5th August 2008, 08:43 | #1 | Link |
aka mappy
Multiple video sizes in the same source
I'm trying to encode the music videos from placebo's Once More With Feeling DVD. The plan is, I want them all to total to 700MB, with both audio tracks. Codec not important; I was thinking 264/aac in mp4, but I may try VP7 for my amusement.
The complication arises from the fact that each video has a slightly different aspect ratio so there are differently-sized black bars every few minutes. I'm loath to just encode these in, but I have all the time in the world and would like to get my 700MB allocated over all the videos in a fair two-pass manner, as if i were encoding a regular DVD. Avisynth won't let me concatenate videos with different sizes. What would be the best way of going about this? |
5th August 2008, 09:19 | #2 | Link |
Hi!
1) In light of the fact that burnable DVD media costs as little or less than than burnable VCD media, why would you want to limit the combined filesize to 700Mb? 2) You could, instead, use (freeware) DVD Flick or trial version of TMPGEnc DVD Author 3 to create a DVD with a simple menu - with each video as a separate TITLE. This would eliminate the need to concatenate the files |
6th August 2008, 01:31 | #3 | Link |
aka mappy
Thanks for your reply, but I'm not really interested in backing these up; as i happen to own the original DVD, this is just for my personal interest. Thus the price of media is irrelevant, and 700MB is an arbitrary limit that i happen to be quite fond of.
Is it possible to allocate my 700MB fairly over all the differently-sized videos, without encoding black bars? |
6th August 2008, 12:41 | #4 | Link | ||
SlySoft Team Member
Or did the "secondary" meaning of "backing up" get promoted from being just a euphemism for piracy? ...sorry, I couldn't resist that little side note Quote:
You have some options, like resizing and cropping, but whatever you do - if the result is supposed to be one video, you'll have to decide for an aspect ratio.
SlySoft Inc. Last edited by blutach; 6th August 2008 at 14:16. |
6th August 2008, 13:21 | #5 | Link |
aka mappy
The first response to anything here seems to be 'did you pirate it?' (i thought i'd made it clear that everything's above board). I want a separate aspect ratio for each individual music video, such that the result would be split over several files. I could use the DVD's aspect ratio, but that would mean including black bars, and wasting bits, which i don't really want to do.
6th August 2008, 13:30 | #6 | Link |
Custom User Title
The easiest way I can think of is to encode the individual videos at their correct AR with one pass, dividing the running time of each video segment by the desired overall bitrate, then creating a playlist for those files. This is assuming you want something playable on a PC or a standalone player.
6th August 2008, 14:33 | #7 | Link |
Mr. Sandman
easy, if you have the original videos resize/crop them at the same resolution and then concatenate them. that's all done within an avisynth script.
use something like: [code] Code:
#clip1 clip1 = SomeFilterSource("clip1.blah", ... options...) clip1 = clip1.Crop(**,**,**,**) # if needed clip1 = clip1.AnyDesiderResizer(xxx,xxx) #clip2 clip1 = somefiltersource("clip2.blah", ... options...) clip1 = clip1.Crop(**,**,**,**) # if needed clip1 = clip1.AnyDesiderResizer(xxx,xxx) # same res as clip 1 #clip3 .... same as above clip = clip1+clip2+clip3.......... return(clip)
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 6th August 2008 at 15:05. |
6th August 2008, 23:16 | #8 | Link | |
aka mappy
If that's the easiest way, is there a harder one? Sharktooth: This involves having them all end up at the same resolution, which isn't what I want, although it brings up the possiblity of resizing everything back afterward... this would give a reasonably accurate two-pass encode i suppose, but then i'd have to make them back to normal sizes, which would be equally problematic. |
7th August 2008, 01:57 | #9 | Link |
Software Developer
Well, if you capture MPEG-2 from DVB-S, you often see the Aspect Ratio switch from 4:3 to 16:9 or vice versa within the same file.
Of course the resolution remains the same, only the PAR (Pixel Aspect Ratio) changes accordingly. I don't know if/how that can be done with H.264, but in theory you could simply change the DAR for each video/segment. This way you could encode all videos at the same resolution (without black bars) and still display each video at the correct aspect ratio.
7th August 2008, 05:44 | #10 | Link |
Angel of Night
Run the audio first - subtract its size A from 700MB, call this V. If you're backing up to x264, use the same CRF on everything. You should even be able to use fairly fast settings to get a good estimate. Once they're done, compare relative sizes, and use those ratios to fit them into V, then calculate the bitrate each will need and run each 2-pass with that bitrate. Alternately home in looking for a CRF that'll get you on the money, but that could take a lot longer. You can substitute constant quant for xvid.
For VP7 you have to specify a bitrate, iirc, no way to do that without a lot of ABX testing. You can only futz around with AR changes as Mulder says by concatenating already-encoded files, and even then many software players don't like it, so you still have to go through the procedure. Last edited by foxyshadis; 7th August 2008 at 05:46. |
8th August 2008, 03:49 | #11 | Link |
aka mappy
LoRd_MuldeR: I was considering something like this, but the source has encoded black bars, so to start with i'd have to crop those and scale everything to the same size, which on second thoughts would be pretty much fine
[EDIT: As a matter of fact, i remember what i didn't like about this; scaling the very wide videos to be tall allocates them bits they didn't have in the first place, that would otherwise be shared amongst all the videos; and the point of this exercise is to allocate the bits as fairly as possible..] foxyshadis: This is pretty much what i was looking for, thank you very much. If i could be bothered, would finding the exact CRF produce a better result than the split 2-passes (noticable or otherwise)? Last edited by click2; 8th August 2008 at 03:52. Reason: remembered something |
8th August 2008, 09:17 | #12 | Link | ||
SlySoft Team Member
I just found the irony in you using "backup" as a synonym for "pirate" irresistible. After all (now being cynical) so many here are carefully using the word "backup" to imply they are NOT pirating - and your "reassignment" of that word sort of is as much as a "yeaah, sure, you're 'backing' up...." Ok, enough of this already... Quote:
It's actually close to NIL. So if you're only about removing those black bars for that reason, you might as well consider not considering it The black bars really get compressed down to pretty much nothing - it's a constant area with no changes, MPEG and Co. just love that sort...
SlySoft Inc. Last edited by Peer van Heuen; 8th August 2008 at 09:20. |
concatenate, multiple, music video, placebo, sizes |
