15th September 2007, 22:46 | #521 | Link |
Otaku
Thanks for the updates casimir. One bug still remains... in the "remember file position", you are not able to replay a file that has reached it's end.
Steps to reproduce: enable the option, insert at least 2 files (like mp3) in the play list and let one of them play until it ends then plays the other one, while the second one is playing try to play the first one... basically it will resume from the end of the first file meaning it will just skip to the next one. hope this helps [EDIT]Also, if you enable "keep history" then "remember file position" then disable "keep history" "remember file position" will remain enabled and working and you cannot disable it until you enable "keep history" again.[/EDIT] [EDIT2]Is MPC v6.4.9.1 legit or fake or custom made by someone? check here.[/EDIT2]
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
15th September 2007, 23:17 | #522 | Link | |
ffdshow/AviSynth wrangler
EDIT: Okay, so it was clsid himself - move along, nothing to see here... np: Luke Vibert - Rotting Flesh Bags (Chicago, Detroit, Redruth)
now playing: [artist] - [track] ([album]) Last edited by Leak; 16th September 2007 at 09:46. |
15th September 2007, 23:25 | #523 | Link |
Otaku
That has crossed my mind as well. anyway casimir's build is more "tuned"!
16th September 2007, 00:33 | #524 | Link |
I incremented the version number in my latest build to make it more clear that it is newer than the latest version available at the Guliverkli website.
MPC-HC 2.2.1 |
16th September 2007, 06:11 | #525 | Link |
I am getting 404 on Casimir's page. Will look on sf.net directly.
Thank you very much Casimir! [EDIT] DAMN! EVR is working now! So now I can get 0-255 with DXVA enabled! Oh thank you, thank you, thank you Casimir! Last edited by Rash; 16th September 2007 at 06:38. |
16th September 2007, 07:52 | #526 | Link |
EVR is working?? I haven't made changes on it except using latest SDK...
Tired of tearing? Try this Media Player Classic mod : http://mpc-hc.sourceforge.net |
16th September 2007, 21:03 | #529 | Link | ||
Anyway, EVR custom is starting to look really good now with the latest fixes. Thanks again for your excellent work Casimir. |
16th September 2007, 22:28 | #530 | Link | |
EVR normal creates grey bars for me, so I've completely banned it from my players, hehe. Have a look. http://rash.apanela.com/images/lost_color.png http://rash.apanela.com/images/wmp11/wmp_grey_back.jpg (black frame) I can't say whether DXVA is working or not. It is selected but I don't get any confirmation/error messages. The picture quality is awesome anyway, so I'm good with it. @Cyberbeing, I have PureVideo enabled on PowerDVD Decoder and I'm using EVR Custom and menus are OK. What decoder are you using? |
16th September 2007, 22:49 | #531 | Link | |
Broadband Junkie
17th September 2007, 09:51 | #533 | Link |
Otaku
In the powerdvd decoder (h.264) to see if dxva is working or not try to tune something like brightness after the video is playing, if you can you are not using dxva. that was my case in xp with a 6800gs. in vista i can't get dxva with vmr9 and evr.
17th September 2007, 16:42 | #534 | Link | |
SW = pure software mode MC = part of the decoding pipeline is sourced out to the GPU (e.g. PureVideo HD) Bitstream = all decoding steps are performed on the GPU (e.g. PureVideo HD2)
Bye |
17th September 2007, 20:41 | #538 | Link |
Otaku
@CiNcH
thanks. has someone got hardware acceleration for h.264 with latest mpc hd and cyberlink in vista with a nvidia graphics like a 6800gs?
17th September 2007, 20:56 | #539 | Link |
@CiNch
Great shortcut! Will be helpfull
18th September 2007, 00:35 | #540 | Link |
x64 version can play dvd mpeg2 with ffdshow as decoder also, i tried it with video title set enabled in internal filters. ac3/dts passthrough with x64 ffdshow also works perfectly.
The only thing missing now is an ffdshow x64 build with eac3 decoding which hopefully isn't far away, and also a 64bit build of haali splitter and renderer. |
