16th November 2017, 22:29 | #47201 | Link | |
K (win10 fall update) |
17th November 2017, 01:13 | #47202 | Link |
hi, i've had to sack off my ATI RX 550 card as I just cant get it stable with anything these days, KODI DS crashing randomly caused by graphic driver crashes, tried all version of drivers MADVR and LAV no joy. I've switch to an NVIDIA 1050, no crashes but I cant get rid of frame drops every 3-4 mins whatever I do. I tried creating custom resolution for 23,976 @1080p but makes no difference. I've also tried reclock, nothing changes it at all. At my whits end here guys, hoping someone can help.
17th November 2017, 01:16 | #47203 | Link | |
I bet it's the 2 GB of VRAM causing issues. MediaPortal already uses a few 100s MB for its GUI, so when playing 2160p the VRAM usage should be pretty high. Try lowering the queue sizes (start with the decode one).
HTPC: Windows 10 22H2, MediaPortal 1, LAV Filters/ReClock/madVR. DVB-C TV, Panasonic GT60, Denon 2310, Core 2 Duo E7400 oc'd, GeForce 1050 Ti 536.40 |
17th November 2017, 02:21 | #47204 | Link |
Regarding Dolby Vision, I'm certainly not an expert on these things, but it seems like the enhancement layer might be a form of ratio image. Basically the 12 bit Dolby Vision source divided by the HDR10 version equals the ratio image which has been down scaled to 1920x1080 (probably among other things). It's sort of a clever way of storing higher bit depth information in two lower bit depth images. In order for MadVR to access the 12 bit Dolbly Vision version, the decoder would need to simultaneously decode both layers (HDR10+enhancement) making both available to MadVR, which would need to scale the enhancement later back up to 3840x2160 and multiply it with the HDR10 pixels. Probably other operations would need to be performed on the enhancement layer, bit shifting or something as in float it would have values greater than one which would need to preserved/recovered. Or all this could be completely wrong
17th November 2017, 02:21 | #47205 | Link |
I'm using default queue sizes and I haven't done any testing of the sort you're asking about. In my limited testing, it always seems to use 3-3.5 gb. My feeling is that it would be silly to try to use the 3gb version for 4k and be always worrying whether it works for any given situation.
17th November 2017, 04:32 | #47206 | Link | |
Thanks. |
17th November 2017, 04:38 | #47207 | Link | ||
it can easily do 1080p23 -> with NGU high. a 960 can do this easily so a 1050 ti can do this too. the 4 GB make it absolutely save. obviously you can't use every feature with a 1050 ti but that counts for a 1080 ti too. a 1060 is about 60 % faster and gives you more options but that's it. RCA is just so slow that NGU high is kind of free in comparison. so yeah that's not going to work with a 1080p source or high FPS source need some tweaking like NGU mid. but it's the new feature on the block so every one things you have to use it or something i don't know... Quote:
a 1060 3Gb may work totally fine but just get the 6 GB is generally faster and the 6 GB will be enough for sure well at least for now. |
17th November 2017, 05:43 | #47209 | Link |
we will never know until someone tries it out.
a program is usual using more memory than it actually needs. so seeing 3.5 GB or more is not unusual. but well i got this working with 2GB and 3Gb is quite a lot more way more than 1 GB for madVR because madVr doesn't get all of the 2Gb. https://abload.de/img/2gbcanworkr5uxx.png it's just i can easily say 4GB is save because i know it is save i was using a 4GB RX 480 for 3Gb well... i saw more than 3 Gb Vram usages but i can make it work with 2 gb too well kind of... |
17th November 2017, 10:01 | #47210 | Link |
I must say that I have really lost all faith with Nvidia in the last month. I have reported the HDR issue (not switching off) a month ago to their support and I have heard nothing since, even after three followups through their live support chat and being told I would be contacted within 24 hours. Looking at the driver threads in their forums it seems they currently have huge issues with their drivers, not just with HDR but also GSYNC and stuff in relation to the latest win10 updates. I am at a loss to understand why they have not simply scrapped the current 388.xx tree, gone back to 385.xx and started over.
Has anyone else contacted nvidia support directly over HDR issues or am I the only one? I'm just thinking the more people that complain the more chance they will do something to fix that mess. |
17th November 2017, 12:04 | #47211 | Link | |
17th November 2017, 13:32 | #47212 | Link |
I have just been reading this new info from nvidia in relation to HDR and netflix (http://nvidia.custhelp.com/app/answe...ail/a_id/4583/) and its got me beginning to think that HDR has been purposely crippled in newer drivers when third party players are used.
17th November 2017, 13:55 | #47215 | Link |
What do you mean by "purposely crippled" exactly ?
I think the issues are discrepancies in behaviour between Windows' internal configuration and NVIDIA's own APIs. That does not necessarily means they intentionally crippled functionality, Microsoft is just careless. Nobody wants to run Insider Preview releases on their production systems as they can break many things and Microsoft sometimes won't provide the fixes for months, so Win10 versions are always released in a beta state and then you have to wait for several weeks (if not months for the next feature update) for the things that broke to get fixed.
17th November 2017, 14:19 | #47216 | Link | |
17th November 2017, 14:32 | #47218 | Link | |
Now cant seem to create a customer 1080p 23.976 resolution either, its imediately overwritten with 24p. |
17th November 2017, 14:40 | #47219 | Link |
Reclock is the answer if you cannot set a custom resolution. If that does not help (you mentioned you tried it before) then either you have not set reclock up correctly or there is some other task on your PC that is causing the stutter every few minutes.
17th November 2017, 15:52 | #47220 | Link | |
If you were to use Windows 8.1, even the latest drivers would work absolutely perfectly fine, since there is no Windows HDR functions it has to co-exist with. Hence why madshi keeps recommending 8.1 for a media PC (among other reasons). At this point its quite a bit unclear of Microsoft has to fix stuff, or NVIDIA. Likely both have some work to do. People that care about HDR today however need to realize that they are early adopters at best, so its somewhat expected for stuff to be a bit unstable.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 17th November 2017 at 15:59. |
