Old 11th December 2015, 02:22   #4861  |  Link
LigH
LigH's Avatar
I have a strange issue with MPC-HC (64-bit) 1.7.10 (d911f14). It seems to apply a kind of automatic de-shaker filter to every video played. They are all surrounded by a black border which seems to get adapted to moving content (shrinks sometimes when letterboxes are included). It is especially obvious when you have slightly shaking footage with a logo in a corner, then you can see how the image is stabilized but the logo is shaking, half covered by the border.
What may that be? How can I disable that? I don't think I have such a filter installed, it seems to appear in MPC-HC with internal LAV Filters only (but I am not aware that they implement such a feature), not in e.g. GraphStudioNext rendering a media file (this uses MS DTV-DVD filters for decoding because there are no other DirectShow filters installed yet).
Technical info:
MPC-HC (64-bit)
Build information:
    Version:            1.7.10 (d911f14)
    Compiler:           MSVC 2013 Update 5
    Build date:         Nov 14 2015 18:25:24
LAV Filters:
    LAV Splitter:       0.66.0.0
    LAV Video:          0.66.0.0
    LAV Audio:          0.66.0.0
    FFmpeg compiler:    MinGW-w64 GCC 4.9.2
Operating system:
    Name:               Windows NT 6.1 (build 7601, Service Pack 1)
    Version:            6.1 (64-bit)
Hardware:
    CPU:                AMD A4-4000 APU with Radeon(tm) HD Graphics
    GPU:                AMD Radeon HD 7480D (driver version: 8.17.10.1116)
Filters currently loaded:
- Default DirectSound Device
- Enhanced Video Renderer (custom presenter)
- Audio Switcher
- LAV Video Decoder (internal)
- LAV Audio Decoder (internal)
- LAV Splitter Source (internal)
__
Oh, heck, it helps writing about it...
It's not a feature of MPC-HC.
It's not a feature of LAV Filters either.
It's a feature of AMD, called "Steady Video".
I hate AMD Catalyst drivers. They are full of ghosts you never intended to call.
New German Gleitz board
Old 14th December 2015, 22:38   #4862  |  Link
Zathor
Originally Posted by Barough View Post
MediaInfo v0.7.80 have been released
Version 0.7.80, 2015-11-30
Thanks, it is now online.
Zathor is offline   Reply With Quote
Old 15th December 2015, 14:54   #4863  |  Link
ravewulf
I don't see any option in MeGUI to manage VFR video: http://forum.doom9.org/showthread.php?t=172917
Feature request:
1) Add a tool to extract video timecodes from mkv.
2) Add a option to load video timecodes in mkv muxer.
Additional request for VFR support in mp4 files:
The easiest way to support this is probably through x264 as it can load timecode files directly via --tcfile-in as long as the output format also supports vfr (use internal mp4/mkv muxer, optionally use external muxer after if for some reason the external muxers are preferred). Another method I know of is here http://forum.doom9.org/showthread.php?t=112199
EDIT: To address 1) FFVideoSource can output the timecodes from the file being read https://github.com/FFMS/ffms2/blob/m...s2-avisynth.md
Last edited by ravewulf; 19th December 2015 at 06:31. Reason: Added additional information
ravewulf is offline   Reply With Quote
Old 16th December 2015, 07:52   #4864  |  Link
kotuwa
MeGUI FLAC issue.
MeGUI 2624. Flac 1.3.1
Just encoded into FLAC using different speed presets...
8 and 0.
Both gave same file size. Looks like 0 was used in both.
Any reason or Fix?
kotuwa is offline   Reply With Quote
Old 17th December 2015, 21:44   #4865  |  Link
Atlantis
Sorry I have not read this long thread. My MeGUI is updated to 2624 and today I noticed I can no longer encode to ac3. Any reason why Aften was removed? What you should use to encode to AC3 in MeGUI 2624?
Atlantis is offline   Reply With Quote
Old 17th December 2015, 22:06   #4866  |  Link
Barough
Barough's Avatar
Use FFmpeg AC-3
Old 17th December 2015, 23:07   #4867  |  Link
Atlantis
Why they removed Aften?
Old 17th December 2015, 23:55   #4868  |  Link
LigH
LigH's Avatar
I believe the AC3 encoder in ffmpeg developed a bit further, especially in its psychoacoustic routines, while Aften didn't. But I am not completely sure.
Old 18th December 2015, 02:53   #4869  |  Link
tebasuna51
tebasuna51's Avatar
Yep, Aften is discontinued, the same developper make the ffmpeg AC3 encoder (libav) improving stereo encode and other parts.
http://forum.doom9.org/showthread.ph...77#post1522077
Old 18th December 2015, 04:11   #4870  |  Link
hello_hello
I just re-started MeGUI and auto-update downgraded MediaInfo from 0.7.80 to 0.7.79. Was that intentional?
