Old 2nd August 2008, 05:59   #2001  |  Link
stax76
What kind of work are you doing with mediamonkey?
I have made a extension called MonkeyToys. Currently it uses a separate dialog for playback to handle keyboard shortcuts and remote input so I can use 0-9 on the keyboard and on the remote to set a rating. Another good examples are the space key which is typically used for play/pause or the Delete key which would be nice for deleting tracks. All those keys can't be used in the main dialog since it does conflict with edit controls, controls accepting text input. I would like to use this keys for shortcuts in the main dialog. I think the message traffic can be hooked to find out if a edit control has the focus so special handling can be added for this keys.
Also, could you please update x264 and dgindex to the latest versions?
I don't plan to release a new version anytime soon. It should be possible to use newer versions however, there will be a warning that can be ignored.
stax76 is offline
Old 10th August 2008, 15:18   #2002  |  Link
Raboo
I have questions about the advanced options
Auto correct crop values (don't disable!)
Auto aspect ration signalin (don't disable!)
I wonder why shouldn't these be disabled?
Perhaps it's better if I explain my goal.
I'm trying to rip a very old movie from DVD and it's in 4:3 ratio, i.e. a square old regular TV image. And now all I got is Widescreen TV's. So when I'm about to crop the DVD it on the sides to the remove "the black". It crops to much.. I wonder how am I to do if I want my cropping to be exactly as i choose it in the crop window?
Why is it so important that it's correct aspect ratio? It's a 4:3 movie, It's going to be stretched anyway...so?
Raboo is offline
Old 10th August 2008, 21:40   #2003  |  Link
Grossmeister
I'm new to StaxRip, and currently I'm trying to configure it. But there is problem I couldn't solve. For BeSweet configuration I receive "There is a problem with the bsn library.".
I tried StaxRip 1.1.1.0 and latest beta, BeSweet 1.4 and 1.5b31.
What should I do?
Grossmeister is offline
Old 10th August 2008, 22:03   #2004  |  Link
stax76
Do you understand what these options do?
From where do you have the BeSweet version?
stax76 is offline
Old 11th August 2008, 00:48   #2005  |  Link
Grossmeister
http://besweet.notrace.dk/ (http://dspguru.doom9.org/).
Old 11th August 2008, 02:06   #2006  |  Link
Raboo
Ehehe nope :S
I just have a goal.. and the goal it to cut of the black lines on the sides without cutting to much.. If it's possible
Raboo is offline
Old 11th August 2008, 08:50   #2007  |  Link
stax76
@Grossmeister
Didn't StaxRip ask to download BeSweet with the internal download feature? Please post the exact error/warning (the image attachment wasn't approved, please use 2shared.com instead of forum attachments) or the first sentence of it if it's too long.
@Raboo
I don't know a guide explaining this in detail but it's discussed in the forum extensively, please use the forum search entering the following two words together in arbitrary order using default search options: overcrop mod
stax76 is offline
Old 11th August 2008, 11:49   #2008  |  Link
Grossmeister
I downloaded BeSweet manually and then copied BeSweet.exe and bsn.dll to the folder specified on image.
Old 11th August 2008, 13:28   #2009  |  Link
stax76
Probably you miss some components or use incompatible versions, generally you should always follow the advice StaxRip gives and never change any default values unless you know exactly what you are doing.
stax76 is offline
Old 11th August 2008, 14:40   #2010  |  Link
Grossmeister
Where can I find, which version is compatible?
Old 11th August 2008, 14:56   #2011  |  Link
stax76
You can find it within the external applications dialog.
stax76 is offline
Old 11th August 2008, 17:33   #2012  |  Link
burfadel
Just a note, Microsoft has released Net Framework 3.5 SP1, since Staxrip uses Net framework thought it might be worth mentioning
This also updates Net framework 2 and 3 as its inclusive, so both of these are now Net Framework 2.0 SP1 and Net Framework 3.0 SP1!
Separate Visual C++ Runtimes have also been updated to SP1 versions, so install these too - x64 users should install both the x86 and x64 versions.
burfadel is offline
Old 11th August 2008, 18:03   #2013  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
Why should x64 users install both versions? x64 version is enough.
Deinorius is offline
Old 11th August 2008, 18:35   #2014  |  Link
burfadel
From what I understand the x64 version is for x64 programme support and the x86 is for 32 bit programme support 32 bit programmes can't use the 64 bit runtime! Therefore, on x64, you need to install both. Actually since most programmes are x86, its probably more important to install the x86 version! The x64 version doesn't install the x86 version along with it, hence why it allows you to install the x86 without saying its not designed for the particular system for which you are installing it on.
burfadel is offline
Old 11th August 2008, 19:56   #2015  |  Link
Grossmeister
When I click "Download" in StaxRip menu it starts to download 7-z - I have 7-z 4.57, StaxRip says that it doesn't know this version of 7-z and starts to download 4.57 again (!). This is some kind of joke. Can I fix only problem with BeSweet?
By the way, when I click "Tools"->"Download with Browser" StaxRip is opening link to 1.5b31 download.
OK, finally I just downloaded BeSweet from StaxRip website, and this 1.5b31 really has different bsn.dll.
Old 12th August 2008, 10:50   #2016  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
@burfadel
Hmm... I'm afraid, I always thought, you can use .NET programs with both runtimes. Maybe it was just wishful thinking. Of course I never tested it nor I asked it, but I never read anything about it too.
It seems I have something to research for.
Old 13th August 2008, 22:45   #2017  |  Link
Ramir Gonzales
I also wonder if there's any danger updating the .NET framework, if Staxrip will start to misbehave ?
Ramir Gonzales is offline
Old 14th August 2008, 17:12   #2018  |  Link
pausefisk
I updated to 3.5 SP1, but still it will not start for me, still reporting "System.InvalidOperationException" in windows error reporting (vista 32bit (norwegian)).
Seems like staxrip wont run on my pc... =(
pausefisk is offline
Old 14th August 2008, 22:57   #2019  |  Link
weaver4
I am having a problem with mp4box muxing. It appears that it can not load my subtitles. Here is the log.
Muxing
"C:\Documents and Settings\Trey Weaver\Local Settings\Application Data\StaxRip\Applications\MP4Box\MP4Box.exe" -fps 23.976 -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\SP.zsxq21_EncoderOutput.264#video:name=Video" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1 01 en-English 3_2ch 448Kbps DELAY -212ms_AudioOutput.mp4:lang=eng:name=English" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.idx#1" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.srt:lang=eng" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf8.srt:lang=eng" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf16le.srt:lang=eng" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf16be.srt:lang=eng" -new "E:\SP.zsxq21.mp4"
AVC-H264 import - frame size 640 x 272 at 23.976 FPS
Import results: 131461 samples - Slices: 1609 I 55665 P 74187 B - 1 SEI - 1565 IDR
Stream uses B-slice references - max frame delay 2
IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels)
VobSub import - subpicture stream 'eng'
Timed Text (SRT) import - text track 640 x 272, font Serif (size 18)
Error importing D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf16be.srt:lang=eng: Feature Not Supported
Error
MP4 muxing failed
weaver4 is offline
Old 15th August 2008, 08:45   #2020  |  Link
buzzqw
HDConvertToX author
try renaming subs with a simplier name not with a triple point name
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline
gui, h.264, h.265, hevc, mkv, x264, x265
