23rd September 2010, 17:17 | #12481 | Link |
In other places this is used for C99 code that MSVC doesn't like:
#if __STDC_VERSION__ >= 199901L // original code #else // MSVC code #endif
MPC-HC 2.2.1 |
23rd September 2010, 18:03 | #12482 | Link | |
4:2:0 hater
23rd September 2010, 18:51 | #12483 | Link |
MPC-HC Project Manager
We compile libavcodec with msvc all the time over at MPC-HC, maybe you could take a look at the code?
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
23rd September 2010, 21:40 | #12484 | Link |
The errors are only in the recently added AAC decoder. I don't mind any extra custom code to allow MSVC compilation.
MPC-HC 2.2.1 |
24th September 2010, 16:05 | #12485 | Link |
4:2:0 hater
There are also unresolved externals because libavutil (cpu.c) is outdated, because it can't find log2f and exp2f, etc. Have you considered creating a new folder (like libavcodec_msvc or something like that) with all these changes to compile libavcodec with MSVC and keep the normal one clear?
24th September 2010, 19:44 | #12486 | Link |
That would mean extra work. Getting it to compile with MSVC is not a high priority right now. It will get fixed eventually.
MPC-HC 2.2.1 |
25th September 2010, 18:29 | #12489 | Link |
hi STaRGaZeR,
I try to compil 3600 but i have an error, i build with the .bat (build_x86.bat), i go to try with the sln. Thanks, Seb. Ps: i didn't know if it's 3600 that break the compil. It's the innosetup, if i compil the .exe with .iss it's ok Ok found it lol : in batch @cd bin\distrib\innosetup but for me it's @cd bin\distrib Edit : Thanks for the fix
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355. Last edited by Sebastiii; 25th September 2010 at 19:46. |
25th September 2010, 23:07 | #12492 | Link |
All it decodes is dts core, which only contains 48Khz samples. But at least it provides full bit depth in decoding, afaik (remember, lossy formats don't have a pre-defined bit depth, you should decode with as much precision as you can)
26th September 2010, 05:12 | #12494 | Link |
Hi, I not sure if this goes here but there seems to be a certain problem getting ffdshow's AAC libavcodec to work with the KMPlayer. I think the problem might be with the internal KMP MKV Splitter since I tested it with MatroskaSplitter.ax and its internal MOV/MP4 splitter and it worked fine.
Versions Used: KMPlayer 3.0.0.1438 ffdshow rev3600 20100925 xhmikosr icl11 |
26th September 2010, 05:43 | #12495 | Link |
I have a problem when using LAVFSplitter. External subtitles don't work when using ffdshow dxva and when I use normal ffdshow I can't choose beetwen external subtitles present in the same folder as the movie(one subtitles is choosen but I can't choose another one. I have no context menu present). I also posted in LAVFSplitter's thread but nevcairiel said that it's possible that ffdshows is the culprit.
Also is good to know that I'm using wmp11. |
26th September 2010, 12:56 | #12497 | Link |
I just recently installed FFDSHOW 3572_20100913_clsid. I was using AVStoDVD for converting my MKV's to DVD5's. All of a sudden I was getting AVS script errors. Using graphedit, I was able to determine that FFDSHOW was no longer decoding DTS or AC3 audio. I looked at the configuration and libdts and liba52 is selected. Installing AC3Filter fixed the isues.
Is there anyway to determine why FFDSHOW stopped working with DTS & AC3 (works fine with AAC). Moreover, how to restore it? TIA |
26th September 2010, 17:39 | #12498 | Link | |
Kid for Today
26th September 2010, 19:56 | #12499 | Link |
契約者
STaRGaZeR
Just a little suggestion. I never saw floating-point build yet but if it will work, could you please keep both variants (16 and 32 bit) if 32bit any slower? Maybe it will be possible to add switch "libavcodec (16bit)" and "libavcodec (32bit)" like it is done for h264 in case of libavcodec and ffmpeg-mt. Also if you know better solution - just skip this post. Thanks. |
27th September 2010, 00:18 | #12500 | Link |
Kid for Today
the only reason to go 32fp for lossy audio is this: http://mp3decoders.mp3-tech.org/24bit.html
it provides a more accurate decoding w/ less rounding errors, very important if you down-upmix/resample/post-process/use Reclock. There isn't a single good reason to decode lossy audio to 16int. |
