31st October 2016, 03:33 | #5101 | Link | |
Also, if anyone finds it useful, L-SMASH Indexer works with VC-1 video if the video (only the video, no audio) is muxed as a .ts file (using tsMuxeR) then indexed with L-SMASH. I don't know why this works but it does (I've been doing this successfully for several years). Out of paranoia I demux the video to raw .vc1 (using the HD Steams Extractor) then remux it with tsMuxeR, but it might work otherwise, too. Last edited by LouieChuckyMerry; 31st October 2016 at 03:46. |
1st November 2016, 21:12 | #5102 | Link | |
6th November 2016, 19:31 | #5104 | Link |
2663 [FileIndexer] fixed processing of DVDs with only one PGC 2662 [IFOParser] fixed sometimes not able to get the language information 2661 [Main] reverted 2639. Bug #843 2660 [Presets] fixed not changing the selected preset if no change has been made in the configuration window. Bug #844 2659 [VobSubber] fixed subtitle export for multi-angle discs 2658 [OneClick]+[FileIndexer] only use pgcdemux if it is a multi-pgc or multi-angle DVD source 2657 [IFOParser] add subtitle type only if there are multiple types 2656 [OneClick]+[ChapterCreator] improved DVD/Blu-ray structure detection 2655 [IFOParser] fixed missing first subtitle track if it contains more than one subtitle type added type information (4:3/wide/letterbox/pan&scan) to the description of the subtitle track added multi-angle detection 2653 [AudioEncoder] fixed an error when aborting the job during the initial steps Last edited by Zathor; 6th November 2016 at 21:52. |
8th November 2016, 10:22 | #5106 | Link |
Haali Matroska Muxer?
"Getting "Haali Matroska Muxer" instance failed.v01" and "Please (re)install the Haali Matroska Muxer to fix this error" when using the HD streams extractor tool on a .ts file with MeGUI 2663. Code:
/.../ -[Error] Log for job2 (ext, file.ts -> Encode) --[Information] [2016-11-08 10:09:29] Started handling job --[Information] [2016-11-08 10:09:29] Preprocessing --[Information] [2016-11-08 10:09:29] Job command line: "C:\Users\Johan\AppData\Local\MeGUI\tools\eac3to\eac3to.exe" "C:\Users\Johan\Desktop\Encode\file.ts" 1:"C:\Users\Johan\Desktop\Encode\T1_Video - .mkv" 2:"C:\Users\Johan\Desktop\Encode\T2_Audio - English.aac" -progressnumbers --[Information] [2016-11-08 10:09:29] Process started --[Error] [2016-11-08 10:09:29] Standard output stream ---[Information] [2016-11-08 10:09:30] TS, 1 video track, 1 audio track, 1:11:15, 25p ---[Information] [2016-11-08 10:09:30] 1: h264/AVC, 720p25 (16:9) ---[Information] [2016-11-08 10:09:31] 2: AAC, 2.0 channels, 24kHz, -40ms ---[Information] [2016-11-08 10:09:31] v01 Extracting video track number 1... ---[Information] [2016-11-08 10:09:31] a02 Extracting audio track number 2... ---[Information] [2016-11-08 10:09:31] v01 Muxing video to Matroska... ---[Information] [2016-11-08 10:09:31] Getting "Haali Matroska Muxer" instance failed.v01 ---[Information] [2016-11-08 10:09:31] a02 Applying AAC delay... ---[Information] [2016-11-08 10:09:31] a02 A remaining delay of +2ms could not be fixed. ---[Information] [2016-11-08 10:09:31] a02 Creating file "C:\Users\Johan\Desktop\Encode\T2_Audio - English.aac"... ---[Information] [2016-11-08 10:09:38] Aborted at file position 934595752. ---[Error] [2016-11-08 10:09:38] [v01] Getting "Haali Matroska Muxer" instance failed. <ERROR> ---[Error] [2016-11-08 10:09:38] Aborted at file position 934595752. <ERROR> --[Information] [2016-11-08 10:09:29] Standard error stream --[Error] [2016-11-08 10:09:38] Please (re)install the Haali Matroska Muxer to fix this error --[Error] [2016-11-08 10:09:39] Process exits with error: 1 /.../ mediainfo: General ID : 1 (0x1) Complete name : file.ts Format : MPEG-TS File size : 891 MiB Duration : 1 h 11 min Overall bit rate mode : Variable Overall bit rate : 1 749 kb/s Video ID : 256 (0x100) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=2, N=50 Codec ID : 27 Duration : 1 h 11 min Bit rate mode : Constant Nominal bit rate : 1 584 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.069 Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 257 (0x101) Menu ID : 1 (0x1) Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : HE-AAC / LC Muxing mode : ADTS Codec ID : 15 Duration : 1 h 11 min Bit rate mode : Variable Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz / 24.0 kHz Frame rate : 23.438 FPS (1024 spf) Compression mode : Lossy Delay relative to video : -40 ms |
8th November 2016, 10:50 | #5108 | Link |
When you use 'HD streams extractor tool' to extract the video muxed as .mkv, eac3to need Haali Matroska Muxer.
But you can extract (Extract As) that video as elementary video stream .h264, and now you don't need Haali Matroska Muxer.
8th November 2016, 19:46 | #5110 | Link |
Thanks, but which default settings produce errors? Do you mean that the external tool is not properly installed?
For some functions the haali splitter is needed. You have that twice in the log. It cannot be installed by MeGUI as for that administrative permissions are required. MeGUI will not perform such actions automatically, but you will be informed that it is required. Also not all eac3to use cases need the splitter. |
8th November 2016, 20:13 | #5111 | Link |
I would even doubt that TransportStreams with AAC audio are very common. I guess a surveillance camera may produce that. But I don't know any consumer media format for cinematic movies offering such a combination.
9th November 2016, 07:23 | #5113 | Link | |
The HD Streams Extractor tool's.
Even if it's rare with AAC in ts, other people than me will end up with this problem too, for sure. Maybe doing it the same way as it's done with the Nero AAC encoder, that a popup informs you of a separate and manual download in some part of the configuration? At least a more informative log message would be useful, one that informs you that something needs to be installed manually, and preferably how. |
15th November 2016, 08:17 | #5115 | Link |
It'd be a large post, because it was a detailed feature request, so rather than copy and paste it here I'll paste a link to the feature request on SourceForge.... if anyone would care to read it, comment there or here, and/or offer further suggestions, or tell me it's a silly idea... but I think it has potential and others may come up with better ideas for implementing it, or for implementing something similar.
Its a suggestion for making it easier to add custom filters to a script via the script creator and to enable and disable them via the GUI, and a method of working around the problem of adding custom filters to a script manually, only to have MeGUI re-write the entire script if you change something in the script creator GUI. https://sourceforge.net/p/megui/feature-requests/604/ |
16th November 2016, 18:00 | #5116 | Link | |
Hi
I get this error, v.2624 works OK on those files. Quote:
I see it allready happend... http://forum.doom9.org/showthread.php?t=115083 Last edited by dev84; 16th November 2016 at 18:14. |
17th November 2016, 20:16 | #5117 | Link |
Could you release a DPI aware build?
Current MeGUI UI is ugly in high DPI settings in Windows 10.
Could you release a build with DPI aware? It's quite simple, just uncomment following code in app.manifest and rebuild it. <!-- <application xmlns="urn:schemas-microsoft-com:asm.v3"> <windowsSettings> <dpiAware xmlns="http://schemas.microsoft.com/SMI/2005/WindowsSettings">true</dpiAware> </windowsSettings> </application> --> |
17th November 2016, 21:23 | #5118 | Link |
Maybe there's more to it than that? I don't know for sure, but from the changelog:
2609 removed the DPI aware flag (requires Windows Vista+) The application will now look blurry when using 150+% DPI but all controls are visible Known Problems: - Windows XP and older is not supported - Unicode is not supported - non default DPI values are not supported |
19th November 2016, 01:19 | #5120 | Link |
hello_hello, thx, for info about updating the ffmpeg to xp friendly
https://sourceforge.net/projects/mpl...0912-gce466d0/ I changed also the LSMASHSource to the one You suggested, unfortunately it doesn't work but it's ok i use FFMS. It's up to date and working on xp thx |
