20th June 2011, 16:51 | #12281 | Link | |
20th June 2011, 16:55 | #12282 | Link |
BD Rebuilder v0.38.04 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.38.04). Changes for this version:
- Corrected an issue in which end-times might be incorrectly updated in an MPLS file for cases where partial CLPI/M2TS playback is referenced. - Added code to handle non-standard 1080p/25 and 1080p/29.97 sources and use "--fake-interlaced" in the command line to make them compliant. - Added a hidden option "CHECK_FFDSHOW". If set to "0" BD-RB will continue running even if no version of FFDSHOW is found. Anyone using this option must ensure appropriate alternate CODECs are installed, and bug reports will not be accepted when FFDSHOW has not been installed. - Changed routines so that UNC pathnames can be used as a source (should make use with NAS and other network units more compatible). - Added an additional quality setting for hidden AUTO_BIAS. Setting AUTO_BIAS=3, gives bias for even higher quality settings (lower speed) when "Automatic Quality Settings" is selected. See HIDDENOPTS.TXT for more details on AUTO_BIAS. - Changed the default values so that DTS and AC3 are kept in their original format rather than being reencoding. That choice can be changed via the SETUP dialog. - Completed testing on FFDSHOW rev 3882 and HAALI Mediasplitter version 1.11.96.14. These are now the recommended versions of these helper apps and can be downloaded from jdobbs.net. They are also now linked in the first post of the DOOM9 bug reporting thread. - Made improvements that should improve accuracy of sizing. - Updated the included version of X264.EXE to the latest release (r2008). - Updated the included version of X264-64.EXE to the latest release (r2008). - Other minor corrections and cosmetic fixes. |
20th June 2011, 17:47 | #12283 | Link | |
DVD-RB User
m00! |
20th June 2011, 17:53 | #12284 | Link | |
There are only certain circumstances in which the 64 bit version can be used. If you set "Use X264's internal LAVF for decoding" in the SETUP dialog the 64 bit version will be used whenever it is possible. This tells BD-RB to use the internal decoders in X264 (LAVF), making use of the X264 64 bit version possible. You don't have to rename anything, BD-RB knows if you are on a 64 bit system. Note, however, that lots of things will make BD-RB revert to 32 bit automatically (like resizing, using filters, etc.). When USE_LAVF is asserted and is in effect, FFDSHOW, AVISYNTH, and HAALI are not used for decoding. Do some testing... sometimes the 32 bit version along with the helper apps can be faster, even on a 64 bit system. Last edited by jdobbs; 20th June 2011 at 18:01. |
20th June 2011, 18:10 | #12285 | Link |
Will this change be used for AVCHD, full backups to BD5/9?
- Changed the default values so that DTS and AC3 are kept in their original format rather than being reencoding. That choice can be changed via the SETUP dialog. |
20th June 2011, 18:27 | #12286 | Link | |
Aging Video Hobbyist
I used to have odd, infrequent glitching exactly as you're describing DMagic1, and found that it went away once I started using DGIndexNV to decode-and-feed to x264. My issues were never as frequent as your own (you said it now happens on every project) but they were exactly as you've described. I dunno if this issue still exists for me as I very rarely use BD-RB (when I have, it's worked) and more typically roll-my-own BDs using DG's nvidia tools now. Anyway my money's on a decoding problem in your PC. Good luck finding it! |
20th June 2011, 19:19 | #12288 | Link | ||
20th June 2011, 20:54 | #12289 | Link | |
I'm running the project again with the new version of BD with the lastest x264. Also did a frame by frame of the source and saw no glitch or pixel errors. |
20th June 2011, 22:22 | #12291 | Link |
Let me start by saying that DVD Rebuilder Pro is a great program and jdobbs, I hope you were well compensated for your work. Next, let me apologize for asking a question that has probably been answered, but I have searched and this thread is far too long to just sit down and read. I have played around with BD-Rebuilder just a tad and I am unable to find a one-pass CRF mode. I see places in this thread where it is mentioned so that leads me to believe it exists. Am I missing something? Ultimately, I don't really care so much about the file size, so I would rather set a target quality and call it a day.
EDIT: Nevermind. I am an idiot. Nothing to see here folks.... move along.... EDIT #2: Is it possible to keep HD audio when using CRF and MKV container? Last edited by Balthazar2k4; 20th June 2011 at 22:42. |
20th June 2011, 22:38 | #12292 | Link | |
20th June 2011, 22:55 | #12295 | Link |
Currently you keep the core of HD audio when "intact" is selected. I do plan to allow keeping HD audio as well -- but I forgot to make that change in this release, it'll probably be in the next release. I'm not a big believer in HD audio (I think its a useless marketing gimmick) so it probably just slipped my mind.
20th June 2011, 23:57 | #12296 | Link | |
I'll keep an eye out for the next release. |
21st June 2011, 00:41 | #12299 | Link | |
[Edit] Whoops. I just tested it again and realized that I didn't save after I updated the size on the 32 bit check. I'll fix it for the next release. If the folder is 2,434,588 bytes, you're good to go. Last edited by jdobbs; 21st June 2011 at 00:47. |
