net/showthread.ph...42#post1894742 In short, until it gets fixed, the only solution is to remove Unicode from names (both input and output) and rename the output manually afterwards. |
15th January 2020, 15:23 | #18235 | Link |
Crap, sorry for wasting your time. This is the only file I'm having issues with, so I thought the problem was universal, not just something on my end. I'll do more testing and post here if I find the solution, in case anyone else encounters something like that. Thanks for responding.
15th January 2020, 17:07 | #18236 | Link | |
ByteShare
15th January 2020, 22:28 | #18237 | Link | |
What's interesting is that in my examples below, those issues occurred if I started Ripbot264, but didn't start any encodes. Once I have an encode in the jobs list, I can minimize and restore Ripbot264 without a problem.
Once my encodes finish, I will see what happens once I remove the completed jobs. Quote:
15th January 2020, 23:05 | #18238 | Link |
I got my hands on a bunch of cheap third and fourth gen i7's, and wanted to set them up as a small render farm.
I've got the distributed encoding working fine. They all have 16gigs and above of memory. But they came without bootdrives, and I want to avoid buying a bunch of basically useless drives, however cheap they maybe. Has anyone ever tried creating a bespoke pxe image, something like a thin client just for ripbot? Just RipBot264, Java 32bit, AVisynth, ffdshow, haali media splitter and .Net Framework, plus however slim you get Windows. |
15th January 2020, 23:26 | #18239 | Link |
Btw. Fffshow and .net are not needed. Next version won't also need java. EncodingServer.exe only needs avisynth installed to work.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th January 2020 at 23:28. |
16th January 2020, 00:21 | #18240 | Link |
So right now it would only have to be avisynth and Java for the Encoding Server?
Did anyone every do sth like this, make a custom OS for it, preferably PXE bootable? Last edited by HehoChef; 16th January 2020 at 00:24. |
