20th February 2006, 18:56 | #261 | Link |
Mr. Sandman
uhm... that way it's ugly.
well, i think this idea should be dropped at this point. we can already default megui to use always 2 threads for x264 even on single core non hyperthreaded cpus (for the reasons explained above). and we can detect if there are more than 2 execution units and rise the number of threads to 4 for quad core or dual core hyperthreaded cpus...
20th February 2006, 19:22 | #262 | Link | |
Flying Skull
20th February 2006, 19:26 | #263 | Link | |
BeHappy/MeGUI developer
We (rissain comminity ) take 2 clips coded with identical adjustments, in 1 and in 2 slices and we measure speed of their decoding on 2 processors nero the decoder (which supports SMP). 1 slice- 169 fps (both of the processor are loaded) 2 slice - 167 fps (both of the processor are loaded)
BeHappy - AviSynth-based audio transcoding tool Audio encoding via AviSynth On2 VP7 is great in quality but it is unusable for long-term video backup puposes! Sincerely Yours, MCPD/MCTS |
20th February 2006, 19:55 | #264 | Link |
Mr. Sandman
interesting. maybe nero found a way to multithread the decoder using something different than slices. never looked into it...
however qt uses slices for that purpouse (but as we all know QT = coded like crap...).
20th February 2006, 20:04 | #265 | Link | |
Slices is easyest but not best way for multithreading
20th February 2006, 20:48 | #266 | Link |
Mr. Sandman
indeed... but since i never used the nero decoder i thought it was using slices (like quicktime).
well, if all the mess is for accelerating quicktime playback we can drop even the 2 slices idea for single/non-multithreaded cpus.
20th February 2006, 23:41 | #267 | Link |
Angel of Night
Well, Doom9, what about integrating Elder as a possibility? It isn't finished, but it already deals with the multiple encodings, segments, stats files, merging, and all that rubbish for you. And it works for xvid and x264. Obviously it wouldn't be bundled by default, since it's perl, but it'd be really nice to see it officially supported. Could just flip a switch and use its brand of massively multithreaded encoding rather than threads. (And since xvid and x264 support mt encoding anyway, once xvid makes it configurable you could move #threads to a global #cores option.)
20th February 2006, 23:47 | #268 | Link |
i believe it's easy to port Elder from rerl to C#
i'm interested in it
21st February 2006, 04:06 | #269 | Link |
developer wannabe
Integrating Elder looks even more difficult than trying to sort out the dependency difficulties discussed earlier.
The more I think about it, the more I like having independent queues. The existing OO design should make it reasonably easy. |
21st February 2006, 08:32 | #270 | Link |
Mr. Sandman
IMHO idipendent queues is an ugly solution.
21st February 2006, 08:46 | #271 | Link | |
21st February 2006, 09:11 | #272 | Link | |
How about this to help solve the dependancy issue... If a "job" is created, instead put all the jobs and dependant jobs inside an arraylist (just for an example, there's probably better ways of doing it. So we can go something like... Code:
Arraylist Job1 = new Arraylist(); Job1.Add(job1_pass1); Job1.Add(job2_pass2); Job1.Add(job3_pass3); .... Then... foreach(Job job in Job1) { display information in the queue } I don't know how it works at the moment, but how does that sound? Stupid or not?
Nothing to see here... |
21st February 2006, 09:23 | #273 | Link |
Actually one job series can contain:
multiple independed audio jobs 2-3 depended video jobs (multipass) mux job in this case you can run multiple audio jobs at same time talking about such architecture we are close to "Processor controlled via Data-Flow" ideology (used in all modern CPU) what does we need to organize such functionality: jobs must contain references to related jobs (i.e. 2-nd pass must refer on 1-st pass, mux must refer to 2-nd pass and all audio etc) in this case we can run any job wich related jobs is already done
21st February 2006, 10:29 | #274 | Link | |||
21st February 2006, 11:53 | #275 | Link | |
21st February 2006, 16:12 | #276 | Link | ||
clueless n00b
Actually, it's probably not even as hard to run two queues.. as the statusupdate contains a reference to the job that triggered the update, and related jobs are already linked (they need be for out-of-order processing and proper between job updates). Quote:
1st March 2006, 17:36 | #277 | Link |
Curious BetaTester
render rate for audio ?
just tried the 0.2.3.2097 devbuild works pretty good since the last time i tried, been busy with other things just wondering if there's any plans to show a rendering rate like the same as the video part ?
would be useful for benchmarking and comparing results with others
Asrock N68-S AMD Athlon(tm) II X4 620 Processor (2.6GHz) - Crucial 2GB PC6400 800MHz DDR2 - Nvidia 9600GT Tools: ProcessExplorer & ProcessMonitor - BatchCompressor Guide: MinGW Compiling GCC |
1st March 2006, 20:12 | #278 | Link | |
clueless n00b
1st March 2006, 21:31 | #279 | Link | |
2nd March 2006, 04:42 | #280 | Link | |
Curious BetaTester
