4th September 2009, 13:31 | #9521 | Link | |
So instead of adding AMR it would be better to dedicate time in more essential things like DXVA with interlaced VC-1 which is NO go currently. |
4th September 2009, 13:52 | #9522 | Link | |
hoborg
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
4th September 2009, 13:55 | #9523 | Link | |
4th September 2009, 13:58 | #9524 | Link | |
MPC-HC Project Manager
-Pre-Beliyaal merge non tearing -Post Beliyaal merge tearing -Gothsync build with a matching refreshrate file with the settings EVR/255/SyncNearest We will investigate your problem. Any report you make of a tearing related problem that does not contain screenshots will be rejected with "works for me, tested on +/- 20 different systems (from geforce2 to 200 series, and ati 7500 to 4870) (From win2000 to win7 X64)" Please help us help you. Do not ask why, just do it.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 4th September 2009 at 14:04. |
4th September 2009, 20:10 | #9525 | Link | |
Who is we ?
I've been bitten on this sort of thing before in totally unrelated Forums where: 1 - I ask a question 2 - Moderator claims that it is Forum rules that, in order to ask that sort of question, I have to post extensive details. 3 - I spend 30-60 minutes of my life getting and posting those details. 4 - Result after posting details: not one reply to the question At this point, I am 90% sure that what happened is that Beliyaal removed all the sync code, including for both multiples and for non-multiples, and then never wrote his own code for cases with non-multiples. If these mythical investigators exist, the first thing would be to simplify verify whether or not the code does anything for the timing in non-multiple situations. Ar-jar describes his code that eliminates the problem as follows (which is also a good example of describing what is being done by code)(bold added by me): Quote:
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote Last edited by ADude; 4th September 2009 at 20:12. |
4th September 2009, 20:34 | #9526 | Link |
Please just post the screenshots. Otherwise this is going to be an endless discussion.
MPC-HC 2.2.1 |
4th September 2009, 22:33 | #9527 | Link | |
-You have a problem. -You don't want to loose 30-60 min of your lifetime to help solving the problem. -You want someone, who does not have the problem, to loose those 30-60min instead of you. I wish you good luck. |
5th September 2009, 01:28 | #9529 | Link | |
ar-jar is in the middle of a huge project at work and cannot do any MPC-HC related work at all, for quite some time. Beliyaal refuses to reply, which is the source of the problems. Casimir refuses to reply about any Beliyaal-related code. So, I don't see any point to posting anything. And now mixer73 won't even see the post. PS all this aside from the fact that the requested screenshots have really nothing to do with the problem... remember that the people who are suddenly demanding screenshots are the same people who thought that the problem was caused by the GPU being from 2007
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote Last edited by ADude; 5th September 2009 at 02:20. |
5th September 2009, 10:39 | #9535 | Link |
Would it be possible to play this type of file with DirectShow and internal MPC source/transform filters? Now it works only with the QuickTime plugin (otherwise there is no image).
General Complete name : F:\DCIM\109_PANA\P1090356.MOV Format : QuickTime Format/Info : Original Apple specifications File size : 14.2 MiB Duration : 12s 0ms Overall bit rate : 9 897 Kbps Encoded date : UTC 2009-09-05 12:29:21 Tagged date : UTC 2009-09-05 12:29:21 Writing library : pana Video ID : 1 Format : M-JPEG Codec ID : jpeg Duration : 12s 0ms Bit rate mode : Variable Bit rate : 9 831 Kbps Width : 848 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Bits/(Pixel*Frame) : 0.805 Stream size : 14.1 MiB (99%) Encoded date : UTC 2009-09-05 12:29:21 Tagged date : UTC 2009-09-05 12:29:21 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Unsigned Codec ID : raw Duration : 12s 0ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Sampling rate : 8 000 Hz Resolution : 8 bits Stream size : 93.8 KiB (1%) Encoded date : UTC 2009-09-05 12:29:21 Tagged date : UTC 2009-09-05 12:29:21 It's a video shot with my digital camera. Here's a sample, if it helps... |
5th September 2009, 11:42 | #9536 | Link | |
I'm fed up reading this. The developers will read your posting and something will be attempted I'm sure...
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
5th September 2009, 12:50 | #9537 | Link |
On 1080p video (h264 in mkv, mts, m2ts, mp4), I have these serious problems when the cpu is at 30% and the video lags behind and eventually freezes, while the audio continues. This happens with every renderer but Haali Renderer. VMR9 is qustionable, it lags behind in the beginning but catch up later.
I am using MPC-HC x64 svn 1265 though I have these problems with almost every svn since 908. MPC 6.4.9.1 doesn't work either although it doesn't lag behind as much as MPC-HC. I am using the built in ffmpeg-mt filter with MPC-HC and ffmpeg-mt from ffdshow 3064 when using MPC. So does anyone know what the cause is? I don't want to use Haali Renderer, because I want to use DirectVobSub. My system specs is: Intel Core i7 2.67ghz ATi Radeon HD 4870 Windows XP x64 SP2 And here is what mediainfo says from one of the videos: Code:
General ID : 1 Complete name : C:\Source\HDWRITER\2008-12-24\00000.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 3.99 GiB Duration : 34mn 7s Overall bit rate : 16.8 Mbps Maximum Overall bit rate : 18.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Duration : 34mn 7s Bit rate : 15.7 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.303 Stream size : 3.74 GiB (94%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Duration : 34mn 6s Bit rate mode : Constant Bit rate : 384 Kbps Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Sampling rate : 48.0 KHz Video delay : -80ms Stream size : 93.7 MiB (2%) |
5th September 2009, 13:58 | #9538 | Link | ||
I have to admit though that it's 400 points in 3dmark06 are not exactly highend these days ;-) Still, it's a nice 2D solution and really not that bad. Quote:
The latest driver for those cards, including the X1250 onboard GPU is Catalyst 9.8. As of today, this driver is less than 2 weeks old. Please don't spread false information about ATI/AMD's driver policy. Last edited by anybody; 5th September 2009 at 14:02. Reason: rule 4 |
5th September 2009, 14:14 | #9539 | Link |
The last couple of pages have inspired me to resurrect my old TA690G (Biostar) mobo for a run at this. It has the X1250 IGP with HDMI out and I've got an X2@2.8Ghz in that thing. I'll give it a go with a subset of film sources at 24Hz and see what happens.
5th September 2009, 14:25 | #9540 | Link | |
Kid for Today
MPC doesn't fulfill everyone's expectations...due to the lack of advanced features and being quite buggy at times. the devs work on it for free and don't have much spare time...plus -as you said- Beliyaal doesn't seem to like answering to end-users whining(just like Haali w/ his fantastic -yet buggy- video renderer). when you're knowledgeable about coding, (l)users are a major nuisance...get the hang of it MPC HC is meant for DXVA in the first place, so you can play h264 on a third world computer. |
