2nd April 2016, 15:47 | #241 | Link |
AviSynth plugger
Released MVTools v2.5.11.20.
•Fixed Mflow broken in 2.5.11.2, fixed several other small bugs. •MBlockFps: added support of overlap, renamed parameter thres to ml. •MCompensate, MMask: added partial time compensation. •Masked functions: improved occlusion mask. •MBlockFPS, MMask - added option to use SAD as occlusion mask. •Documented (after Firesledge) negative delta values (v.2.2.1 quick hack for static scene compensation and motion tracking) and fixed some functions accordingly. Avisynth 2.6 header, but no new color formats.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. |
2nd April 2016, 16:02 | #242 | Link |
I know it's very difficult but a merge of all flavors and builds would be awesome. Out of the 34 x64 plugins included with StaxRip x64 only ffms2 and KNLMeansCL support both AviSynth+ x64 and VapourSynth x64 as single DLL.
3rd April 2016, 13:33 | #243 | Link |
BTW svpflow plugin code contains an intermediate abstraction layer to separate the core logic from *synth interface, so the same sources're used to build both Avisynth and Vapoursynth plugins.
It's more like a demo version now and may not be suitable for a complicated plugins but it's totally enough for MSuper/MAnalayse/M***Fps.
SVPflow motion interpolation |
5th April 2016, 11:32 | #244 | Link |
Fizick, download link to the new version is available only from the Russian page http://avisynth.org.ru/mvtools/mvtools2-rus.html
6th April 2016, 18:37 | #245 | Link |
AviSynth plugger
Anyboby else have a problem with english page ?
22nd April 2016, 22:06 | #248 | Link |
AviSynth plugger
v2.5.11.21 (22.04.2016 by Fizick)
•MflowXXX: remove limit of motion vectors length (was 127/pel). •MMask: possible vector scaling for kind=3,4,5. The vector length limit problem was discussed (without me ) here: http://forum.doom9.org/showthread.php?t=165075 It was not bug but feature (documented). Vectors always was stored as short , but previous versions used interpolation (resize) code with BYTE (char) as unity. Now it is short int.
My Avisynth plugins are now at http://avisynth.org.ru and mirror at http://avisynth.nl/users/fizick I usually do not provide a technical support in private messages. Last edited by Fizick; 22nd April 2016 at 22:21. |
26th April 2016, 08:15 | #250 | Link |
unsigned int
1) avisynth.org.ru appears to be dead? It loads "Default Web Site Page".
2) In v2.5.11.3, in MVDepan.cpp, line 711: Code:
int nf = (backward) ? ndest: ndest; // set next frame number as data frame if backward
Buy me a "coffee" and/or hire me to write code! |
27th April 2016, 03:13 | #251 | Link | |
Edit: the DL link still points to avisynth.org.ru, here's the correct DL link for MVTools: http://www.avisynth.nl/users/fizick/...v2.5.11.22.zip Last edited by Reel.Deel; 27th April 2016 at 04:05. |
27th April 2016, 09:27 | #252 | Link | |
unsigned int
27th April 2016, 17:51 | #253 | Link |
AviSynth plugger
jackoneill, sorry I can not give you answer about MVDepan right now. It is old code. And it is quite possible that the code is correct (by result)
And yes, I now see some problem with my main site. May be cheap hosting limit is exceeded.
27th April 2016, 21:26 | #254 | Link |
unsigned int
Oh well. I noticed another thing though: the "zerow" parameter appears to be ignored. The variable "zeroWeight" at line 531 shadows the class member.
11th May 2016, 18:53 | #255 | Link |
unsigned int
Another question about MVDepan: if the "range" parameter is greater than zero, it will calculate data (motionx, motiony, motionrot, motionzoom) for several frames in a single GetFrame call. However, it uses just one frame from the mask clip in the calculations for all those frames. Is this a bug?
20th June 2016, 17:37 | #256 | Link |
unsigned int
While integrating the recent changes into the VapourSynth plugin, I found several bugs.
MVBlockFPS.cpp -------------- - At lines 861 and 862 the pointers pDst[1], pDst[2], pSrc[1], pSrc[2], pRef[1], and pRef[2] should each have nWidth_B/2 added. - At lines 865, 866, and 867 the pitches need to be multiplied by nHeight_B, not nHeight-nHeight_B. - Short2Bytes is not called before returning from MVBlockFps::GetFrame. Frames are returned uninitialised when overlap is used. - There is a line missing after line 730. MaskFun.cpp ----------- - In function MakeSADMaskTime MaskPitch should be used, not nBlkX, when writing to Mask. Older things I hadn't noticed or forgot about: MVFlowBlur.cpp -------------- At line 74 it should be nVPadding instead of nHPadding. The arrays MaskSmallB, MaskSmallF, MaskFullYB, MaskFullYF, MaskFullUVB, and MaskFullUVF are never used. And also: shouldn't FlowFps reject vector clips with negative delta? And in Degrain2 and Degrain3 only the first two vector clips are checked for negative delta.
