28th October 2019, 10:55 | #7141 | Link | |
ffx264/ffhevc author
In my encoding, I no longer use it as it's slow here too. --hme seems to run faster here, at least for me on a Core i7 7700K on Linux HME is a bit beneficial for 1080p. But it really shows its strength for 2160p and higher |
28th October 2019, 13:12 | #7142 | Link |
Pig on the wing
In this case, VMAF could be useful in determining if it's worth it or not. Just need to make sure that the compared streams are decoded frame accurately so I would probably encode a sample clip, mux to mkv and index and decode with DGDecNV tools.
28th October 2019, 22:29 | #7143 | Link | |
If doing CRF, it'll just make the file larger. In general, those values will reduce compression efficiency of most content in most scenarios. |
1st November 2019, 06:50 | #7145 | Link | |
Pig on the wing
If your only problem is that your computer becomes unusable, run the process at a lower priority. You can do that in command prompt by using "start /belownormal ...your encoder stuff here..."
1st November 2019, 11:01 | #7146 | Link | |
Furthermore, I use htop to see CPU utilization. This is my third run, and the exact same 4 threads are used. Does it imply that ffmpeg only runs on those same 2 cores (or 4 cores) over and over? I know next to nothing about CPU architecture & organization, but if it implies so, does it have a long term effect on those cores? I thought that the OS should shuffle the workload among cores (between run), still I want to confirm. Last edited by nghiabeo20; 1st November 2019 at 11:08. |
1st November 2019, 11:09 | #7147 | Link |
Why don't you try runing x265 in idle priority? What you do is not optimal.
1st November 2019, 11:29 | #7148 | Link |
Pig on the wing
The OS scheduler does do that, unless you set the process to use only specific cores (=CPU affinity). But as I and Atak_Snajpera said, set the process priority lower (idle or just below normal) and let the encoder use whatever resources are available to it after other processes.
1st November 2019, 11:51 | #7149 | Link | |
Artem S. Tashkinov
Linux: man taskset OS X: You're f*cked. |
1st November 2019, 18:21 | #7151 | Link | |||
3rd November 2019, 19:19 | #7153 | Link |
I've done tests, 1080p with bitrate 22mb, x264 10bit (placebo, subme 11, bframes 8, etc) and x265 10bit (slow, no-rect, subme 4, bframes 8 and some other tweaks). In the end I get almost the same encoding speed. And x265 looks much better. I don't know why many people say that at high bitrate x264 beats x265.
3rd November 2019, 23:01 | #7154 | Link | |
3rd November 2019, 23:31 | #7155 | Link |
I know that 22 is very high for 1080p, I did it specially for test. After encode I upscaled FHD to UHD and compared them. I don't say that x265 MUCH better, but it significantly better at preserving small details. And I can definitely say it's not worse anyway.
4th November 2019, 20:45 | #7156 | Link |
Derek Prestegard IRL
It's definitely not impossible that x265 would produce better results than x264 at 22 Mbps for 1080p. I think it's fair to say that for MOST content the difference would be quite negligible, especially at the same encoding speed. Even if you can get a small improvement when encoding several times slower, is it really worth it?
In many use cases, probably not. But for some? Absolutely. |
4th November 2019, 22:53 | #7157 | Link | |
But IMO, if x265 better at low bitrates and better at high bitrates, I don't see why I should use x264 at any cases. |
5th November 2019, 09:30 | #7158 | Link |
I'm getting this warning. I'm trying to test the new frame duplication switch:
x265 [warning]: Frame-duplication require NAL HRD and VBV parameters. Disabling frame duplication How do I address this?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR |
