16th October 2016, 18:39 | #1221 | Link |
I make a new package of BeHappy with:
- New versions of AviSynth plugins decoders: LSMASHSource, ffms2 and Bass. - New versions of some encoders and a new encoder: OptimFROG - Also a pack of encoders with 64 bit version to replace if use OS 64 bits. - Some changes in extension folder to acomodate new encoder versions or correct some bugs. I put in main BaHappy folder OptimFROG.dll, because in plugins32 is usseless, and work here without need to copy to system folder. Is a new version from recent encoder, the included with bass_ofr don't work with the new encoder. I modify the Readme files. And I have somme suggestions about encoders: Some of them are really old and usseless: enc_AudX_CLI and mp3sEncoder. Others are deprecated and replaced with better options: dcaenc, Aften, Twolame and enc_aacPlus Now ffmpeg is preferred for AC3 and MP2, and offer the new native AAC than claim be high quality (FAAC deprecated, fdkaac not present in Zeranoe builds but we have already fdkaac). We have now 6 AAC encoders. Also CUETools, a great tool to rip CD's, but wasted here to only encode to flac when we have already Flaac. Maybe is time to clear a little BeHappy. At least I will do that with my working copy, and leave this package like a historic backup. EDIT: I forget the Readme.txt and Changes.txt from main folder but without changes with the included in Codeplex. Only ffms2 need AviSynth 2.6 but LSMASHSource work with 2.58 (and I suposse also with 2.57) EDIT 2: Included Readme.txt and Changes.txt
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 17th October 2016 at 19:48. Reason: New links |
17th October 2016, 20:11 | #1224 | Link |
I changed the packages in previous post:
- pack of encoders with 64 bit version Deleted mpcdec.exe, a decoder not needed at all. Created folder qaac (previously qaac was in encoder folder) Don't need a new download only make the changes if already download previously. - new package of BeHappy Added Readme.txt and Changes.txt with some changes. New clean BeHappy.State I know BeHappy.State is created if not exist but the included put the logical order, for me, of DSP functions. By default BeHappy put the DSP order of first image, but I like the order of second image: - First downmix channels (mono, Downmix). - After convert frequency or tempo (TimeStretch or SSRC). - Now upmix (Duplicate or Upmix 5.1). - Amplify or Normalize volume. - At last change to desired bitdepth if required. Changed files attached if already downloaded.
17th October 2016, 20:32 | #1225 | Link | |
But I think mp3sencoder need a special player to play surround mp3's, is not standard at all. And I don't found new versions, the link provided don't work.
18th October 2016, 13:47 | #1227 | Link |
Yep, the mp3s(surround)encoder.exe 2008/05/19 is still in my package.
But need special player like http://www.free-codecs.com/download/...3_surround.htm (not currently available) Or Foobar2000 plugin http://www.free-codecs.com/download/...3_surround.htm (not currently available) The same for enc_AudX_CLI, you can always make a Downmix Dpl_II, encode like regular mp3 stereo, and play with hardware/software players with Dpl_II decoder than is more standard.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 18th October 2016 at 13:49. |
18th October 2016, 14:45 | #1228 | Link |
In foobar2000 is present the last version of fhg aac (by case, 2015, in lamexp is already present too). In your package is the 2012 version of tmkk.
For now, I use mp3sencoder for mp3 cbr only. Last edited by GMJCZP; 18th October 2016 at 14:49. |
1st December 2016, 10:24 | #1229 | Link |
thanks tebasuna51
I am not sure but i think new version of behappy need net frame 4 not 2
Behappy BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions. Avisynth Movie Screenshot, thumbnails creator |
2nd January 2017, 17:26 | #1231 | Link |
At least in xp with avast, lately and sometimes exists incompatibilities with d_ConvertSample.ext. The error message starts:
"Can't load extensions from file C:\Program files\BeHappy\extensions\d_ConvertSample.ext System.InvalidOperationException:There is an error in XML document (22, 4).---> System.IO.IOException: The process cannot access the file 'C:\Documents and Settings\...\Temp\da5qiums.dll' because it is being used by another process" The solution is deactivate the AV or click in "Reintent" (equivalent to "Reintentar" in spanish). Edit: the dll archive in Temp directory maybe be different. Last edited by GMJCZP; 2nd January 2017 at 17:36. |
3rd January 2017, 00:10 | #1232 | Link |
Big Bit Savings Now !
da5qiums.dll would look suspicious to me, nothing that belongs inside BeHappy. An unwanted guest maybe ?