Old 18th December 2015, 15:02   #4871  |  Link
Barough
Barough's Avatar
Wonder the same here also
Old 19th December 2015, 18:55   #4872  |  Link
Zathor
8 and 0.
Thanks, will be fixed in the next build.
Thanks, one of the update server was out of sync.
Old 23rd December 2015, 13:09   #4873  |  Link
Zathor
The newer FFM2 plugin versions seem to require a recent AviSynth version. At least it does not work with 2.5.8 but it does work with 2.6
I am unsure which way to go. I could block all AviSynth versions which are not using the recent interface version and use the portable AviSynth instead.
Or I can print out only a error message and continue with the old way.
Both ways have pros and cons. Which would you prefer?
Old 24th December 2015, 11:45   #4874  |  Link
tebasuna51
tebasuna51's Avatar
Yes, I see that. I use sometimes 2.5.8 and need switch to 2.6 to work with FFM2.
I prefer "use the portable AviSynth instead" for me.
Old 25th December 2015, 14:50   #4875  |  Link
Barough
Barough's Avatar
"always use the included AviSynth" is what i use.
FFmpeg v2.8.4 is out
http://ffmpeg.zeranoe.com/builds/win32/static/
Old 26th December 2015, 16:18   #4876  |  Link
Zathor
Ok, I will emplement it in the way that I update the AviSynthWrapper to the recent interface version (currently 2, will be 6). With this new DLL no old AviSynth versions can be accessed. During startup of MeGUIthis will be checked and if necessary a fallback to the portable AviSynth will be done.
After this change it is not possible to use MeGUI with older AviSynth versions (replacing the DLL is the only way).
Old 28th December 2015, 05:22   #4877  |  Link
hello_hello
I found myself explaining to someone again today, why an anamorphic option called "Encode non-mod16" lets you encode mod16.
I still think a rename might be in order. "Encode any-mod" would work. Anamorphic "strict" as Handbrake calls it seems pretty succinct. Not to mention accurate.....
Old 28th December 2015, 13:51   #4878  |  Link
hello_hello
I'm using an anamorphic DVD encode to illustrate the problem. It's an MKV. I open and index it. The script creator looks like this:
Problem #1. The display aspect ratio of the source video isn't in the drop down list. So if I change it, I can't change it back, unless....
Problem #2: I create a custom aspect ratio in which case the source aspect ratio will be automatically be listed, so as long as I remember to create a custom aspect ratio first, I'm fine. Until......
Problem #3. I don't want to use the custom aspect ratio any longer and wish to delete it, but I can't unless I delete all the custom aspect ratios.
Happy New Year everyone. Especially Zathor.
PS. I still think it's time for MeGUI to switch from using the old ITU pixel aspect ratios for DVDs to the MPEG4 pixel aspect ratios. Because.....
- They're easier to remember.
- The display aspect ratios for NTSC and PAL are exactly the same, so there's only two display aspect ratios in total.
- They're included in the list of pixel aspect ratios in the x264 encoder configuration. The ITU PARs aren't.
- If you use --bluray-compat in the command line MeGUI (or the x264 encoder) automatically changes the ITU PARs to MPEG4 PARs.
- It keeps everything more consistent.
- Depending on the setting in preferences, MeGUI will choose either an ITU or generic display aspect ratios for NTSC or PAL Bluray video. I'm pretty sure both would technically be wrong.
- It's 2016 (give or take a day or so).
Old 28th December 2015, 14:01   #4879  |  Link
hello_hello
One more pixel aspect ratio related question. The mpeg4 and generic pixel aspect ratios are:
MPEG4:
      PAL    NTSC
4:3   12:11  10:11
16:9  16:11  40:33
Generic:
      PAL    NTSC
4:3   16:15  8:9
16:9  64:45  32:27
All the above are listed in the drop down list of pixel aspect ratios (SARs) in MeGUI's x264 encoder configuration, except the one highlighted in blue (generic PAL 4:3).
Not that it really matters, aside from the fact that once I noticed I realised I'll probably never sleep well again until I know why.
Old 28th December 2015, 16:18   #4880  |  Link
Zathor
2627 [Main]                 detects during startup if AviSynth can be used
                            automatic fallback to the portable AviSynth
2626 [AvisynthWrapper]      updated to recent avisynth.h (requires AviSynth 2.6)
                            improved error handling
                            added x64 support
2625 [Flac Encoder]         fixed always using compression level 0 (regression of 2536)
Please report as usual issues with this new build. I expect some problems due to the switch to avisynth interface version 6 (before it was 2).
EDIT: A positive effect is that due to the improved error handler AviSynth should not be able to crash MeGUI anymore (like with FFM2 and fast cropping).
EDIT2: With hello_hello in mind I have compiled the wrapper also for XP. I hope it works :-)
