9th January 2012, 15:44 | #14521 | Link |
BUG?
Hi. I noticet if there is a "hi quality yv12 to RBG conversion" enabled in RGB convesion, 10-bit encoded videos make Graphstudio (FFDshow) to crash. Just tested by "ffdshow tryouts project, svn 4236 (x86) - MSVC2010" on "i444compressed.mkv" sample.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
10th January 2012, 07:32 | #14524 | Link | |
Edit: The same problem on my HTPC with Radeon 6450 + VMR9 FSE. Edit2: I reset FFDshow setting and it is working now. Must be some registry entry in "HKEY_CURRENT_USER\Software\GNU\ffdshow\default" causing the crash.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin Last edited by hoborg; 10th January 2012 at 09:44. |
10th January 2012, 11:16 | #14525 | Link | |
Do you have any back up of the crashing settings? If you have one, please send it to me. |
10th January 2012, 11:37 | #14526 | Link | |
10th January 2012, 13:02 | #14527 | Link | |
I have fixed at rev 4240. |
10th January 2012, 13:23 | #14528 | Link |
What should be the default output color space to EVR for 10-bit 4:2:0 video?
For most (all?) PC, EVR does not accept P010/P016. Currently ffdshow use YV12 to connect with EVR. It's lossy. I think RGB32 is less lossy. It's a bit slower though. A small patch can change this. Code:
Index: src/imgFilters/ffImgfmt.cpp =================================================================== --- src/imgFilters/ffImgfmt.cpp (revision 4238) +++ src/imgFilters/ffImgfmt.cpp (working copy) @@ -1154,6 +1154,10 @@ FF_CSP_P216 , FF_CSP_444P10, FF_CSP_Y416 , + FF_CSP_BGR32, + FF_CSP_RGB32, + FF_CSP_BGR24, + FF_CSP_RGB24, FF_CSP_420P , FF_CSP_NV12 , FF_CSP_YUY2 , @@ -1167,10 +1171,6 @@ FF_CSP_410P , FF_CSP_ABGR , FF_CSP_RGBA , - FF_CSP_BGR32, - FF_CSP_RGB32, - FF_CSP_BGR24, - FF_CSP_RGB24, FF_CSP_BGR16, FF_CSP_RGB16, FF_CSP_BGR15, |
10th January 2012, 17:18 | #14529 | Link |
IMHO the default should be to output a format as close to the original as possible, and upsampling chroma is not close at all. If 10-bit doesn't work, provide properly dithered 8-bit.
10th January 2012, 18:38 | #14530 | Link |
If P010/P016 can't be used, then best order of preference would probably be RGB > NV12 > YV12.
MPC-HC 2.1.7.2 |
10th January 2012, 23:49 | #14532 | Link | |
The up-sampling without extra 2 bits is lossy. If up-sampling is done in ffdshow, it can utilize the 2 bits. The video renderer may be able to use better interpolation while ffdshow use bilinear. Which will produce better result? Is interpolation method more important than native conversion? |
11th January 2012, 09:45 | #14533 | Link |
haruhiko, there's one thing missing in your argument, namely that RGB output is only 8bit. So let's collect arguments:
RGB output: + chroma upsampling and color conversion can make use of the original 10bit data - after color conversion everything must be converted down to 8bit - chroma upsampling algorithm is lower quality than what good renderers do - user has to configure ffdshow's RGB output to match the display's level requirements (TV vs. PC levels) NV12/YV12 output: - video must be downconverted to 8bit right away + video renderer doesn't have to downconvert to 8bit after color conversion + chroma upsampling algorithm is higher quality + ffdshow doesn't have to care about PC vs. video levels Please note that YCbCr -> RGB color conversion results in floating point data. So basically ffdshow has to dither the floating point RGB data down to 8bit integer. When using YV12/NV12, the video renderer doesn't have to do that, it can perform the color conversion in floating point and then maintain a much higher bitdepth in its internal processing chain. |
11th January 2012, 11:06 | #14534 | Link | |||||
Thank you for your opinion.
For now, it's a rare setting to have 10-bit monitor. It may change in the future, but until then, EVR would have supported P016/P010. Quote:
What are expected in video renderer's processing chain? Resize is done in 8-bit anyway either in RGB32 or NV12. Deinterlacing is the biggest problem, but I have never encountered an interlaced high bit material. After all, EVR must support P010/P016! |
11th January 2012, 11:45 | #14535 | Link |
A 10-bit -> 8-bit conversion may be lossy, but with proper dithering its "visually lossless", you don't see it. A forced RGB conversion may be visible, depending on what the renderer would do better with the raw YUV data.
11th January 2012, 11:54 | #14536 | Link |
@haruhiko_yamagata:
I agree that it would be ideal if EVR supported P010/P016. I'm not sure if that is something Microsoft would have to implement, or maybe the media player devs could do that with a custom mixer? Don't really know... I don't think that 10bit to 8bit YCbCr is "very" lossy. If you apply proper dithering the loss should be small. You're saying that the ffdshow RGB output will be the final output with no further processing. This may be true in many cases, but not in all. E.g. users may use the video renderer to scale the image. In my projection setup (CIH, Cinemascope) I always have to scale 16:9 and 4:3 movies. So even with 1080p content and 1080p displays scaling may still be necessary sometimes. Then there are color changes, brightness/contrast changes, level changes, calibration, gamma adjustments. These are all things that the video renderer may perform. If you take all that into account, you can't be sure that the ffdshow RGB output will see no further processing. You do have a valid point, though: *If* ffdshow's RGB output is the final output without any further processing being done by the video renderer, then having ffdshow output RGB would minimize bitdepth losses. At the end of the day I don't really care much, because all of this applies to EVR/VMR, only. So if you prefer RGB output in this situation, that's just fine with me. |
11th January 2012, 12:26 | #14538 | Link | |
Please pack exported settings with it. |
11th January 2012, 13:30 | #14539 | Link |
1)Problem with rgb32 output and ffdshow
With this video ffdshow doesn't work if I select rgb32 in output. If I check nv12 or p010 video works with mpc-hc and ffdshow. video here: http://www.nyaa.eu/?page=torrentinfo&tid=270934 I tried with ffdshow 4238 and ffdshow 4079 there is the same problem. edit: it's the same problem with all 10bit video and rgb24 output edit2: If I use lav video and select only rgb32 output in lav video, video works well. 2) other problem. a) If I turn on subtitles in ffdshow. If I open 10 bit video, ffdshow switch to rgb32 output and video do'esnt work (mpc and ffdshow open and close immediately like said in 1)) b) If I turn off subtitles in ffdshow. If I open 10 bit video, ffdshow swith to po10 output and video works. during the video, I can turn on subs and it works and subs are displayed. There is a problem with turn on or turn off subs to select output color space when video start 3) question: When can I expect implementation of \t subs ? you have told 1 or 2 months in november. Last edited by ikarad; 11th January 2012 at 14:35. |
11th January 2012, 13:42 | #14540 | Link | |
I will try and get you a sample, though. Edit: Hm, I can't reproduce either. I will get back to you if I encounter it again. Just put this out of mind. Sorry. Last edited by obieobieobie; 11th January 2012 at 14:34. |