3rd January 2017, 10:58 | #1234 | Link |
random user
I can not imagine what dependency could be between the extension loading and some suspicious dlls in your Temp folder.
I suggest to clear your 'C:\Documents and Settings\...\Temp\' folder (manual or with CCleaner or so..).
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub> MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool |
3rd January 2017, 11:05 | #1235 | Link |
I would guess that BeHappy wants to create a temporary file, which gets a directory content list to avoid filename conflicts, and the AV takes this opportunity to scan the folder for suspicious files in the same location as their list is collected. So, obviously, cleaning the %TEMP% folder regularly is not a bad idea...
22nd January 2017, 14:56 | #1237 | Link |
random user
I have cloned BeHappy repository over to GitHub. Why? Because everybody is on GitHub.
Next week or so I'll look at tebasuna's changes. @tebasuna: You can of course send your changes via pull request at github, or I can add you as collaborator (for direct access) if you want. I aggree to clean extensions folder, we can move old exts. to 'BeHappy/extensions/deprecated/' and users can copy them back if they want to use them. Changes since last release on codeplex: (Nothing fancy, some gui tweaks and github import related things.) Code:
commit 7c938ce21cc52a35149a838c48dd941cd4b93b29 Author: jones1913 <jones1913@users.noreply.github.com> Date: Sun Jan 22 11:16:34 2017 +0100 * fix .csproj and compile.bat + add controls.cs (missing in previous commit) + add .gitignore commit fefcce84b240a96d3d66af432a7063f01aacaff5 Author: jones1913 <jones1913@users.noreply.github.com> Date: Wed Jan 11 10:45:54 2017 +0100 * move custom controls to controls.cs + add linkLabel with context menu as head to source and destination groupboxes to make related tasks accessible in a more obvious way (concept stolen from StaxRip) + add some tooltips to 'Tweak' section commit 53d4ca1eb6bfbc0e51f012698983af108aedbf4f Author: jones1913 <jones1913@users.noreply.github.com> Date: Wed Jan 11 10:27:45 2017 +0100 + show number of loaded source files in groupbox text + add option 'StartJobsInstantly' to start jobs immediately after enqueuing * state of 'omitEncoderScript' and 'startJobsInstantly' checkboxes is saved in config file commit 15d1a4546955cc76702e26623a8da38da8190ad5 Author: jones1913 <jones1913@users.noreply.github.com> Date: Wed Jan 11 10:18:54 2017 +0100 + jobqueue tab is splitted horizontal to make jobqueue/log panels resizeable * fix too much spaces in some generated encoder command lines commit 21658ae39699ba27a27c69cacdd2cf95c9440325 Author: jones1913 <jones1913@users.noreply.github.com> Date: Wed Jan 11 10:05:45 2017 +0100 + add button 'show script' to immediately inspect the avs script + add encoder commandline as comment to avs script commit 072644cb221c032854307080398d5c202b97224c Author: jones1913 <jones1913@users.noreply.github.com> Date: Wed Jan 11 09:11:57 2017 +0100 * cleanup after TFS import from codeplex * changed folder structure, removed some stuff commit 7895a07b2856940a5414280a2a1f0d662ba226fe Author: jones1913 <jones1913@users.noreply.github.com> Date: Sun Jan 8 15:34:34 2017 +0100 create README.md commit 25262541788250d9731cc5707d8749a985a64872 Author: jones1913 <jones1913@users.noreply.github.com> Date: Sun Jul 5 07:49:01 2015 -0400 * bugfix in ffmpeg aac extension Compiled binary can be found here: https://github.com/jones1913/BeHappy/releases
22nd January 2017, 23:37 | #1238 | Link |
Thanks jones1913, I aggree with your decission.
Don't need be addeed like collaborator, if I have some suggestion I can use GitHub and/or this thread.
23rd January 2017, 02:24 | #1240 | Link |
- [1] Load your mkv in BeHappy
- [1] Select LWLibavAudioSource and Configure to the Stream Index (-1 work for first audio, if not select the desired track, 2 for the second...) All audio formats (except DTS-Express) from a BluRay can be decoded by LWLibavAudioSource. - [3] If desired select any DSP (Downmix, TimeStretch, ...) - [4] Select name, Encoder and Configure to the desired mode (CBR/VBR) and Bitrate/Quality.
behappy |
